Question about Lexmark T640 Laser Printer
241.10 paper jam
How do i clear the error
  • Anonymous Feb 04, 2009
    I am still having the same error 241.10 paper jam - check tray 1 after cleaning out the roller, spray, switch out tone and cartridge.
  • tarcom Apr 11, 2009
    I have the same problem. But I do know that the rollers have never been changed. I would like to know what the part number or numbers is for the rollers so that I can purchase them.
    President:
  • Lexmark Master
  • 1,314 Answers
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Posted on Feb 04, 2009
There is a little plastic lip coming up on the right side of the paper tray that actuates the pick assembly to come down upon the paper. If it is missing the rollers will never come down to feed the paper in giving a 241.10. Replace tray if the stub is missing.
Posted on Jan 27, 2010
  • printerma956 Jan 27, 2010
Replaced the LCD Panel on a Lexmark T640 and now receiving 950.10 NVRam Error. I have tried to reset the printer and it did not work. I would appreciate if someone could help with a resolution.
  • 1,602 Answers
MOST OF TOME OPENING THE COVER WHERE THE INK OR TONER GOES WILL AUTOMATICLY RESET THE COPY OR PRINTER,
THE ROLLER MY HAVE INK BUILT UP ON THE ROLLERS,EXPLAIN;
THE DRUM HOT YOUR RUNNING HOT PAPER AND HOT INK OR TONER CHEMICALS ONTO THE ROLLERS AND DRUM AND THAN THE PAPER COMES OUT WARN LEAVING THE INK CHEMICALS INSIDE THE MACHINE ON THE ROLLERS THE MACHINE NEED A FEW MILLISECOUNDS TO COOL DOWN SO THE INK WILL DRY BEFORE THE NEXT PAGE COME THROUGHT IF NOT JAM EVERY TIME, OR SMEAR ON THE PAPER, LINE ON THE COPIES
ROD
SOURCE: lexmark c510 241 paper jam error
had same trouble with card stock
I read the manual...lo! There are markers on the inside of the feed tray for various media. Complied with these markers, and no more problem. Should work for paper too.
jre
Posted on Feb 27, 2008
frcs68
  • 1605 Answers
SOURCE: Paper Jam error
try to open the cover and reseat the ink.
the machine is trying tell you there is something stuck inside where the switch or the senser is located. usually right before the heater path. after the paper pickup roller.
Posted on Oct 15, 2008
nonontech
  • 4737 Answers
SOURCE: dell 922 saying there is a paper jam
First try this. Turn off the printer, remove all the cartridges, drum, open all the doors and remove all the trays. Now verify that there's no actual paper jam by exploring through the inside of the printer. You can use a blower to blow any dust or pieces of paper, etc.. from the printer. Now use the manual feed and put in thicker paper several times (push in and pull out). Again reinstall and reconnect every components and boot the printer. If the actual printer's paper sensor isn't broken or stuck or twisted, this will definitely clear the paper jam message on the printer.
If the problem persists, please download this small text file and follow the instructions (click here). Open the link, click "Download Now" button, wait for 20 seconds and again click "Download File Now" link and read the instructions and follow step by step.
Good luck.
Thanks for using FixYa.
Posted on Aug 17, 2010
SOURCE: Paper Jam Error 2
Samsuing SCX 4200
would not give up [Paper jam 2 - Check Inside] alarm
no jam, nothing broken, turning off etc. no help
Finally put a sheet in halfway through the manual feed slot
- had door open doing it so I could make sure sheet went far enough so that the little two-pronged black flag right at front of the paper feed opening was kept pushed down by the sheet.
Then used Copy to copy the sheet - this got rid of the false alarm. Prints ok again.
Posted on Feb 22, 2008
Cops
  • 64 Answers
SOURCE: when i try to print anything, i get a message 241 paper jam,
this is most likely to be worn pick up rollers. these are the two rubber wheels that you can see underneath the printer when you remove the tray. you should be able to source these from a local suplier and are very easy to fit. just make sure your gentle with the clip that holds them in place as if they break then you will need to buy a whole new pick up assembaly which is significantly more expensive.
hope this helps
Pete
Posted on Nov 25, 2008
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Paper Jam error
Oct 11, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark T640 Laser Printer Logo
13,712 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
