Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Oil leaking craftsman 9hp snowblower is leaking oil by oil drain pipe by the block or block its self. only 11 months old
4 Suggested Answers
trippssmengi
  • 76 Answers
SOURCE: tecumseh 9hp craftsman snowblower will not stay running
First take the carb off of the engine and then remove the bowl, carefully take the float off paying special attention to the needle and how it is attached to the float. Next, lightly blow air into the fuel inlet while holding your finger over the spot where the needle goes in. Use a bread tie with the paper scraped off. Stick the wire through the pick up tube at the bottom of the carb. Find any other holes and probe those holes with the wire. Then thoroughly wash the entire carb with carb cleaner then blow the whole carb off. Then put the float and needle back in making sure that when putting the bowl back on that it seats tightly all the way around the rubber gasket. Also, just before you put the bowl on turn the carb upside down to see if the float is sitting level. If it is put the bowl on, If not then the spot where the needle sits on the float has to be bent one way or the other just a little until the float sits level. After the bowl is put in place, the nut that holds the bowl on the threaded area should have two possibly three holes plus the hole down the center, probe all holes with the wire. put everything back on the motor and try again. If it still won't run then you will need a carb kit.
Posted on Dec 27, 2008
wireguy212
  • 1627 Answers
SOURCE: My Craftsman 26
You likely have it in one wheel drive,try lifting the rear wheals of the ground to check and see if both wheels tirn at the same speed.If they don't then you need to change the wheel that is not turning into a drive wheel by removing the pin and putting it back in in the lock position[usually the next hole back in the axle].
Posted on Jan 08, 2010
geterrollin
  • 277 Answers
SOURCE: I have a Craftsman 9hp snowblower and it is not
It is belt driven, the belt is located between the chute and the engine behind the inspection cover some have it on the top and some on the bottom.That model may have to be split in half to get the belt past the shaft.But regardless it can at least be inspected by taking the cover off.Please let me know if this helps
Posted on Jan 19, 2011
Model # 627804x79a. Spirit snowthrower. How much oil does it take?
what does the manual tell you about engine oil
Nov 24, 2015 | Garden
Oil leak craftsman snowblower
Only a few places to leak oil from, Main crankshaft oil seal, Oil fill cap, valve cover gaskets, Cracked engine block, Engine Block gasket (some blocks split apart)
Mar 08, 2015 | Cars & Trucks
Craftsman snowblower will not kick over
Old gas? Did you pull out the spark plug and see if you have a spark? If the gas is old, drain the tank and line to the carburator, then put in fresh gas. Never put it up for the summer with gas in it. Run it until the engines runs out of fuel, then put it away.
If there's no spark, then you have a coil issue.
Nov 21, 2013 | Craftsman Snow Blower / Snowblower Bottom...
My 9hp sears snowblower doesnt through snow anymore and the belts are fine. I have tried tightening the cable for the auger lever with no success. Is there a friction plate to change ??
Usually on the bottom of those there is a scraper plate on the bottom behind the auger this is made to wear out check to see if needs replacing.
Mar 09, 2011 | Craftsman Garden
How would I drain the oil from my craftsman 8.5 26 snowblower, model 536.886190
There should be a oil drain at the bottom of the motor.it should be a plug at the base of motor or below the oil fill.
Nov 19, 2010 | Garden
Have a 1999 eclipse 2.0 L...Need to replace oil pan. Do I have to remove any other parts to get the pan off
2.0L Engine
  1. Disconnect the negative battery cable.
  2. Drain the engine oil.
  3. Remove or disconnect the following:
    Engine undercover Front exhaust pipe Lower oil pan bolts and lower pan Cover Upper oil pan bolt and upper pan Baffle plate
    0996b43f8023193a.jpg Fig. Oil pan and related components-2.0L engine
To install:
  1. Clean all gasket surfaces of the cylinder block and the upper and lower oil pan.
  2. Install or connect the following:
    Baffle plate
  3. Apply a 0.16 in. (4mm) bead of sealant to the gasket surfaces of the upper oil pan.
    Upper oil pan onto the cylinder block within 15 minutes after applying sealant. Tighten the bolts as shown in the accompanying figure.
