Question about Canon PIXMA MP830 All-In-One InkJet Printer
Printer reads no paper, when I have envelopes or cards .
When i try to print envelopes or cards that are smaller than 81/2 by 11, the cassette or auto-feed both read there is no paper. I have set all the info on custom or whatever size is appropriate...what am I doing wrong.
...soooo frustrated!
  • 3 more comments
  • ruth waltman Feb 04, 2009
    I am not using vista as the operating system.
    where do I find auto-size? There is no such setting on my printer under settings
    it will feed the envelope but the printing is cut off.
    I have done all of that. The problem is the envelope is 6 inches high by 9 inches wide. If I move the envelop to where I think the return address will print, it states no paper. If I move the envelope to where it is supposed to go in the paper feeder, it cuts the return address off.
    President:
  • 2,559 Answers
When you start to print Choose Page Setup.(Not just print) Displays a modal dialog box that allows the user to set the following attributes of the printed page:
  • The paper type (envelope, legal, letter, and so on)
  • The paper source (manual feed, tractor feed, sheet feeder, and so on)
  • The page orientation (portrait or landscape)
  • The width of the page margins
The following illustration shows a typical Page Setup dialog box.(Change the size to what you want).Change source if needed,
Printer reads no paper, when I have envelopes or c - ffa97b4.png If you clicks The ptPaperSize and rtMargin contain the values specified by the user. These structures contain additional page information as well as information about the printer. You can use this information to prepare the output to be sent to the selected printer.
If the user cancels the Page Setup dialog box or an error occurs, PageSetupDlg returns FALSE.
Posted on Feb 04, 2009
  • 15,935 Answers
Check your printer's settings In CONTROL PANEL.
The paper orientation, media type, and size should be in there.
Also be sure the paper feed tray is set up properly.
CLICK HERE to access your user manual if you do not have it.
Thank you for using FixYa - a FixYa rating is appreciated!!
    Master:
  • 848 Answers
  1. Click on the Mailings tab. (If using an older version of Word, click the Tools tab, then select Letters and Mailings.)
  2. Select Envelopes (if using an older version of Word, Envelopes and Labels). Enter your delivery address, and if you like, a return address in the appropriate field
  3. Select Options to choose a font, and select an envelope size from the drop down menu. (Check your envelope packaging for exact sizes). If your size is not available, select Custom Size and enter your dimensions.
  4. Insert your envelope into your printer’s document feeder the same way you insert paper. Most printers will indicate which way to insert your envelope with an illustration on the document feeder (vertically vs. horizontally, face up vs. face down).
Before printing, follow these additional tips to avoid paper jams and other printing mishaps:
  • Check the packaging to be sure your envelopes are compatible with your printer.
  • Avoid printing on envelopes that are loosely constructed, as they can get caught in your printer or document feeder.
  • Do not try to print on envelopes that have clasps, strings, or buttons. Hand address or use labels instead.
  • If you’re printing a stack of envelopes, stack them loosely to avoid a jam.
Most printers have built-in support for popular envelope sizes. Some even have special trays for feeding envelopes. If your printer has an envelope tray, be sure to enable the "load from envelope tray" option in the print dialog box before printing.Click Print to print a test envelope. If you find that your settings are incorrect, click on Printing Options to choose a different feed method.
    Sergeant:
    Champion:
  • 289 Answers
Hi..Make sure that u have switched on
to auto-size option.To select this option
go to settings and look in the preferences
option.Selecting this will solve the issue.
try it out..
thank u..
  • Hariharanath V Feb 04, 2009
    hi..this setting should be changed in
    ur printer software setting.This is not
    related to operating system.
    thanks..
    hi..go to properties,then select paper quality,
    there u will get a option as size,it lists u
    with various size option.From that u can select
    your size according to ur wish.
    try it out..
    thanks..
  • 916 Answers
What operating system are you using? If you are able to re-set the sizes in the print and printer menus and you are using Vista, Vista does not recognize that you have set a custom size envelope, therefore, you are not able to print it. Try a menu pick size envelope in the print properties on your computer, then let me know what happens.
