Question about DFI INFINITY NF4X Motherboard
Dfi infinity freeze at logo screen
Hi, i'm trying to flash my dfi infinity nf4x bios. but after restart it freeze at logo screen. can't even go to bios. i've try restart cmos,but still the same.
any suggestion??
sorry for my bad english
  • 1,602 Answers
There is a jumper on the motherboard for that perpose, should reset on it 3 jumper it is alway on pins 1-2 move it to 2-3 for a few secound and than move it back and reboot system
rod
Posted on Feb 04, 2009
Where can I find the drivers for Windows 7 ?" DFI NFII Ultra"
Hello my friend,is very old motherboard and i couldn't find and i don't think that there are drivers for windows 7.The only think you could do is to try this motherboards XP drivers or better your motherboard`s windows XP sound drivers.
Feb 05, 2010 | DFI NFII Ultra INFINITY Motherboard
DFI infinity wont post
Hi...
When your computer continuos beeping the problem is the RAM you need to open the CPU casing and check the remove the RAM clean the dust then after that, reinsert the RAM to the socket, then turn on your computer. "good luck".
Regards
PCmania
Jul 13, 2009 | DFI NF4 INFINITY Motherboard
Bios actualization
Click on the DFI link below;
http://www.dfi.com.tw/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=biosTab&windowstate=normal&mode=view&downloadFlag=true&itemId=228
Everything you need is on the site. Just follow the instructions on the site.
Thanks for using FixYa!
Mike
May 25, 2009 | DFI AD77 Pro Motherboard
I need the drivers for this motherboard
Have you tried givemefile.net?
go to :
http://www.givemefile.net/search.html
copy the line below into the search line, and that should bring up all the drivers you need.
INFINITY MOTHERBOARD DFI 865PE
Apr 26, 2009 | DFI 865PE INFINITY MOTHERBOARD P4/A&GB...
DFI NF4 INFINITY MOTHERBOARD NON BOOT
sounds like a hardware problem. try unplugging all external devices including keyboard and mouse but not monitor. test if it works. if not, open the side of the case and remove the little battery found on the flat motherboard for 30 seconds. then slide it back into place. now try to see if it works. if still nothing, check to see if there are motherboard jumpers (they will be 2 tiny pins on the board with a clamp over the top of them, you probably wont find them), if you see the jumpers, move the clamp to the spot that says "clear cmos" then put it back. or if your motherboard has a clear cmos button on the board, press it and try the computer. if it still will not boot, it could either be the flat IDE cable (for a hard drive or cd drive) or the power supply which means you will need to purchase either a new power supply or ide cable. if all still fails, i would say the motherboard is shot.
Feb 25, 2009 | DFI NF4 INFINITY Motherboard
DFI Infinity NF4 SLI won't start
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
Jun 28, 2008 | DFI Computers & Internet
DFI INFINITY NF4X Motherboard Logo
239 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
