Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Error code C-D251
Does any one know how to fix this?
    Sniper:
  • 62 Answers
Hi, the definition of CD251 is
• JPEG board (Scan accelerator kit) is not mounted when the JPEG board mounting is set ON at
Service Mode.
Has this mode been turned on even though no Scan Accelerator board has been fitted?
It's an unusual code to get. Has anyone been playing with the settings ?
Posted on Feb 07, 2009
  • chovongai Mar 31, 2012
    Hi, so how can we clear this error code screen to go to Service Mode to set the Scan accelerator kit back to OFF? Or how do we go about clearing this error code ? TIA.
Error code c-d251
Machine is being told it has a scan option but it does not have it or vice versa. did you get a scan option with the machine and or it was remove and that person did not reset the machine to reflect that.
Jul 11, 2015 | Konica Minolta Bizhub C253 With Document...
How to reset error code c-d251 on konica minolta bizhub c253
Press -UTILITY and turn on or deactivated hard disk in service mode The "book" says its the machine setting is wrong jpeg scan accelerator board option enabled when there isn't one installed. Check option setting in service mode (system 1 or 2 I dont remember) turn off jpeg option, reboot.. maybe a failed jpeg board if installed or some other glitch.
Regards.
May 06, 2014 | Konica Minolta bizhub Office Equipment &...
Trouble code C-D251
JPEG Board is not installed but the machine believes it has one due to being set in service mode as having one. Have Technician look at it. Power on off to clear. Scanning issue.
Mar 15, 2014 | Konica Minolta Bizhub C550
Trouble code c-d251
JPEG board (Scan accelerator kit) is not mounted when the JPEG board mounting set ON at Service Mode
Mar 05, 2014 | Konica Minolta Bizhub C550
Error s-d251/s-d366/s-d370/bishup c351
NVRAM kind like computers BIOS. Data multiple errors. Need a tech to come out and re-flash the copier firmware not the drivers. the firmware is only available thru a secure Konica Minolta server. or the NVRAM CHIP is bad worse case so is the board. And it is C-D370, C-D366, and C-D251 which deals with Image control board. it to mite require its firmware re-flashed.
Jan 30, 2014 | Konica Minolta bizhub C351 All-In-One...
S-d366/s-d370/s-d251 error
Sir,
Jan 30, 2014 | Konica Minolta bizhub C450P Laser Printer
C- d251 error
In konica minolta copier not exist d251 error code.Read correct the error code and specify the copier model.
Mar 05, 2013 | Konica Minolta Bizhub C550
C-D251
Try this:
- Turn on the machine with the Utility key pressed
- When the "Troube Reset" appears, press it and right after pressing it try getting into Service Mode.
If that doesn't work, try this:
- Turn off the machine
- Open the right door
- With the right door still open, try to get into Service Mode.
Give us some feedback.
Apr 01, 2012 | Konica Minolta bizhub 250 All-In-One Laser...
How do i fix error C-D251 for Konica Minolta Bizhub 3 in one Printer?
Check option setting in service mode (system 1 or 2 I not sure) turn off jpeg option, reboot.. maybe a failed jpeg board if installed or some other glitch.
Mar 19, 2012 | Konica Minolta bizhub 200 Printer
Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
Feb 17, 2009 | Kyocera KM-1510 Copier
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
849 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
