Question about EliteGroup ECS G556 Notebook
ECS GREEN556E Laptop Memory
can anybody tell me how to figure out where the memory of this Elitegroup laptp is located ?
I found a slot on the backside, which seems not to be used.
But where is when the 1GB RAm which is already inside ?
Can i use the slot i found to install a 2. GB of RAM - and which kind of ?
Regards
Robert
  • 395 Answers
The manual is here
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2258&areaid=2&LanID=0
pages 87 & 88 show how to install
it uses' ddr1 memory up to 2gb max total in the laptop
Memory
0MB on board, 2 SO-DIMM slots, up to 2GB
Support DDR 266/333MHz system memory
Posted on Feb 04, 2009
Also there is 512Mb base RAM under the keyboard.
Toby
Posted on May 17, 2009
What memory and processor use Q35T-GB
Socket Type: LGA775
Supported Memory: DDR
Onboard Video: yes
Onboard Audio: yes
Graphics Expansion Slot: PCI-E x16
PCI Slots: 2 PCI, 1 PCI-E x1
USB Ports: 6
VGA Ports: 1
This should be the homepage:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2654
Good luck
Mar 16, 2013 | ECS Q35T-GB Elitegroup Type Motherboard...
I have a G320 laptop with 512 SO-DIMM DDR400 and 1 GhZ procesor ,OS WIN XP, how can I run my G320 faster
There is nothing much that can be done to speed up the system as it can not go beyond 1GHz Processing speed, but several operating system tweaks and some hardware upgrade could make a little but notable difference.
As for Hardware, you may increase the RAM. You can upgrade memory on ECS Elitegroup Computer G320 upto a maximum of 1.0 GB (The ECS Elitegroup Computer G320 takes the PC2100 DDR SDRAM SODIMMs Memory)
Secondly, You may increase the size of PAGE FILE, uninstall unwanted software, Remove unwanted start-up items, Clean Junk Files/ Temporary files, De-fragment the Hard Disk to achieve the maximum speed and performance that EliteGroup G320 PC can give.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | EliteGroup G320 Notebook
I have put a "GB DDR2 -800 in each memory slot in
because there is a defect with the dimm slot 2 on these mobos.I have the same problem.contact ecs therell give you a bios update but it wont work
Nov 09, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
My motherboard ecs elite p4m800pro m2 cant detect 1 gig memory,, please help
Hi, you need to check you have the corrct memory, you need: Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MH
Jul 12, 2010 | EliteGroup (ECS 915PL-A2) Motherboard
2G RAM's for Elitegroup (ECS) L7VMM2 Rev 1.0A Motherboard
You're board can handel; DDR SDRAM up to 200 or 266MHz DDR SDRAM memory module. Accommodates two "unbuffered", 2.5V 184-pin slots. Each slot supports up to 1 GB with a total maximum capacity of 2 GB. Return the Kingston memory you have installed if it is less than a year old. They should allow you to trade up to the MB's supported memory.
Two reach the MB's max memmory of 2GB. Buy two Kingston DIMMS of, "unbuffered", 2.5V 184-pin
DIMMs. Here is one site that sells Kingston memory;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=235786&CatId=548
The next link is Kingstons site; http://www.ec.kingston.com/ecom/configurator_new/PartsInfo.asp?root=us&LinkBack=http://www.kingston.com&ktcpartno=KVR266X64C2/1G
Here is another site; http://www.buy.com/prod/kingston-1gb-ddr-memory-pc2100-266mhz-184-pin-dimm-kingston-1gb-ddr/q/loc/101/10348796.html
If you decide to search for you're self, use this as the basis for the correct model: Module - KVR266X64C2
Link to ECS web site; http://www.ecsusa.com/ECSWebSite/Product/Product_Detail.aspx?DetailID=62&CategoryID=1&MenuID=50&LanID=9
Mike
Jun 02, 2010 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
Ok i have 2 1gb corsair memory sticks and when i put them both in they wont work but when i use one it will its the slot on the mother board i think is there anyway to fix it
try the known good memory stick and try to reseat the memory stick to every slot that your mobo have. so you would know if the problem is with the mobo or the memory stick itself
Mar 29, 2010 | EliteGroup ECS 915P-A2 Intel 915P Socket...
ECS 6100SM-M hangs on POST
Check memory, remove or replace sticks of memory with just one piece in the slot closes to the CPU. Now try a power on and see if it boots. You have at lease one good stick of memory to boot.
May 20, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
ECS 648FX-A1 can it use high density memory?
The Motherboard limitation are DDR400 = 2GB maximum size per slot
Allthough you can with slower memory DDR333 or DDR266 go to the 3GB memory limit.
Due to the age it will be trail and error on the memory types. You won't necessary get any problems with the high density memory as long as it is good quality memory and you don't exceed the slot memory limit as mentioned above.
I recommend that you download the motherboard manual and read it.
Dec 02, 2017 | EliteGroup 648FX-A Motherboard
Can't find the primary memory for a elitegroup a535 laptop
a manual can be found here along with the software drivers
http://download.ecsusa.com/dlfileecs/manual/desknote/a535/English%20Manual.pdf
On board 128MB DDR RAM ( primary cant be removed from motherboard)
Expansion 1 slot of 200pin DDR SO-DIMM DDR Module, 640MB total memory capacity.
Supports DDR200 / DDR266 module
Dec 18, 2008 | EliteGroup ECS A535 Notebook
EliteGroup ECS G556 Notebook Logo
959 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
