Question about Canon LaserBase MF3220 All-In-One Printer
Laserbase mf3220 paper jams
I have the above problem and it has constantly paper jams, it pulls more than one sheet at the time and they get jammed. It does some noises that it did not do before. I come to the conclusion that the paper feeding mechanism is failing. Could it be repaired?
  • 40 Answers
Usually that problem occur when the paper pickup feed roller has run out.....and theres nothing you can do about it....but you can try to cleaning the paper pickup feed roller with the soft cloth and soap water...
Posted on Feb 04, 2009
Please describe your cannon laserbase 5630 showing paper check error after printing one print problem:
Hi mani4u58,
After the print,does the alarm indicator show?
Are the papers loaded and aligned in the correct way in the printers cassette?Please align them well and also note that the cassette can hold only around 250 sheets at a go.Remove the cassette completely when loading the papers and after paper load,insert the cassette as far as it can go.Does the printer feed paper correctly?If not,there may be a paper jam.To clear the jam,open the front cover by pulling it towards you.Remove the cartridge and inspect the compartment.Also make sure the orange adhesive tape around the cartridge is full removed to free its connections.You can also unplug the printer and leave it for a while and then plug it back to clear jam.
Hope it helps.Thanks!
Mar 27, 2011 | Office Equipment & Supplies
ERROR CODE E225
eror 225 relates to a paper jam. It might be a tiny tearoff, rather than a larger pice of paper.
Please rate my help++++Thanks for using FIXYA
Nov 29, 2009 | Canon LaserBase MF3220 All-In-One Printer
Continuous Paper Jam
Could try cleaning the peper feed rollers, may be debris on the feeders. Possibly could be damaged..
Rich
Aug 13, 2009 | Canon LaserBase MF5750 All-In-One Printer
Canon MF3220 jam paper?
Make sure to look for bits or tiny papers that is jammed on the printer. Sometimes, the sensors trace this as paper jam so you have to make sure that it is 100% clean.
Aug 04, 2009 | Canon LaserBase MF3220 All-In-One Printer
Constant paper jam after clearing and checking all areas
Don't put too much paper in the printer Try only having 10-50 sheets or so in at a time. These printerssay they can hold hundreds of sheets, but they can't without having a "jam".
If that isn't the problem, you should pull the paper back a few millimeters, to make sure you haven't pushed it into the internal print-area.
Some printers are sensitive to the thickness of paper that you insert. Try using a different grade of paper, and see if that works better.
Jun 23, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
ADF (automatic document feeder) constantly jams
change paper pick-up roller & paper stop roller in ADF
Oct 30, 2008 | Brother MFC-8840D All-In-One Laser Printer
The paper light is flashing
My printer is constantly getting jammed, spitting out blank sheets of paper in between every printed sheet, clicking and snapping, etc.
There are a few places to check for a jam - pull the paper drawer out and check there, take the toner cartridge out and you'll often find a sheet there that you cannot see from any other angle, open the little compartment at the back and check there and the usual paper sticking out of the output just enough to pull it out the rest of the way.
I'll be looking for a new printer this week though. I can't take the constant paper jams and sifting out the blank sheets when I'm printing 500+ statements a month.
Definitely NOT an office friendly machine!
Aug 20, 2008 | Lexmark E250dn Laser Printer
Pulls through too many pages at once
In the scanner where it pulls the paper in, there are rubber pads that hinder the paper feed from pulling more then one sheet. Those wear out and need to be replaced.
Feb 06, 2008 | Xerox DocuMate 262 Path-Through Scanner
Canon LaserBase MF3220 All-In-One Printer Logo
459 people viewed this question
old marine
old marine
Corne Viljoen
