Question about RCA 32F531T 32" TV
Tuning video programs
Hi, I have a Sony Video Machine model SLV-SE840G. It has a Menu option to record programs. My RF channel is 21, but i use channel 8 for watching programs when they have been recorded. its position has changed or dissapeared and i can't get it back on channel 8. I would be glad if you could help
I have solved the recent problem myself. I simply retuned the Menu option on channel * and then stored the channel into the TV
Posted on Feb 11, 2009
Have Sony VCR model SLV-N80/N70 . Cannot get it to record using Samsung TV model SLV-N80,N70.
The television has nothing to do with recording. It is only required for playback. There are a number of possibilities depending on what equipment you have. Do you have cable, satellite, antenna? Your signal source has to be connected to the VCR either through the cable connector, or RCA video jacks.
If you have straight cable, connect the cable to the "ant in" connector on the VCR. The VCRs tuner will select the channel you want to record. If you are on antenna, you will need a Digital set top box (STB) to receive any channels.
If you have a satellite, cable box or digital STB, you must go from the output of the box to the input of the VCR. You can use the standard coax cable,but I would recommend using the audio/video cables for better quality. If using coax, the VCR will have to be set to either channel 3 or 4, depending on the boxes output setting. Using A/V jacks, the VCR will be set to "Line" or "Video" input.
Feb 26, 2011 | Sony SLV-N70 VHS VCR
How do i get my toshiba regza lcd tv to work via the antenna/cable input
Change video source by pressing Input button and select TV, make sure antenna is connected in RF In jack in tv then go to Tuning menu and select Auto Tuning/ Auto Scan option, tv will tune and store all available channels in memory.
Let me know model number of tv if you have additional question.
Thanks.
Jan 08, 2011 | Toshiba Televison & Video
I have just purchased the sony video player SLV SF900 for my mum. I have used a scart socket to connect through the freeview box and to the back of the video. I have also added the aerial sockets. The...
Not all SCART connectors and cables carry the IN and OUT connections - make sure that the one from the freeview box has OUT connections, that the cable can carry them and that the one from the recorder has IN connections. Then , to record what you want, all you have to do is to tune the freeview box on that channel and set the recorder to use that SCART connector as source.
Sep 03, 2010 | Televison & Video
How come I can play video tapes on my sony video casette recorder, but can not record tv channels on my recorder?
i guess you havent connected it correctly.
Run your ariel int antenna (RF) in on the video recorder.
You will need another (RF) cable that connects from RF-out on the video recorder to antenna in on the tv.
put the tv onto channel AV (or video)
tune (scan) the TV channels on your video recorder.
NOW you will be able to record the channel you see it play on TV
hope this helps!
Apr 06, 2009 | Televison & Video
I need playback channel for tv to be ch.4 -
Solution 1
How to set the DVD Recorder+VCR’s RF output channel
Turn off the DVD Recorder+VCR, then press and hold
CH (v/V) on the front panel for about five
seconds to change the RF output channel (CH 03 or
CH 04). “RF 03” or “RF 04” appears on the front panel display.
Solution 2
Cable Service With Cable Box
If a cable box is required in your cable system, follow the
instructions shown below. This hookup permits both TV and
DVD Recorder+VCR operation.
To view or record a CATV channel:
1 Tune the TV to the correct video input channel.
2 Set the DVD Recorder+VCR to the output channel of the
cable box using the CH (v / V) or the 0-9 keys on your DVD
Recorder+VCR (e.g., CH3).
3 Select the channel you wish to view on the cable box.
Please rate this a fixya
Jan 30, 2009 | GoVideo Go Video DVD/VCR Combo
VCR with intermittant audio and video problems
you have to connect VCR output cable to your TV input, thats all, it will be in series, if u want to record any program then on your TV and on record switch of your VCR.
Dec 30, 2008 | Sony SLV-N55 VHS VCR
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
RCA 32F531T 32" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
