Question about Combi Centre DX - Mango
Water gets hot then turns cold and runs cold then hot again
Baxi combi 80e
  • sjtg Feb 17, 2009
    My Baxi 80e seems to have the same fault, When in the shower it runs hot for a while then goes cold, then back to hot again. I've checked the boiler and all seems OK with the lights, but when it goes cold it looks like the flame light goes out as if it's shut off on a high temp cut out.
    Going to open it up and look at the safety thermostat and clean the temp sensor. Not sure what to do after this, any help appreciated.
Secondary heat exchanger is blocked on sealed system side.
Remove and de-scale heat exchanger or fit new one.
Posted on Jan 14, 2010
    Problem Solver:
  • 5 Answers
Get a fully trained, corgi registered gas engineer to repair and service the boiler, these boilers are not a do it yourself proposition. Safety stats and temp sensors are not serviceable items, replacement if required after testing is the only option, bye the way if you carry out any work on the boiler yourself, any incident that occurrs due to your work will invalidate your building and contents insurance and you could end up in court for your actions as you are not competent to work on the boiler.
Posted on Mar 04, 2009
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
Oct 12, 2009 | Water Heaters
Baxi 80e - water pressure too high
water will stop coming out of the once pressure drops . it will act the same and water will flow out of pipe the same .
Jul 25, 2017 | Combi Centre DX - Mango
Baxie 80e
The usual problem with the hot water fault you have is that the domestic hot water diaphragm needs replacing,they usually last 2 to 3 years, if you haven't had the boiler serviced on a regular yearly basis then you will need it serviced and the fault repaired by a corgi registered engineer.
Feb 07, 2009 | Combi Centre DX - Mango
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Nov 02, 2008 | Combi Centre DX - Mango
Baxi combi boiler 80e safty thermostat light on
baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Combi Centre DX - Mango Logo
3,149 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