  • Canon Master
  • 13,433 Answers
Hi if you set the correct size on the printer itself it should print fine.
  • Ekse Feb 04, 2009
    First open the paper support tray, then pull out the extension
    pinch and slide the paper guide to the left
    Prepare the envelopes for loading
    a Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
    b Remove any curling by holding the edges diagonally and bending them gently.
    c If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
    d Ensure that no curl or puff exceeds 1/8 in. (3 mm).
    Place the stack of envelopes (print side up) in the ASF and pinch the paper guide and adjust it to the left side of the stack
    Load the envelopes in the ASF with the short side down.
    Pinch and slide the paper guide to the envelope's left side.
    press the open button
    ensure the asf light is on
    make the appropriate printer settings
    # Media Type : Envelope
    # Page Size: Select either DL Env. or #10 Env. according to the envelope size you are using
    # Orientation: Landscape
You must have a record. hp p1006 printer envelopes hang in print que. I have spent many hours with your staff and the problem hasn't been solved?
Envelpopes should be printed using the feed tray located in the front of the printer not through the paper cassette. Try this: Follow these steps to print on envelopes from a computer running Windows. NOTE: For specific details on formatting text for printing on envelopes, consult the help files in the word processing software. For best results, consider using a label for the return address.
  1. Click File , and then click Print . The Print dialog box opens.
  2. Depending on the software program, click Properties , Options , Printer Setup , or Preferences . The printer Properties dialog box opens.
  3. Click the Paper/Quality tab.
  4. Select Envelope as the paper type.
  5. From the Size drop-down list, select the applicable size. To create a custom size envelope, use the following steps:
    1. On the Paper/Quality tab, click Custom .
    2. Click in the Name text box, and then enter a name for the custom envelope size.
    3. Click in the Width text box, and then enter the width. NOTE: Make certain the size is in inches. Click the Use Millimeters/Use Inches button to toggle between using millimeters and inches to define the custom paper size.
    4. Click in the Height text box, and then enter the height.
    5. Click Save .
  6. Click Apply to save the settings.
  7. Click OK to print the envelopes. NOTE: An error message might display asking to load an envelope into the manual feed tray. This might occur even if the envelopes are loaded. Make sure the envelopes are loaded, and then click Continue . The product will continue printing from whichever input tray contains the envelopes.
Dec 17, 2010 | HP LASERJET P1006 Printer
The printer prints the paper out to the side and then causes a paper jam
As the following paper may cause problems in the printer, do not use them:
- Thick paper: Paper heavier than 105 gm2 (28 lb) (corrugated paper, etc.)
- Thin paper: Paper lighter than 64 gm2 (17 lb) (tracing paper, thin letter paper, etc.)
- Paper with no rigidity
- Folded, wrinkled, or torn paper
- Wet or soiled paper
- Paper smaller than 54 mm (W) x 86 mm (H) (2.13" x 3.39") (sheet feeder)
- Paper smaller than 89 mm (W) x 127 mm (H) (3.50" x 5.00") (cassette)
- Non-rectangular paper
- Paper with adhesives
- Paper with holes (However, loose leaf can be used in the sheet feeder only.)
- Paper in bound form (such as a notebook)
- Photo postcards or postcard with image seals
- Non-empty envelopes
- Envelopes with double flaps or flaps with adhesive
- Embossed or coated paper, post cards, and envelopes
- Newspaper, flyers, tissue paper, etc.
- Media other than paper, such as cloth and plastic
- Folded reply post cards
Oct 26, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
Jul 06, 2010 | Canon LASER SHOT LBP 3300 Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Machine flashing load paper message even though paper is loaded
Hi ...
Most of the time this problem comes when the paper is not loaded correctly. Follow the below instructions to load papers to the cassette and I am sure this will resolve your problem. I will keep monitoring your responce and if required, i'll look for a work arround.
