Question about Microsoft Windows Server Standard 2003 for PC
While starting the windows its saying that NTLDR is missing
Please let me know how to fix this issue
Worolinfg
Posted on Feb 04, 2009
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
Windows 7 with Gigabyte motherboard says "ntldr is missing"
Check if UEFI is disabled after flash with newer BIOS version. If you flash BIOS the default settings gets loaded again. Check hard disk settings and boot settings.
Mar 03, 2013 | Gigabyte Computers & Internet
Bootmgr is missing
Bootmgr is the replacement for NTLDR in Vista and Win 7. NTLDR (NT loader) is the OS component which literally started the operating system in XP/2000. In the past I have had to use recovery console to go in and repair the OS (this is only available on the Windows disc). I would say in this case you will have to do the same, repair the operating system using the Windows disc.
This article is a how-to on fixing this issue, if you up for it:
http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
Jan 14, 2012 | Gateway Computers & Internet
Cd/dvd not knoun the cd
This issue with CD/DVD has always been my favorite issue. Checkout my technical blog at reyfrancisbasa2.blogspot.com. This technical blog shows a graphical step by step instruction on how to fix this issue. Please let me know if it fixed the issue or not.
Thank you for visiting FixYa!
Apr 26, 2011 | Computers & Internet
Dsc-t20 digicam, are problem while the open the camera is shaking or vibrate................are question is what is the good sulotions???
Sony has discovered that some DSC-T20 Cyber-shot cameras sold in the United States may experience an issue with abnormal internal vibration and an inability to properly focus and take pictures.
For cameras affected by this issue, Sony will provide free repair until July 16, 2011.
This issue affects some of the following DSC-T20 cameras sold in the United States:
  • Pink or Silver cameras with serial numbers between 500001 and 525350.
To setup the service under the know issue, please call Sony customer support center at 800-784-6726.
Please click hear to view the Sony's Announcement regarding the issue.
Thanks for understanding. I hope this information enough to get the Camera fixed.
Please let me know if you require any additional help.
Apr 15, 2011 | Sony Cyber-shot DSC-T20 Digital Camera
If someone could walk me through the set up it would be appreciated.
Brother! We would be happy to help you out to fix any issue but please mention the issue that you are facing with your Sylvania 7" G-Netbook PC Notebook. Unless we don't know the issue, How can we fix it.
Please mention the issue that you are facing with laptop and what do you want to setup.
like you want Window 7 installation.
Wireless setup.
etc.
cheers!
Mar 18, 2011 | Sylvania G-Netbook
I want to download firmware to my GE A1250
Unfortunatly these are shipped with the current firmware loaded, if you having issues with the camera please update me with the issues.
Updating firmware does not fix hardware issues "never does" , it fixes software issues.
If your having freezing, grainy photos or anything like that the camera would need to be repaired. Firmware will not fix this.
let me know
Jan 06, 2011 | General Electric A1250 Digital Camera
Vibrating and rattling from inside and shakey pictures
I'm sorry that the Camera is vibrating. Sony has discovered that some DSC-T20 Cyber-shot cameras sold in the United States may experience an issue with abnormal internal vibration and an inability to properly focus and take pictures.
Dec 27, 2010 | Sony Cyber-shot DSC-T20 Digital Camera
Os system not found,i cant boot windows
Hi khanaboki1,
This issue may occur if the Computer is not detecting the Internal Hard Disk Drive in it. Resetting the BIOS to the default values should fix the issue.
To reset the BIOS to the default values, please restart the Computer, press and hold the F2 Key. This will take you the BIOS Utility Window, there, please press the F9 Key to load the default values then F10 to save and exit. After that, please try restarting the Computer to check if the issue is fixed.
If the issue is not fixed, please try disconnecting all the external devices connecected to the Computer. Also, please confirm if the Hard Disk Drive is listed in the BIOS main window.
If the issue still persists, you may need to perform the System Recovery in the Computer to fix the issue. In that case, you can try accessing the Recovery Partition in the Computer to perform the System Recovery. To access the Recovery Partition, press and hold the F10 Key while restarting the Computer. This will launch the VAIO Recovery Wizard. There, please click "Proceed with System Recovery" and then you can select the "Restore C: Drive" option to re-install the Operating System in the Computer. Performing the Restore C: Drive will erase all the User Data in the Computer and restore it back to the factory settings.
Hope this helps.
Good Luck!
Please let me know if you have any further questions or require any further assistance.
Thanks for using FixYa.
Dec 16, 2010 | Sony VAIO GRZ660 Notebook
NTLDR is missing Press Ctrl Alt Del to restart
The issue is your system is not loading off of the boot drive- check for usb keys, floppies, even sometimes cds can cause the issue. If that does not work, you'll need to get your copy of windows, boot to that disk, and run a chkdsk /r in the repair option. If that does not work, you will need to reinstall Windows.
Oct 17, 2010 | Acer Computers & Internet
Microsoft Windows Server Standard 2003 for PC Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
