Question about Sony KP-65WV700 65" Rear Projection HDTV
Sony 52 inch projection Screen keeps shutting off.
Hi I have a Sony Projection Screen TV . The Picture is Great when its Running But after a while The Screen goes all weird and then the TV shuts itself off, and a little Red Light on the front keeps Blinking on and Off. This same thing happened a few months ago and I had it fixed for about $300. Im not sure if its the same problem or something else.
I ve since bought a new 46 inch Sony Bravia HDTV which is fabulous, but Im wondering if the 52 inch Sony is worth getting fixed again. Thanks............ David
  • 1 more comment
  • keyman07 Feb 06, 2009
    Hi WelcomeJee.
    Sorry it took me a while to get back.
    The Model number of the TV is: KP51HW40.
    When you turn the TV on the Basic picture is OK then the entire Screen flashes Red a few times, then the TV shuts itself off.
    The Red light in front Blinks a Sequence of 8 Flashes. Over and Over. Thanks for any help.............. David
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Thanks for update,
    RED screen flash shows problem with RED GUN in TV and 8 times is resulted code error when TV shut off due to whole screen red flash.
    In my opinion, RED GUN is defective and requires replacement. If you are not familiar with TV repair please ask an estimate of repair form local TV repair shop.
    Please intimate exact model of TV, written at rear side and how many times that red light blinks?
  • 2,920 Answers
Not if it keeps repeating the same cycle over and cost 300 once and if you have it fixed again thats another 300 and if it happens again so on and so on....
Posted on Feb 04, 2009
Screen Flicker then tv shuts off
please re solder  first all parts specially in hot area, and observe if problem still occur, then next is replace filter capacitor. observe also too hot parts and check for change value resistor.
Feb 25, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
I own a 52 inch rca projection tv and last week
Most likely the Horizontal output transistor has shorted. When it shorts it causes the power supply to chirp. This is a common problem with this series of TV. Have a shop check it out. It should not be real expensive.
Oct 16, 2009 | RCA P52926 52" Rear Projection Television
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Sony 52" rear projection tc
Hi, thats the code for AKB fault, this requires a tv tech to fix,, not a big bucks repair, video-tek
Feb 09, 2009 | Sony KP-43T90 43" Rear Projection...
Tv shutting off!
replace the high voltage block
the part number is (8-598-955-32)
comen problem for you model number.
Jan 13, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Sony 52 inch hd widescreen projection tv
You need to pull the top back off be very carefull that you do not break mirror clean mirror and all 3 tube lenses this should make a diffenrents in picture.
Feb 19, 2008 | Televison & Video
52 inch sony rear projection t.v.
Whining sound most likely is a bad flyback transformer. You are probally looking at a 350-450 bill depending on the repair shop. If your picture was "great" go for it. If the tv has a lot of wear let it go. Nothing the repair shop does to fix your problem will make your picture better than it was before it went out. Somthing to contemplate.
Feb 05, 2008 | Televison & Video
Sony KP-65WV700 65" Rear Projection HDTV Logo
932 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