Follow this procedure to load paper / envelope in the cassette:
  1. Pull out the cassette from the machine.
  2. Remove the cover from the cassette.
  3. Fan out the sheets of paper so that they do not stick together.
  4. Align the edges of the paper.
  5. If the cassette is not yet extended, use your thumb to press the tab (indicated by the pink circular outline) and release the latch.
  6. After the latch is released, remove your thumb from the tab. Then extend the cassette until a click is heard.
  7. Load paper on the upper-right corner of the cassette with the print side facing down.
    Note:
    * Since the Credit Card sized paper, Canon Photo Stickers, and Legal sized paper cannot be fed from the cassette, load them in the auto sheet feeder (ASF).
    * When loading A5 or larger sized paper (nonstandard-size paper: 203mm / 8inches or more in length), extend the cassette by pinching the tab.
  8. Grasp the paper guide (A) and align it to the long edge of the envelope stack (2). Align the front edge of the paper stack in the same way (3).
  9. Close the lid and push the cassette all the way into the printer.
  10. Press the <Open> button and pull out the extension completely.
  11. Press the <Feed Switch> button to turn on the Cassette light.
    *MP500 shown.
    Note:
    If the Auto Sheet Feeder lamp lights, press the Feed Switch button to light the Cassette lamp.
    If the Cassette lamp does not light even after pressing the Feed Switch button, Paper Source in the printer driver may be set to the setting other than the Feed Switch button.
Loading on envelopes
Paper Type
Precaution
Envelope (DL / #10 )
Set paper with the flap closed.
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
  5. Load envelopes in the cassette with the print side facing down and the flap towards the left.
  6. Close the lid and push the cassette all the way into the printer.
  7. Press the <Open> button and pull out the extension completely.
  8. Press the <Feed Switch> button to turn on the Cassette light.
    Note:
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
What thickness of card can my canon ip4000 printer print onto
and the answer is:
standard paper: from a5 size (148.0 x 210.0 mm / 5.83 x 8.27 inches) to legal size* (215.9 x 355.6 mm / 8.5 x 14.0 inches)
* legal-sized paper is not loadable in the cassette.
bullet_s.gif non-standard paper: from 54.0 x 86.0 mm to 215.9 x 584.2 mm (from 2.13 x 3.39 inches to 8.5 x 23 inches) in the sheet feeder; from 89.0 x 127.0 mm to 215.9 x 297.0 mm (from 3.5 x 5 inches to 8.5 x 11.69 inches) in the cassette.
bullet_s.gif others: envelopes (european dl and us com. #10)
important
do not use the following types of paper. using such paper will not only produce unsatisfactory results, but can also cause the printer to jam or malfunction.
bullet_s.gif folded, curled, or wrinkled paper
bullet_s.gif wet paper
bullet_s.gif paper that is too thin (less than 64 gsm / 17 lb)
bullet_s.gif paper that is too thick* (more than 105 gsm / 28 lb)
bullet_s.gif picture postcards
bullet_s.gif postcards affixed with photos or stickers
bullet_s.gif envelopes with a double flap
bullet_s.gif envelopes with sticker flaps
bullet_s.gif envelopes with an embossed or treated surface
bullet_s.gif any type of paper with holes (loose-leaf paper is an exception; it is printable when loaded from the sheet feeder.)
* non-canon branded paper
Hope this does it for you, please -please leave a rating...thank you kindly
May 07, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Need to print a half-fold card envelope with HP Photosmart C4480
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Feb 15, 2009 | HP Photosmart C4480 All-In-One InkJet...
Printing envelopes
HI,
Try this one.Make sure the HP paper size setting needs to be "plain paper," not "automatic.
Aug 17, 2008 | HP Photosmart 3210 All-In-One InkJet...
Print Size
you have to choose the paper type in the printer driver option wheather envelope or A4 paper see the preview before printing
Mar 22, 2008 | HP Deskjet 3915 InkJet Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
65 people viewed this question
old marine
old marine