    0996b43f8023192d.jpg Fig. Upper oil pan bolt location and torque sequence-2.0L engine
  4. Apply 0.16 in. (4mm) bead of sealant to the gasket surfaces of the lower oil pan.
    Lower oil pan and tighten the bolts, in the sequence shown, to 88-106 inch lbs. (10-12 Nm)
    0996b43f8023192e.jpg Fig. Lower oil pan bolt tightening sequence-2.0L engine
    Front exhaust pipe Engine undercover Oil drain plug with a new gasket and tighten to 29 ft. lbs. (40 Nm)
    0996b43f8023192f.jpg Fig. Make sure to the install the new drain plug gasket as shown, or leaks will occur
  5. Lower the vehicle and fill the crankcase to the proper level with clean engine oil.
  6. Connect the negative battery cable. Start the engine and check for leaks.
Non-Turbo Engine
  2. Raise and safely support the vehicle.
  3. Drain the engine oil into a suitable container.
  4. Once the oil has completely drained, install the plug and tighten to 25 ft. lbs. (34 Nm).
  5. Remove the front exhaust pipe.
  6. Remove the engine oil dipstick and tube assembly.
  7. Remove the front plate.
  8. Unfasten the oil pan mounting bolts, then remove the oil pan and gasket.
    0996b43f80222121.jpg Fig. Exploded view of the oil pan and related components-1999 2.0L non-turbo engine
To install:
  1. Apply sealant at the point where the engine block meets the oil pump.
  2. Use a new gasket and install the oil pan. Tighten the mounting bolts to 8.9 ft. lbs. (12 Nm).
  3. Install the front plate.
  4. Install the front exhaust pipe.
  5. Install the dipstick and tube assembly.
  6. Safely lower the vehicle to the floor.
  7. Refill the crankcase with oil to the proper level.
  8. nnect the negative battery cable.
  9. Start the engine and check for leaks.
Turbo Engine
  2. Safely raise and support the vehicle.
  3. Remove the front exhaust pipe.
  4. Remove the exhaust pipe and muffler assembly.
  5. Drain the engine oil into a suitable container. Once the oil has drained completely, tighten the plug to 29 ft. lbs. (39 Nm).
  6. Remove the dipstick and tube.
  7. For AWD vehicles, remove the transfer case assembly as follows:
    1. With the propeller shaft still installed, remove the transfer mounting bolt.
    2. Insert a suitable prytool in between the transfer case and transaxle, then remove the transfer case from the center shaft.
    3. Remove the transfer case from the center shaft. Do NOT tilt the transfer assembly to the rear or oil will leak out.
    4. After removing the transfer assembly, insert tool MB991193 or equivalent, to prevent the oil from leaking out. Use a piece of wire to suspend the transfer case from the body.
      Fig. View of the transfer case with the tool installed to prevent oil from leaking out-1999 2.0L turbo engines
  8. Remove the bell housing cover.
  9. Disconnect the oil return pipe from the oil pan.
  10. Remove the oil pan mounting bolts. Tap the oil pan seal breaker MB998727 or equivalent between the oil pan and the engine block to break the seal and remove the oil pan.
    0996b43f80222123.jpg Fig. Exploded view of the oil pan and sealant application-1999 2.0L Turbo engine
To install:
  1. Clean the sealing surface on the oil pan and engine block. Apply a continuous bead of sealant MD970389 or equivalent to the oil pan.
  2. Clean the oil pan mounting bolt holes in the oil seal case.
  3. Install the oil pan to the engine block. Tighten the mounting bolts to 5.1 ft. lbs. (6.9 Nm).
  4. Use a new gasket and connect the oil return pipe to the oil pan.
  5. Install the bell housing cover.
  6. If equipped with AWD, install the transfer case assembly.
  7. Install the dipstick and tube assembly.
  8. Install the front exhaust pipe.
  9. Install the exhaust pipe and muffler.
  10. Install a new oil filter.
  11. Safely lower the vehicle to the floor and add five quarts of oil to the crankcase.
  12. Connect the negative battery cable.
  13. Start the engine and check for leaks.
Good luck (remember rated this help).
Mar 06, 2010 | 1999 Mitsubishi Eclipse
My Craftsman 26" 9HP snowblower pulls to the left. Any ideas?
Jan 07, 2010 | Craftsman 16" High Garden Tractor Snow and...
9hp briggs and stratton engine has gasoline in the engine oil
Old gas, gone bad from sitting. Drain all gas out and use carb cleaner in unit to clean. Add fresh gas.
Oct 01, 2009 | Coleman Powermate Powermate 5000W...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
109 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
