Question about Dayton E52 Utility Heater
Heater 150,000 just makes a loud hum when plugged in.
The heater has been working great. the model # is 3F219B trahanswelding@yahoo.com
  • John Keith Trahan Feb 04, 2009
    thanks i took the mooter off and plugged it in and it is the motor, where can i get one at?
  • Ira Bowles
    Ira Bowles May 11, 2010
    is the motor coming on or is it just the ignition making the hum? Sounds like a bad motor.
  • 92 Answers
Dayton is owened by Desa International so the best bet is to go to the Enerco/ Mr. heater website or call 1-800-251-0001. his is the actual manufacturer so you don't have to pay the mark up of a retail supplier.
Posted on Feb 04, 2009
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
My phd2 amp is hooked up but it making my subs hum for some reason no bass just a loud hum y is this
bad amp its getting a bypass voltage to the amp when powered down sell the amp, if it is the grey model email me ric006@yahoo.com i might buy it
Dec 24, 2011 | 1999 GMC Yukon
I have a saturn Vue 2003 with 150,000 miles. there is a loud humming noise when driving coming from the rear of the vehicle. I have rotated tires and balanced. Tires have 65% more wear to go. Muffler...
Based on your description: 150K+left rear slowed down much quicker than the right +/ and the humming noise, there is a great possibility that the Wheel Bearings will have to be replaced.
Aug 18, 2010 | 2003 Saturn VUE
Humming noise under hood near air filter
sounds like the transmission solenoids in the trans. Does your speedo work ok?
go here for villager help
http://autos.groups.yahoo.com/group/villagerquest/
Mar 29, 2009 | 1999 Mercury Villager
Maytag Netune Mah4000AWW
Makes a loud humming noise. Does the machine go thru its cycles ? Is the humm ther all the time ?
Jan 06, 2008 | Maytag MAH6500 Neptune Front Loading...
Loud humming
If this is an electric resistance heater then there is no power supply or transformer. I had a baseboard heater that would hum loudly and I found there's a wire that runs along the bottom to connect the far end of the heat element to the electrical wiring at the supply end. This wire becomes magnetized from the current flowing through it and vibrates in the channel it runs through. I was able to open this channel and squirt a bit of silicone caulk in to keep the wire from vibrating and the hum is gone.
Dec 19, 2006 | Honeywell HZ514 Baseboard Heater
Dayton E52 Utility Heater Logo
112 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
