Question about HP Compaq dx2300 Microtower - RT950UTABA PC Desktop
Cd driver is no more responding
It was reading only DVD and now it refuses to open and it has blocked one of my CD inside. and cannot even locate the CD driver on '' MY COMPUTER'' don't know what to do.
need help please.
thanks for all the technicians and problems solvers,
chapeaud a vous....
  • jeanboubie Feb 04, 2009
    thank, got the CD back. but there is an orange light on since. and the CD can still not be open itself. do u think it can be fix. i've uninstall it and install it back. but still no working. i've got my CD by using the PAPER. Nice that SYSTEM...
  • 326 Answers
From your desktop, right click on ''my computer'' and go to propeties, on the tab go to hardware then device manager, you can click on the drive from the list and reinstall the driver from there.
if the driver is in stalled and looks ok you could uninstall the drive and use the scan for hardware changes icon to reinstall the drive.
after that it might be a problem with the drive itself, youll notice a small hole on the front of the drive, if you straighen a paper clip out and place it in that hole it will open your drive so you can get your disk out. be carefull when doing this.
hope it helps
Posted on Feb 04, 2009
  • mark hudson Feb 04, 2009
    theres a few things you could try,
    make sure cables are connected properly try a different power molex lead (should have a few spare from the power supply) try a different ide lead.
    if its dvdrw, what burning software have you got installed? more than 1 burning software? does the drive show up in the software?
    could uninstall the software, uninstall the drive, restart and let windows pick up the drive and install the drive.
    if you do open your case to check the cables make sure you power off your computer before touching anything
    let me know how you get on
Sony DVD not responding to power
open the top cover and chech the fuse in the power supply board,if ok then check on the diodes and probably the ic for power
Dec 15, 2011 | Sony Televison & Video
CD drive refuses to open or run even when I press the button
Select a cd rom device,then add another boot up disc,then see if it opens.Will it take a cd rom better than a floppy? If so use the boot up disc,rather than an older and possibley more damaging floppy.
Feb 16, 2010 | E-Machines eOne 433 PC Desktop
My dvd drive does not open or responds green light
hello, here is the simplest thing to do if your cd/dvd is stacked inside. 1. punch through the hole infront of your burner using a paper clip, that will force the cd door to open, try it..
Nov 25, 2009 | Pioneer DVR-107D DVD±RW Burner
Packard Bell computer won't play dvds.
This sounds like a common problem. You need to install the drivers (small programs that instruct the computer to notice and manipulate peripherals, like a dvd or cd player, sound card, etc...).
The easiest place to find your specific driver is at the Packard Bell web site under support > Downloads. There are MANY sites (even some that advertise on this very site) that say they have the drivers for your dvd drive, but go directly to your manufacturer's web site. These companies that provide drivers for computers install a program into your computer and there is a fee for use of these web sites.
UPDATE: I just checked the Packard Bell Web Site and was unable to find specific drivers for your particular model. They stopped making them some time ago, and no longer support the model. That being said, you can still conceivably find the drivers, it will just take some investigative work on your part. In doing a broad search on the internet, I found that many people are looking for that very driver, which is an indication it has become hard to find.
Jun 15, 2009 | Packard Bell GCD-R580B (gcdr580b) Internal...
Philips DVP-3020K not eject my CD
hello my friend! my dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
Dec 21, 2008 | Philips DVP-3005 DVD Player
Lense problems
vickyforwin
r u sure all fragment of broken r cleare from inside. this problem happen if any pice of cd r block head actuator path. open ur drive cover and carefully cleare it.
thanks for asking
Jul 06, 2008 | LG (GSA-4120BK) DVD±RW Burner
Power calibration error
In the past some burns did not like some makes of cdr's. Ask a friend for a blank cd from a differant manufactor. And be sure that your burn software is set to use the right drive.
Apr 03, 2008 | Computers & Internet
CD-RW/DVD-ROM can not read and CD or DVD
yes..it's most likely kaput. I have a tecra, and I'm on my second CD/DVD replacement. They are easy to find and replace(one screw underneath, and just slide em out)..
Feb 17, 2008 | Toshiba Tecra 9100 Notebook
My dvd combo does not read dvd
There are separate lasers for CD reading, and for DVD reading. This is why it is possible to have a drive that reads only CDs but not DVDs, or the other way around. And your particular combo unit seems to have a lot of these problems. Since the drive doesn't work it's almost definitely a problem with the drive itself (I'm assuming that there is nothing wrong with the discs you tried to read). If that drive is still covered by a warranty period, send it back for repairs. Otherwise, I can't see the harm in trying to tinker with it yourself as the DVD portion of it is dead anyways. Ummm, on a side note...CompUSA is going out of business and they are selling things cheap. I got a DVD lightscribe burner for $40...booyah!
Mar 26, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
DVD drive some time works, some time does not
first try uninstalling the dvd drive go to start/control panel/system/hardware/device manager look for dvd/cd-rom drives right click dvd - uninstall reboot afterwards so winxp will re-install drivers if this does not work, go to toshiba.com look for downloads for your dvd/cd drives just make sure you have the right model so the file you download will be exact and correct
Jan 21, 2007 | Toshiba Satellite Satellite 5200 Series 15...
HP Compaq dx2300 Microtower - RT950UTABA PC Desktop Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
