Question about eMachines T6534 PC Desktop
EMACHINE T6534 COMP. WANT BOOT . TRYING TO CHANGE V-CARDS
OK,HERE GOES. I TOOK MY MEM. OUT AND CLEANED AND TRIED ALL 4 SLOTS NOTHING HAPPENED.I TOOK A OLD HD AND PUT IT IN. NOTHING, AND I HEAR THE HD RUNNING. I TOOK A OLD PWER SUP.(WITCH IT ONLY HAD 145 MAX OR MORE) THAT MIGHT NOT BE ENOUGH TO START IT?I HAVE A 300 MAX.I HOOKED MY OLD COMP.TO MY MONITOR AND KEY BOARD IT WORKED.WHEN I PUSH THE POWER BUTTON THE LIGHTS LIGHT UP ON THE KEY BOARD BUT WANT STAY ON.ALL THE FANS RUN GOOD AND STRONG.BUT THEY SEEM TO GET FASTER AND FASTER TO A CERTIAN LEVEL IS THIS NORM?I DIDNT TRY THE CD-DVD DRIVE NOT SURE IF ITS GOT ANYTHING TO DO WITH IT? I TOOK OUT THE BATT. AND TRY TO BOOT IT. I TOOK THE OLD BATT. OUT MY OLD COMP. AND PUT IT IN,NOTHING. I LOOKED AT THE PWR SUP. FOR BLOWN CAPPS ON THE CAPTRS. EVERYTHING LOOKED GOOD THE ONLY THING I HAVENT DONE IS TEST THE WIRES AND IM NOT SURE HOW MUCH VOLTAGE I AM GOING TO NEED? 5V? I NEED HELP.
  • 5 more comments
  • eakesj Feb 04, 2009
    THANKS I WILL CHECK IT. NOT SURE I WILL BE ABLE TO GET IT BOOTED TO CHECK BIOS.
  • eakesj Feb 05, 2009
    OK, I PUT MY NEW HARD DRIVE IN MY OLD COMP.AND HOOKED UP BOTH AND GOT IT TO WORK AND RECOVERD THE HD.I PUT IT BACK IN MY T6534 AND THEN I CHECKED THE POWER SUPPLY CONNECTORS. GOT LIKE .2VS AND THE LARGE ONE WAS 1.5VS. IT MIGHT BE THE POWER SUP.BUT WHY DO THE FANS RUN AND HD?I CHECKED THE CPU IT LOOKED OK . WHATS WIERED IS THAT I CAN UN PLUG MY CD/DVD AND THE TRAY WILL OPEN AND RUN THE CD AND WHEN I PLUG IT BACK IN THE MOTHER BOARD NOTHING HAPPENS THE TRAY WANT OPEN. IT JUST WANT BOOT UP. NOTHING ON THE MONITOR.
  • eakesj Feb 06, 2009
    OK, I TRIED SWITCHING RIBBONS NOTHING.I CHECKED THE VOLT'S. UNDER A LOAD ON ALL THE CONNECTORS. 12.11V,4.99V,3.5V'S. SO ITS NOT THE PSU. WHEN THE CD/DVD AND THE HD ARE PLUGGED INTO THE MOBO.THEY WANT WORK. WHEN I UNPLUG THEM FROM THE MOBO THEY WORK. ON MY OLD PC THE SAME THING HAPPEN,BUT I HAD THE RIBBONS IN THE WRONG SLOT. PULLED THEM OUT WITH THE PC ON AND SWITCH THEM AND BANG IT WAS WORKING. I WISH THIS WAS THE CASE ON MY NEWER ONE. IM NOT SURE IF ITS THE MEM. STICK? WOULD I GET SOMETHING ON THE SCREEN?
    THANKS,I DIDNT THINK OF PLUGGING UP THE SPEAKERS TO SEE IF I CAN HEAR A BEEP.I KNOW THAT IM NOT GETTING ANYTHING ON THE SCREEN.I HAVE ALREADY CHECK TO SEE IF IT WOULD RUN WITH THE HD AND CD/DVD PLUGGED AT DIFF. TIMES. I AM GOING TO HAVE TO ORDER A MEM.STICK TO TEST.SOMEONE TOLD ME TO GET A NEW SYSTEM.IT WAS THE MOBO.IF I CAN FIND A CHEAP STICK TO TEST. I WOULDN'T FEEL THAT I WAS TROWING MONEY AWAY. LETS HOPE THAT I HEAR A BEEP TONIGHT. I WAS WONDERING IF THE MEM.COULD CAUSE THIS PROBLEM.
    WILL DO. THANKS. IT WILL BE MONDAY WHEN I CAN GET BACK TO YOU.
  • eakesj Feb 09, 2009
    machadojr_fe,
    I HAVE THREE SMALL PLUG IN'S ON THE MOBO THAT GO TO THE PWR BUTTON.DIDNT WANT TO UNPLUG THEM TO CHECK VOLT.SEEM TO HARD TO FIND THE RIGHT WAY TO PUT THEM BACK.3 PLUG IN BUT 9 PINS. SOME TO LOOK LIKE RED AND RED WITH A WHITE CROSS. GREEN AND BLACK, AND SO ON. I DID UNPLUG ON THAT WENT TO THE PWER ****. THE COMP. WOULDNT COME ON. NOT SURE THAT THIS WILL HELP? BY THE WAY I HAD NO BEEPS. ONLY THE FANS CAME ON. WHEN I UNPLUG THE HD AND CD/DVD THEY STARTED TO WORK (FROM THE MOBO). YOU THINK IT COULD BE THE RIBBION SLOTS SHORTED OUT.OR THE MEM.?
