I ereas the setting from hand set now i want pair hand set with base
Sorry, it seems that they have no manual for this model online yet. however, the procedure to reset handsets might work if you go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf") good luck!
To assign Panasonic KX-TC1175BXN is:
On base phone press and hold function/edit button until hear double beap, and than press * button.
On hand set press function/edit, select program, select unit option, select assign, select chanel you want, and it's done.
Hope this write help full for you.
HS.
No work all hand set display is blank pls help
Please dont forget to vote if you liked my answer
thanks
there is messege come on cordless handset say out of rang and i can not use the cordless unet thank you
i have sam the problem
hand set unsubcribe
