Question about New World E70DOa Electric Double Oven
Halogen hotplate will not turn down
Got a creda edhw61 will only work on high even when you turn it down
  • New World Master
  • 3,463 Answers
You need to fit a new regulator that controls the hotplate, as the other one is faulty.
Please rate my fixya solution.
Thanks
Posted on Feb 04, 2009
What can I do about the hobs overheating - when on, they are only on the highest heat and can't be turned down.
THE only solution is to replace the regulators that control the hotplates.
Could prove to be expensive.
Mar 01, 2015 | Belling Ovens
Hotplate and oven temp
There are several possibilities. Make certain your fuse at the main electrical box is correct for a 220VAC line. You do not want to OVER POWER the range. If that is normal, check all cords for insulation and flexibility. Check thermostat controls on the burners and/or oven.
If parts are normal, the only thing you can do is manually set temps lower when using the oven. Glass tops generally stay hot for several minutes after they are turned off. That is Normal, for example, to avoid Glass from fracturing; temperature slowly declines. Lastly; if all is lost, call for a serviceman to check it out, as you do not want a house fire.
Jan 11, 2018 | Ovens
Back right hotplate getting hot when oven on
That hole is most likely a vent for oven where some heat escapes.
Nov 10, 2017 | Hotpoint Ovens
Creda problems
Hi, if there is no regulation on the hob, it is typically the switch that is faulty unless halogen, then it could be the thermal cutout.
warmest regards
Richard The Repairman Colchester Oven Cooker Washing machine repair
Mar 30, 2014 | Creda Ovens
I have problems with my Hotplate!!!!! Name of the hotplate is just Induktion. The Hotplate is a Induktion and after a moment of heating it starts to blik and shots down with the Error: E R
From my previous mechanical engineering work, and have maintained a few of similar problems, but different maker. I found one one thqat it was not properly wired, check the owners manual and go over wire diagram. Secondly, is the kitchen on the other 2 I did the breqaker for that room was way over loaded, and sometimes it will shut your equiptment down b3efore the breaker goes off. This is because when the element reaches a certain tempature, or even rising in tempature the stove will kickback, almost like a car going into safemode, so it does not destroy the stove. I had to call an 3electrician, because3 I am not a certified elec.
Dec 26, 2012 | Ovens
Our Simpson Esprit hob has terrible heat control. We are burning everything, even on low because the temp is too hot, but then when we try and boil pasta on a high heat we cant seem to get it even to...
I am assuming the cooktop is electric. Are the hotplates the solid type, coil type or beneath the glass. Are these new to you or have you been cooking with these for a long time?
Mar 06, 2011 | Ovens
Where is the thermostat located in the main oven of my Creda Europa Solar oven. Thanks
Depends which thermostat you are referring to.
Thje main oven stat is on the control panel, and is marked with the temp, the sensor being located at the top rear of the oven compartment.
The other stats are located at the top of the oven outer casing under the the top cover. you need to remove oven from housing to access these.
Oct 29, 2010 | Creda Europa E010E Electric Single Oven
Hotplate on ceramic cooktop not working, another won't turn down.
If 1 of the plates is not working at all, then it is going to be the plate itself, or a faulty regulator, you will have to take it apart to check the plate.
The other plate that you cannot control, needs the regulator replacing.
Mar 25, 2010 | Ovens
Hi.i have a hotpoint creda c362e cooker the rings work grill works but main oven and top oven elements dont come on even when lights come on when switched on fan works but no heat could you help me on this...
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Jan 09, 2010 | Creda Ovens
New World E70DOa Electric Double Oven Logo
204 people viewed this question
Top New World Ovens Experts
Paul Carew
ashburton
Are you a New World Oven Expert? Answer questions, earn points and help others
