Question about SanDisk Sansa e260 MP3 Player
Not charging and down loading form computer
It take charging only for one min also not started down loading
Just had the same problem, found solution on another thread
Switch Off
Put side switch to hold
Press in middle button, keep holding in while you plug into usb port and keep pressed for a few seconds after.
Computer should recognise it and will keep charging.
Worked for me
Posted on Feb 04, 2009
  • daveaustin14 Feb 04, 2009
    Just realised that you have e260 player, mine is 8gb clip. Problem was the same though would only charge for 1 min and not down loading
Battery light flashing jump it ,it will start but not run
It could be you have a fault in the Diode pack in the alternator you need to get this checked at an alternator repair center.
Dec 03, 2014 | 2000 Ford Mustang
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
Have a 1994 Benz c220 car won't start jump starts with no-problem ran car  for 1 hour shut car down .tried to start car started rite up .waited 5 mins and car wouldn't start up. What other parts need to be...
have a load test done on the battery as it appears that you have a dead cell. Check the charging rate and if it is not around 10 amps then the battery may not charge at all
Jul 18, 2014 | Cars & Trucks
Will not start When you turn the key lights all come on and door locks click
it might be that you need a new battery as the is not inof power in that 1 to ture it over < try jump starting > that might put some life back in it if it start leave it running for 20 - 30 min or drive round min of 12 miles as that will charge it up more
i cant help much form hear i need to know more on what its doing and the sounds (eg) duss it make a clicking sound when key it turnd or just go dead no light nothing
Dec 04, 2011 | Pontiac Cars & Trucks
I have upgrade my pc with asus 7750 processor and also attached nvidia 9500 gt graphic card now when i start playing games.. my computer shuting down every after 10 or 15 min.. pls help me out...
Sounds like you might need to upgrade your power supply, If it physically shuts off then it's probably the power supply's thermal sensor being triggered. place another fan on the power supply form the inside and check to see if it makes a difference. Also make sure your running at least a 400 watt PSU if not higher.
May 26, 2010 | ASUS (S370L) Processor Board
My 2003 chevy ventuew will not start anymore
battery probably bad or you have drain somewere
start with the easy,have battery charged and load tested
Mar 25, 2010 | 2003 Chevrolet Venture Passanger
Car won't start
Have the charging system checked out .
Have the battery load tested first.
If you want to do this testing yourself its pretty easy.
a) need a fully charged battery (charge battery 3min charge)
b) you need special equiptment to do a load test so the next best thing is open circuit test. Use a DVM
and hook it up to battery you should have min. of 12 volts. if not charge battery or replace it.
c) Leave DVM on battery start car and measure voltage with all accessories on and off should be between 13.5 and 14.5 volts.
If this is ok you know the alternator is charging that battery .
If you don't get 13.5 to 14.5 turn off vehicle and start looking at battery cables and wires behind the alternator for corrosion.
If cables are good and wires behind alternator are good then replace alternator.
Mar 30, 2009 | 1998 Toyota Camry
Zen 16 gig won't turn nor charge
hold down the reset button for about 1 min then leave it for about 30 seconds. once you have done that try turning it on, if it does not turn on and it is completely dead leave it pluged in to your computer by using the usb cable, leave for about 30 mins it then might start to charge, if it does start to charge leave it till it is fully charged and then it should turn on. if none of that works then i don't know.
Jan 06, 2009 | Creative Labs Zen Digital Media Player
Not charging
I found out how to solve this problem...first power down your computer. Then take out the battery, remove the power supply, and then hold down the power button for 30 secs. Put the power supply in only (not the battery). Start your computer after everything is done loading up put the battery back in. Give it a min. and then you should be able to roll your cursor over the battery life indicator in the lower right corner of you computer and is should say charging. I have found that other people have had this problem and it has worked for myself and for them.
Aug 26, 2008 | Computers & Internet
SanDisk Sansa e260 MP3 Player Logo
41 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
