Question about HP Compaq dx2300 Microtower - RT950UTABA PC Desktop
CD STILL NOT READING
Thank, got the CD back. but there is an orange light on since. and the CD can still not be open itself. do u think it can be fix. i've uninstall it and install it back. but still no working. i've got my CD by using the PAPER. Nice that SYSTEM... DO U THINK MY DRIVER CAN WORK AGAIN?
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    I would consider replacing the CD drive .. They are not worth repairing ..
    Sergeant:
  • 219 Answers
It sounds like it is broken. It really is not worth getting it repaired as it would cost more than buying a new one.
I can help you install a new one. I just need to know one thing. Does your motherboard handle ATA and/or SATA? I can figure this out if I get the precise model number of your motherboard along with the manufacturer's name.
Posted on Feb 04, 2009
My door will not stay shut to play a game what is wrong.my ps2 door was not opening so we thought we fixed it but now it wont stay shut . all lights are on just wont stay shut to even read/play any games...
the tray doesnt stay in. does your ps2 sit on its side where the tray is sideways, or is it straight up? i think you should try rotating it to a point where it should stay shut.
Feb 11, 2010 | Sony PlayStation 2 (PS2) Console
New CDJ1000 MK3 freezing and then turning itself off
CDJ 1000 mk 3 freezing while playing tracks and sometimes freezes when a cd is inserted. The orange cue light comes on but the green play doesnt. Any ideas?
Thanks
Sep 25, 2009 | Pioneer CDJ-1000 CD Player
No power only plug light and battery light is on
The lights are indicators of which operation does your laptop operates.
1. Power indicator is lighten to green meaning you are in the mode of charging your power.and if the power indicator turns to orange meaning you are now using battery power or the charging is finished.
2. Reading indicator is blinking meaning your laptop is currently processing but if the Reading indicator is not blinking and made a static light then your system is in hang up or not reading the processes.
3. Wireless indicator is blinking or lighten then you are in the a wireless mode connection. Also the bluetooth and Infrared connectivity.
So please check which light indicator is lighten when you on your laptop.
Thanks
Aug 06, 2009 | Toshiba Satellite M115-S3094 Notebook
The lens opens and makes a ticking sound but light stay orange
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
Jul 15, 2009 | Olympus FE-210 Digital Camera
My '95 Geo Prizm's tail lights are out. The brake and hazard lights still work. I think it is a wiring problem and not the bulbs. I just want to know around how much it may cost to fix the tail lights.
Its crazy but my tail lights went out also and I could not afford to have them fixed but I can tell you how I fixed mine. If you pull the cd player out you have to connect the orange wire also called the dimmer switch the wire is solid orange connect it to the red fire wire that you use to power the cd player and everytime you turn on the ignition switch the tail lights will come on but when the switch is off they will go off.
Jul 07, 2009 | 1995 Geo Prizm
Has it got wireless function
I have one of these.
There's an on/off switch on the right hand edge of the laptop, with an orange light, between the dvd and the floppy drive.
The wireless card itself is a mini-PCI affair which can be fitted under one of the smaller panels underneath (you'll have to unscrew the cover, but it just slots in). There's a yellow label about interference on the panel.
As far as I know, you can only get "wireless b", or IEE 802.11b standard mini-PCI cards for this laptop. I say "only" because I wasn't able to get a connection on mine unless I stood with the laptop in view of the base station, and it's very slow compared to "wireless g" (802.11g).
Good luck.
I'd really like to know how to boot up my toshiba with the recovery dvd, by the way.
I think my drive might be physically broken.. I've set it to boot from dvd first, but when i put a blank formatted hard drive in it, it still says NTLDR is missing press ctrl+alt+del whether i put the cd in or not. Also, the dvd light is on all the time, but it flashes when its thinking about reading the cd.
any ideas ? please write to chinchilla_g03@yahoo.co.uk
thank youuu
Sep 06, 2008 | Toshiba Computers & Internet
Stanton C304 Single Top... Problem
i had the same problem on the c303. ended up sending it to FL for fixing. when i got it back it worked fine for a few days then other issues such as not reading disc. unfortunately i could only recommend another manufacturer since this one seems unreliable.
Aug 22, 2008 | Stanton C304 Single Top Loading CD Player...
Kenwood KDC 7024
Some flip face stereos use a tiny micro switch to tell the onboard computer when the face is down or up and sometimes it uses the same switch for both positions sensing. It could be this switch is not working properly (dirty contacts, broken, bad wire, mis-aligned, etc.) and that is causing the problem. Good luck.
Feb 12, 2007 | Kenwood KDC-7024 CD Player
HP Compaq dx2300 Microtower - RT950UTABA PC Desktop Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
