Question about Sony PlayStation Portable (PSP) Console
I droped my unit twice, i noticed that it hang while saving data
And it will shut down
The thing is, your psp is already damaged. Something inside of your psp is broken, so you'll have to either replace it or try and put it back
Posted on Feb 07, 2009
My brand new Samson Graphite MIDI Controler Keyboard hanging whenever i will save an edited data. i have to unplug the cable power or the USB cable to swicth it off and open again for me to use it. th
i have the same same problem with my unit, i really need help !!! The problem is still there , even if you do a firmware upgrade . i also returned the unit to the retail store and have a new one with the same problem, the software editor doesnt work on windows 7 but in windows xp with 1.92 version, please check my video
http://youtu.be/DKn5ArIxl4M
Jan 21, 2013 | Samson Graphite 49 - USB/MIDI Keyboard...
2002 Santa Fe 127174 miles. On hills car slows dwn, rpm is climbing, speed is droping. on steep hills from a dead stop rpm's are 4,000 speed is just below 20mph. have had the fluid flushed twice.
sounds like your transmission is going bad fast. get it checked asap to see if it can still be saved. aamco will take a look at it. if its completely bad, then getting a new transmission might be cheaper than getting the current one fixed so look into that!!
Oct 18, 2012 | 2003 Hyundai Santa Fe
I need a users manual for my Um-016
Tanita UM Series Body Fat / Hydration Monitor InstructionsTanita UM Series Body Fat Monitor/Scale Instruction Manual
How to Determine Body Fat Percentage
Setting & Storing Data in the Memory
1. Turn the power on using the set button.
2. Select a Personal data number using the Up/Down arrow buttons, then press set.
3. Select your Age using the Up/Down arrow buttons to scroll through numbers, then press set.
4. Select Male or Female using the Up/Down arrow buttons, then press set.
5. Specify the Height using the Up/Down arrow buttons, then press set.
The unit will beep twice and the display will flash all data (Male/Female, Age, Height) to confirm the programming. The power will shut automatically, or you can tap the weight only button (in front of monitor) for quick shut off.
How to select Personal Data Number
1. Press the Up memory button to turn on.
2. Use the Up/Down arrow buttons to select your personal data number, then press set.
3. The unit will beep and the display will show the programmed data.
4. The unit will beep again and the display will show '0.0' and then step on the platform.
5. Your weight will show first, then "00000" will appear and then your Body Fat Percentage will appear on the display.
Programming the Guest Mode
1. Press the Down Guest button to turn on
2. Follow the same steps for programming as outlined above.
3. The unit will beep twice and show '0.0', then Step onto the platform.
Taking Weight Measurement only
1. Select weight only mode, by toe-tapping the weight only button located at the base of the scale.
2. Wait for the scale to display ‘0.0', then step on.
Replacing the batteries
1. When the "Lo" error message appears on the screen, the batteries need to be replaced.
Understanding Your Readings
Healthy Range Indicator
(Please note this function is only applicable on adult mode, as no standard healthy ranges have been established for children and athletes.)
Your body fat monitor/scale instantly compares your body fat reading to the healthy range chart. Following your body fat reading, a black bar will flash across the bottom of the display, identifying where you fall within the body fat ranges for your age and gender.
(-): Underfat; below the healthy range. Increased risk for health problems
(O): Healthy; within the healthy body fat percentage range for your age/gender
(+): Overfat; above the healthy range. Increased risk for health problems
(++): Obese; high above the healthy body fat range. Greatly increased risk of obesity related problems.
Oct 18, 2009 | Tanita 2204 Body Fat Scale
Hp 6735s wont shut down
using the button to shut it down is not recomended, but if you do not have programs running that is loading/saving data, it should be ok, in some cases it could damage the computer, you should see if it is under worrenty and get it looked at or call tech support and see if they can help
Sep 28, 2009 | HP Compaq 6735s Notebook
How can i reboot my toshiba M35x-S111 without a disc?
it's not necessary to have disc to reboot or shut down your PC.. This procedure is very simple to do.
Rebooting PC is necessary when sometimes its notice have a hang-up or low running system or uninstall program.
Aug 27, 2009 | Toshiba Satellite M35X-S111 Notebook
After doing a hard reset on my HTC TyTN 11 it just hangs at a message that say "The device is clearing the storage..please wait" .I have switch it on and of nothing changes..same message appear after...
Hi you seem to either corrupted the storage card of the flash memory. In either case you have to remove the battery physically for 1 minute and try again.
Jul 24, 2009 | HTC TyTN II Smartphone
Pc hanging after turning on
I suspect viral activity. Malware does these type of things. You will need to perform isolation techniques in order to prevent the erroneous apps from running. When in doubt utilize task manager to shut down the pc if it is non-responsive (CTRL-ALT-DEL) gives you the menu. When in extreme doubt, RELOAD OS. Save your extreme data first, of course. I like Webroot software.
Jul 01, 2009 | Compaq Computers & Internet
The motherboard, CPU and heatsink has been replaced and memory upgraded to 1G a year ago now it runs slow and shut down from time to time. It also get hang-up frequently. The motherboard is a gateway...
I think your hard drive may be getting bad sectors on them if its hanging on you frequently.
Save the important data that you need and then wipe out your drive and restore it back to factory defaults.
If its still hanging on you frequently, then at that point replace the hard drive and restore it back to factory defaults.
Jun 29, 2009 | Gateway GT4024 PC Desktop
When loading saved game data I get a Data corrupt message
You need to make sure you have updated the PS3 as well as the games. You said you wait until the game is done saving, well just to make sure, check the HDD light isn't flashing (writing information). Also you should not just shut down from the game, quit game then shut down the system. If you are shutting it down with the switch in the back, shut down "softly" (holding down the PS button and selecting shutdown) then turn off in the back.
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
WD-52327 Lamp hour indicator.
Found this in another forum. So apologies if there are any innacuracies. service code
menu-5-7-5-7
Press the "AUDIO" button on a remote hand unit to select an adjustment function.
Press the ?VIDEO? button to select a specific adjustment Item.
After selecting an adjustment Item, use the ?ADJUST UP/DOWN? buttons to change data.
? Press ?ADJUST DOWN? to decrease the data value.
? Press ?ADJUST UP? to increase the data value.
Press ?ENTER? to save adjustment data in memory. The character display turns red for approximately one second in this step.
Press the ?MENU? button on the remote hand unit twice to terminate the adjustment mode.
options code
menu-5-7-7-0
Nov 07, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Sony PlayStation Portable (PSP) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
