Question about Polaroid FDM-0700A 7 in. TV/DVD Combo
Under the counter tv
I have a FDX 0700T Polariod tv and the sound works but the picture will come on for less than 2 seconds and then go blank.I bought the tv in Dec 06 and they say the warranty is up? Help
  • jricco Dec 29, 2007
    Unit was purchased in 12-06 and it was the best item I have ever purchased; until now. Screen has gone exceptionally dark and it not viewable. I would love a resolution as I don't see any other units on the market.
  • blomberg_pen Sep 24, 2008
    I have no picture please help
  • 3 Answers
I have the same issue with mine actually. The issue seems to be the backlight inverter circuit just behind the screen. It's a small circuit and the orignial Poloroid circuit is defective. You can buy a replacement one from here:
http://www.lcdparts.net/InverterDetail.aspx?InverterNumber=UI8007S-1MSS
This is a redesigned substitute for the orginal part and it's actually cheaper than the original replacement part.
Hope this helps you some. Good luck!
Posted on Sep 29, 2008
I have very light picture
Posted on Sep 24, 2008
This is a problem of soft is normali becouse is protector of radiation
Posted on Aug 02, 2007
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Samsung t240hd, turn on, no picture, just sound. only had it less than a year! HELP!
did you find a solution? mine is the same. get a picture for about a second then it goes blank. it's not an input problem as it does the same whatever the source and you cannot bring up the menu on screen. audio works fine but no image after first second.
Apr 26, 2010 | Samsung T240HD 24 in. LCD TV
Will not read dvd disc
This can be due to dust in the machine, on the disc or surdace damage to the disc.
These are the most common causes anyway.
Clean the disc itself with plain water and wipe with a soft cloth gently to dry it.
Run a CD Cleaner disc in the machine for 30 seconds, and dust off the loading tray/area with a soft brush.
Then try again.
Try other discs to see if the machine is ok - or whether it is the new disc that is faulty.
Smetimes you have to load the disc 3 or more times untill it reads a certain bit of data correctly to start, after this it doesn't seem so important.
Sep 14, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Westinghouse 42' tv working fine this morning, got home from work this evening turned tv on picture come on for about 4 seconds than blank screen still had sound pressed menu botton still blank screen...
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jul 01, 2009 | Westinghouse Televison & Video
Blank Screen No Audio
Ur main video backlight board is dead,must be replace.Try this website,Shopjimmy.com buy the board for $163,replaced it ur tv will work again.
Feb 09, 2008 | Sharp LC37SH20U 37 in. LCD Television
Maxent MX-27X2 no video,but sound
may not be the inverter but the main board bad
nesco
Dec 30, 2007 | Televison & Video
FDX-0700T has no picture
Here is a website that offers a replacement inverter board that will fix the backlight issue on this monitor
http://lcdparts.net/LCDTVInverterdetail.aspx?InverterOriginal=UI8007S-1MSS
Jul 25, 2006 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Polaroid FDM-0700A 7 in. TV/DVD Combo Logo
182 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
