Question about Eemax EX120TC 11.5kW 240V
My eemax ex120tc 11.5kw 240v the water does not get hot enough.
One of the lights just flickers.
  • bigslimaba May 11, 2010
    Send some more info on the prob what you wrote got cut off. These are normaly a simple fix let me know
    Scholar:
    New Friend:
  • 70 Answers
You can check elements with a meter to see if they are any good. how old is heater?
Posted on Feb 09, 2009
I have a Eemax so 35 instant water heater and it makes a buzzing noise when you turn the hot water on
Heavy current required for instant hot water may be switched via a relay or contacter which may be faling. One way to diagnose may be with cover off and careful listening and visual inspection, but a risky process for inexperienced DIY'er's ??. Pro time?
Apr 11, 2017 | Eemax Water Heaters
How do you adjust the temperature on a model SP 3512
Check if thers incoming water. Ur heater dependent on the level of water
Sep 15, 2014 | Eemax Instant Water Heater 120V SP3512
Eemax280t2t no hot water
see if the circuit breaker switch has tripped either partially or fully and reset it. Check for bad or loose wiring on the heater and breakers. The next thing is more likely the heating element is no good and needs repaired or the heater needs replaced.
Jan 30, 2014 | Eemax Water Heaters
Wher does white wire go on ex 190 eemax water heater
It runs off 220v, meaning there are two "hots" and a ground. The 190tc uses TWO sets of 220v at 40amps each. Instead of only having one dbl throw breaker, you need 2. Having said that... the white wire "should" be the same as the black wire and can be connected which ever way you like
Jan 17, 2011 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
My house has 200 AMP Service, will this work ok with the EEMAX EX380T2T2? It requires 4 40AMP Breakers.
your water heater will take a 160 amps of you service. I would not install one if it was me. The total demand in the dead of winter with furnace, water heater and lights on will cause you to brown out.
Oct 05, 2010 | Eemax EX380T2T2 Series 4 Whole House...
Can the board be changed easily on the ex 120 tc or do i need an electrician?
If you have the parts, replacement is a no brainer. Take few pictures with your digital camera or label the wires before you start
Feb 12, 2010 | Eemax EX120TC 11.5kW 240V
Takes longer for water to get hot at sink and shower and bath tub does not get hot.
The boiler temperature setting is kept at a position lower than you need. Go to the boiler. There will be a small box with a knob. The knob generally has 3 settings marked. Cold or Vacation, warm and Hot. If you inspect it closely you will also see a rd dot marked on the body. If my guess is right, the red mark and warm align in your case. Turn the knob a little towards the hot. However, test your setting after a little time and adjust to the best setting that suits you.. If your temperature controller is in good working condition, water could get really hot. So, tely everyone in the house that you have changed the setting to hot. Other wise you know, severe scalding could occur. If this did not work you may need to change the thermostat. The element seems to be work because the water is heating up at least a few degrees.
Jan 22, 2010 | Eemax EX144TC 15.0kW 240V
No hot water
in and out hooked up right?
May 17, 2009 | Eemax EX280T2T Series 3 Whole House...
Eemax EX120TC 11.5kW 240V Logo
400 people viewed this question
Top Eemax Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you an Eemax Water Heater Expert? Answer questions, earn points and help others
