Question about Hotpoint First Edition WMA20 Front Load Washer
Can't find filter on hotpoint wm63p
Machine not draining or rinsing well need to check filter where is it??
  • anna263 Feb 04, 2009
    Thank you! Problem solved quickly and easily.
  • Hotpoint Master
  • 3,463 Answers
Remove lower rear panel of washer, locate and remove the large black hose fastened to bottom of tub, you will find the plastic filter inside the hose, remove and clean.
Please leave a rating for my fixya solution.
Thankyou.
Posted on Feb 04, 2009
Need to change the drum bearings on a hotpoint wm63p anyone done a video showing how to do it?
If the motor bearings need replaced, you're better off just replacing the whole motor. Save yourself time.
May 21, 2012 | Hotpoint Washing Machines
My hotpoint wm63p washing machine when in wash cycle works up until the last spin and then u hear clicking and the machine will skip the cycle and stop or sometimes just continue to the next dial cycle..i...
If you have changed the brushes are satisfied that they are fitted correctly, then it can be a couple of possibilities.
1- The motor itself is faulty.Even though it does the wash o/k it is possible the spin winding is faulty.
2- The prograqmmer is faulty.
Make sure the pump is working o/k, and that all the water has drained out, as this would stop it spinning
Dec 15, 2010 | Hotpoint Washing Machines
Hotpoint WMA74 does not pump out after programmed
No test available other than:
Remove pump - check motor will turn by rotating impellor. There is a slight resistance then moves freely, then slight resistance and freely again. This is correct for this machine. worth checking there is no hair, elastic band or other obstruction around the impellor fins and shaft whilst the pump is out.
There is no spin cycle so you have to use rinse & spin, which means if the pump is shot you need to empty the machine each time :(
Worth checking lower filter as stated and blowing down the drain hose whilst the pump is off to check for obstructions.
The resolution to my problem was a new pump - £20.
All working fine again now !
Jan 24, 2010 | Hotpoint WMA74 Front Load Washer
Hi My Hotpoint WF540 1400 spin is stopping mid cycle and not draining, rinsing and spinning unless I stop the cycle and choose just rinse and spin. Any suggestions? sarah
Probably needs the filter cleaning.
Remove lower rear panel.
Remove large black hose onto drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump itself.
Please rate my solution.
Thanks.
Nov 16, 2009 | Washing Machines
All programmes stop before last rinse & spin.
I would suggest you check the filter.
Remove rear panel completely, locate and remove large black hose fastened to bottom of tub.
Remove and clean plastic filter inside hose,, check drain hose for partial obstruction, refit filter and hose.
Make sure drain hose is not kinked or trapped, and make sure outlet is not obstructed.
Refit rear panel, and test.
Please leave a fixya rating for my suggested solution.
Thanks.
Feb 11, 2009 | Hotpoint Aquarius WD63 Front Load...
MY HOTPOINT BWM12 1200 SPIN WON'T DRAIN,
You need to check and clean filter first.
You will find the filter is normally located behind a removable plastic cover at the front right side of the m/c.
Make sure the drain hose is not kinked or restricted..
Make sure you have not selected rinse hold..
Obviosly make sure pump is actually working.
Plz rate this solution .Thanks.
Dec 24, 2008 | Hotpoint BWM12 Front Load Washer
Washing machine not spiining
sump hose filter blocked, running out of draining time, when you put it on again it allows more time to drain, remove sump hose and clean out internal filter.
Dec 10, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint wm63p washing machinre.
i replace these weights regularly and tighten them up as tight as i can get them (and i am a big chap) so as tight as you can get them with a ratchet and socket.
Jun 04, 2007 | Hotpoint First Edition WMA20 Front Load...
Machine stops in Rinse & Spin Cycle & leaks water
Hotpoint WF430 Front Load Washer This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 24, 2007 | Hotpoint WF430 Front Load Washer
Hotpoint First Edition WMA20 Front Load Washer Logo
234 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
