Question about Epson Stylus CX6400 All-In-One InkJet Printer
Jammed paper Hello I have removed some of the jammed paper in my SX200 but not all.It appears that something will have to be released to allow the paper to clear fully. Regards Geoff
Removed the new paper from feed slot, pressed the on button which allowed the `grabber` to release the jammed paper slightly and then was able to [with the aid of long tweezers] remove the jammed paper through the feed slot.
Regards
Geoff
Posted on Feb 06, 2009
Open right side cover.let down the lever 1 and remove paper open drawer 1 check & clear paper path
Hello Rashid
Thanks for posting.
Look if the real paper jam had occurred then probably still the paper might have been left in the cartridge area. or mostly when the jam has taken place it might have let the sensor flag stuck then inspect closely and release it manually by pulling it down or upwards. Use a spot light to see it clearly near the toner cartridge are and also in the paper tray area.
May 26, 2014 | Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
How do i print onto acetate using an epson sx200; it doesn't recognise any paper... thanks
Some printers use a light sensor to tell if paper is loaded or not. If printing on clear acetate, try loading a regular sheet of paper under it. It should pull the acetate sheet through and leave the regular paper in tray. Since the Epson sx200 is an inkjet printer be careful not to smudge. I would allow a good 5 to 10 minutes to dry. Good luck!
Mar 01, 2011 | Office Equipment & Supplies
How can fix the jammed paper situation?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-17
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I do'nt see any paper being jammed.
when the message appear? Turn on printer or starting to print? If message appear at beginning turn on printer is caused by "something " slip at paper feeder. But if it appear at start to print, it caused by chip error? Do you use CISS chip?
Jun 25, 2009 | Epson CX7800 Stylus Color All-In-One...
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Paper jam
Solution one: Clear the jam from the back of the All-in-One Follow these steps to clear a paper jam from the back of the product. Step one: Remove any loose paper Remove any loose paper from the input tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back CAUTION: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the product slowly and gently. Avoid touching the internal components of the product.
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear door. Push in the two release tabs, and then pull the door toward you.
Feb 01, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Paper jam
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
334
Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
Epson Stylus CX6400 All-In-One InkJet Printer Logo
411 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
