Question about Amana ABB1927DE Bottom Freezer Refrigerator
Amana ABB1922 refrigerator - refrigerator not cooling
The freezer (bottom) is working fine. The fridge (top) is not cooling. Why is this? The unit is about 18 months old.
  • sid8 Feb 19, 2009
    I have the same problem. Top will only cool to about 45 deg. on max setting. Cleared ice from freezer wall, forced a defrost cycle and still will not cool. Fan is working and no blockage in duct, damper is fully open.
    Did the same about 12 months ago but running one forced defrost cycle seemed to cure it. I have the guide to run the service tests if anyone needs it.
  • Amana Master
  • 4,655 Answers
Check fan for operation and vent duct for ice or the damper sticking between the two compartments. It does not take much when the freezer is on bottom, colder air (because heavier) remains there without proper circulation. I will be trying to find the maintenance /service manual to help resolve this. JT
Posted on Feb 04, 2009
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Feb 05, 2013 | Whirlpool Refrigerators
Bottom freezer is fine but top refrig. is warm. Have vacumned bottom front coils, unit less than 2 years old. Any suggestions, other than calling repair? thanks.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | Amana AFF2534FE Bottom Freezer French...
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Hi, I have an LG refrigerator, the top freezer works fine but the fridge section has stopped cooling, I turned the unit off and next morning there was a large puddle of water on the floor, when I turned it...
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
Feb 15, 2010 | Refrigerators
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Nov 26, 2008 | Amana ABB1927DE Bottom Freezer...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Feb 21, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Freezer not working
there is a defrost fault - quite common with these hotpoint. fault could lie with the module or stats associated with defrost or possibly the heater itself. most probable is the module but impossible to localize by remote control. water drains away thro a hole in the centre of the tray underneath the evaporator
Jun 21, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Amana ABB1927DE Bottom Freezer Refrigerator Logo
496 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
