Question about Life Science Life Source Blood Pressure Monitor Ua-767pv
Life source 767 monitor does not work
When I try to take my blood pressure the unit cuts off and displays the words ERR 3
  • Anonymous Mar 23, 2014
    where can i get a mmanual for Life brand smartlogic blood pressure machine Model # 5534
    how can i find manual for my smartlogic blood pressure monitor (Life brand) model #5534
  • 50 Answers
The cuff sensor must be placed directly over the vain in order for it to pickup the beat. This takes a little practice
Posted on Feb 06, 2009
My monitor pressure life source UA 767 show in display error cuf , what mean thats error
The Err CUF probably means that the blood pressure cuff isn't properly arranged on the arm. Check that the cuff is around the upper arm 1-2 cm above the elbow. The hose should be near the center of the elbow. Make sure that a rolled up shirt sleeve is not too tight. Next check that the indicator arrow is in the correct range when the cuff is firmly fastened.
Make sure that you are using the correct cuff for the user. There are different blood pressure cuffs (medium, large, wide-range) available for some blood pressure monitors. If the arrow doesn't line up in the indexed range, use a different blood pressure cuff for the unit.
I hope this helps. I used the information about the A&D Medical UA-767 for some of the trouble-shooting details. See and click on the Downloads tab to see the manual for this model. (I suspect the Life Source and A&D Medical products are extremely similar.)
Nov 21, 2017 | Health & Beauty
I question the accuracy of my Life Source model
Find Biomed tech such as one at hospital. You do not have specialized cal equipment to do it.
Sep 07, 2014 | Health & Beauty
Err code 3
From manual at pag.3:
err code 3Appears when pressure value did not increase during cuff inflation: 1) cuff is not fastened 2) air connector is not connected properlMake sure cuff tube is properly connected to monitor, cuff is securely fastened and exhaust rate is between 2 mmHg and 5 mmHg. Make sure air connector is inserted properly into tube and monitor.
refer to manual
Mar 05, 2012 | Lifesource UA 767 Plus Digital Blood...
Get directions on life source 767 monitor
Would suggest you try looking in the manual section of
Feb 25, 2011 | Life Science Life Source Blood Pressure...
Life source ua 767 plus set time &date
On my unit, on the lower left side, underneath where the grey hose attachs to the unit, there are two buttons that blend in with the white plastic body. One button has an icon of a clock at the 3 O'Clock position and the one next to it has a triangle on it. Press and hold the clock button. 4 seconds the display flashes the year, hit the triangle shape button to advance the year, then hit the clock button again, Month, day, hour, minute. Hit the clock button to advance to the next item, hit the triangle shape button to advance the item you are on to the proper date/time.
Feb 20, 2011 | Life Science Life Source Blood Pressure...
My lifesource ua-767 displays err 3 is it the cuff or the machine
Turn it over tap little black gauge above battery cover with fingers turn on, err 3 code normally resolved.
Sep 25, 2010 | Lifesource Ua 767 Blood Pressure Monitor...
Walgreens HD303 Blood Pressure Monitor error 3
Possible explanations and work-arounds based on various blood pressure is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Apr 08, 2010 | Walgreens Wrist Blood Pressure Monitor
Err 3 is displayed
Wrist blood pressure monitors must be used with the arm above heart level. You can do the pledge of allegiance while doing a reading to make sure this is done. Usually this error occurs when inflation takes too long or the placement of cuff is wrong.
Sep 10, 2009 | Walgreens Wrist Blood Pressure Monitor
Life Science Life Source Blood Pressure Monitor Ua-767pv Logo
833 people viewed this question
Top Life Science Health & Beauty Experts
Tom Chichester
Are you a Life Science Health and Beauty Expert? Answer questions, earn points and help others
