Question about Kodak ZD710 Digital Camera
Having power problem
I cannot switch on my kodak zd710 digital camera, when i push the on button nothing happens, normally the zoom comes out the moment i switch it on.. help
    Sergeant:
    Champion:
  • 373 Answers
Let just make sure we do the simple things first
check the batteries and make sure they are in the right way . then we will go from there
Posted on Feb 04, 2009
Card write protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 23, 2013 | Kodak EasyShare ZD710 Digital Camera
Hello, I 'm just now ordering your Kodak ZD710
Kodak ZD710 User's Manual
Here is the link to the download page :
http://resources.kodak.com/support/pdf/en/manuals/urg00740/ZD710_UG_GLB_en.pdf
or
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00740/ZD710_UG_GLB_en.pdf
You will need to have Acrobat reader or Foxit reader installed.
I am sorry but the service manual for Kodak ZD710 is not available right now, I will need some time to search for the manual.
Nov 15, 2011 | Kodak ZD710 Digital Camera
Drop my kodak easyshare zd710 and now it will no retract or zoom. Can it be fix
Welcome to Fixya
Looks like the mechanism already failing. Try to troubleshoot it first by taking the battery out. Press and hold the power button for 15 secs then put everything back.
If same problem will occur then the problem is already the mechanism
Thanks
Oct 24, 2011 | Kodak EasyShare ZD710 Digital Camera
When switching my camera on it just switches itself straight back off?
Make sure you have installed freshly charged batteries on your Kodak Camera. If you already have but problem still goes on, then try to do a little fix.
With your camera turned OFF, hold the camera on your right hand with the lens facing the ground. Then hit the camera's base on your left palm as you push the button to turn on the camera. You might have to do this a few times. What happens is that there could be a grit of sand that got stuck between your lens' barrel and the camera's base, preventing the lens to retract freely. If the above solution does not work, you might want to apply a bit of force by twist-pushing the lens inside with your index finger while trying to turn on the camera. The idea here is to remove that grit out of the camera.
Please let me know how this goes. Thank you for using FixYa.
Nov 06, 2010 | Kodak Easyshare V1233 12.1MP Digital...
Kodack ZD710 not getting power?
So far you've done all the right things, please also try to upload new firmware: I doubt that it will solve the issue, but the alternative is a repair.
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11255/11260&product=EKN034158
Feb 09, 2010 | Kodak EasyShare ZD710 Digital Camera
I push on the shutter button and nothing happens!
Have you tried to put new batteries in it sometimes when they start to die then not all of the functions will work and also cheap batteries can be brand new but not strong enough to run the functions
May 25, 2009 | Kodak Easyshare Z812-IS Digital Zoom...
Help Turning my camera On
Hi , I had the same problem ,Kodak advised getting re-chargable batteries Mah 2500 ,normal batteries just are not powerful enough. Mine works fine now
Aug 31, 2008 | Kodak Easyshare C813 Digital Camera
Cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Apr 09, 2008 | Cameras
Kodak ZD710 Digital Camera Logo
171 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