  • eakesj Feb 16, 2009
    the new mem. stick did not work. i think its time for a new mobo. maybe it has a bad chip on the mobo?
  • 916 Answers
This could be a few things though if you have already checked the memory and HD. The next thing I would tell you is that you should check the cpu. Also make sure that everything in the BIOS is set to the default settings when you start it.
Posted on Feb 04, 2009
  • 3 more comments
  • machadojr_fe Feb 05, 2009
    Please try using a different ribbon cable on the cd drive going to the motherboard and switch to a different molex connector going from the power supply and see if you get the same problem.
  • machadojr_fe Feb 06, 2009
    If this was caused by memory you would either get a beep or see a error on the screen, if your mobo is not connected to a speaker on the case then if you have another stick that you know is working try that and see if the system boots if it does then the memory was bad. If it is still not working it could be one of the drives try just the HDD and just the cd/dvd drive to see if it starts with just one. If it starts with just one and not the other and then still does not start when the other one is the only one plugged in that one will be the cause of your problem.
    Yes the memory could cause this problem and you can find a cheap memory stick on www.newegg.com
    The problem is most likely not the MOBO if there is power going to anything connected to the MOBO check the voltage going from the power supply into the MOBO and then the voltage on the MOBO to the power button on the case if both are good then the problem is not the MOBO as it is supplying power to the components but could be a chip on the MOBO itself.
    Hook up the speaker and if you hear any beeps let me know how many times it beeps and how long the beep is and whether or not it is a steady beep.
    ok let me know the results
  • machadojr_fe Feb 09, 2009
    Ok if the fans and power button and even the drives are starting then it is not the MOBO. Check the memory if you have another module that you know works test it and see if it will post if it does you know it's a bad memory module. Please post the results once you do this.
    Also did you recently flash the BIOS? If you did check your jumpers you mave have accidentally left them in the flash position. Which erases the cmos. If you haven't yet please make sure the cmos battery is in place as well.
    If your memory is not the problem and the jumpers are set correct. We have checked your HD and PSU and CPU. So I would have to say you may have a bad ROM chip on your MOBO.
Acer desktp internal ram installation needed
I'm a bit confused....did you have all four of these in the ACER and are trying to put the 2x1GB into the Emachine? And that the 2x1 GB wouldn't work in the Emachine but they did in the ACER and that the 2x512 Acer cards worked in the emachine?
If that is what happened here is my best guess. The ACER MOBO will support 533/667/800 MHZ DDR2 RAM. The Emachine will only support 533 RAM. Iys possible the 2x1GB are either 667 or 800 MHZ and are not compatible with the Emachine but will work in the ACER.
Jan 23, 2012 | E-Machines T5082 PC Desktop
THe Emachines T6534 is not recognizing the monitor i have plugged in, thoguh the monitor is also emachines and i'm pretty sure it came with the computer
The problem could be with your Graphics card.
1) Try the monitor on another PC, is it good? If yes
2) Try removing and re-seating the graphics card.
3) If on board graphics and so no graphics card, try a PCI graphics card in one of the spare slots
Apr 06, 2011 | eMachines T6534 PC Desktop
Multimedia audio controller driver problem
here is a link to a help document:
http://downloads.emachines.com/drivers/audio/RealTek_Audio_5_10_0_5152_readme_en_em.txt
here is a link to the correct file. http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6534
Note this is for Windows XP
Oct 27, 2009 | eMachines T6534 PC Desktop
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
T6534 WANT BOOT UP. SYSTEM RUNS INSIDE.POWER SUP?
You power ratings are ok on the main power supply. But you should check the volts on the internal and see what is happening.
Feb 05, 2009 | eMachines T6534 PC Desktop
Comp not reading montor
It sounds like the on board video has failed. I would try installing a video card on the motherboard. Then in the bios at start up, disable the on board video, so it will use the video card instead.
I hope this helps and thanks for using FixYa,
Eric
Jan 25, 2009 | eMachines T6534 PC Desktop
EMachine T6534 Ram Issue
did you try putting 4 1g stick . instead 2 1g and 2 512?
Jan 16, 2009 | Computers & Internet
EMachines T6534 motherboard replacement
motherboard replacement is depending on your current processor, memory, and video card:
Verify this site for your processor and motherboard matching.
http://www2.amd.com/us-en/Processors/DevelopWithAMD/1,,30_2252_869_9460%5E9461,00.html
(Note: copy and paste the url to your internet browser address bar.)
may this help you.
melnavz
Oct 04, 2008 | E-Machines eMachines Desktop PC
Is there help for this dragon doesnt go on ive tryed video mem ?
This might be problem with your RAM. Remove the RAM and connect it to another memory slot or try changing RAM with new one.
Remove your PCI card and try now...
Sep 28, 2008 | Soyo i845 P4I Fire Dragon Pentium 4...
eMachines T6534 PC Desktop Logo
255 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
