Question about Microsoft Computers & Internet
Computer randomly restarts
My computer randomly restarts, the specs:
motherboard: asus p5dc-mx
processor: intel p4d 2.8 ghz
memory: 1.5g
hard disk: 80g seagate sata2 7200 rpm
built in video and sound card
power supply: 500w
os: windows xp sp2
already scanned for viruses and there were none
reformatted the hard disk but the problem occurs again after reformatting
originally the memory was 512mb when the problem occured and increased this to 1.5gb but still the problem persists
replaced already the power supply
what can be the problem? can anybody help me with this?
    Genius:
  • 2,785 Answers
Plz try with 1 gb of ram module
Posted on Feb 04, 2009
Can the motherboard asus p5vd2-mx admit a q6600?
The Q6600 will physically fit (LGA775) that Motherboard but it will probably not work. Attached is a list of supported processors and it looks like this motherboard does not support Kentfield based processors.
http://www.cpu-upgrade.com/mb-ASUS/P5VD2-MX.html
Intel Core2 Quad Processor Q6600 8M Cache 2 40 GHz 1066 MHz FSB...
Jan 17, 2017 | ASUS Computers & Internet
Need the specs for HP DV7 Laptop motherboard #486542-001. Most interested in what AMD Turion X2 cpu's this motherboard supports
Microprocessor 2.26 GHz Intel Core 2 Duo Processor P8400
Microprocessor Cache3 MB L2 Cache
Memory 4096 MB
Memory Max8192MB
Hard Drive 320 GB (5400 rpm)
Take care.
Jun 01, 2010 | Computers & Internet
Can windows 7 be installed on asus k8v-mx mb with amd sempron 2.4 1gb ddr1ram
this is the minimum spec for Windows 7:
  • Processor: 1 GHz 32-bit or 64-bit processor
  • Memory: 1 GB of system memory
  • Hard drive: 16 GB of available disk space
  • Video card: Support for DirectX 9 graphics with 128MB memory (in order to enable Aero theme)
  • Drive: DVD-R/W drive
  • Internet connection (to download the Beta and get updates)
Its not the motherboard, its the processor speed, RAM size, and hard drive space, and video card capability that counts.Your processor speed well meets this criteria and also your RAM size is within spec for Windows 7, and im sure you will have in excess of 16GiG hard drive space. So its all down to your video card. You may need to install DirectX 9.Hope this helps :)
Feb 14, 2010 | ASUS K8V-MX Motherboard
Pc saya mengunakan Motherboard P5KPL-AM SE dengan prosesor intel Core 2 Duo 2,8 GHz, Memori VGEN 1 GB PC 5300, harddisk seagate SATA 250 GB 7200 RPM Pc saya tidak bisa boting dan setiap dinyalakan, 15...
Pc saya mengunakan Motherboard P5KPL-AM SE dengan prosesor intel Core 2 Duo 2,8 GHz, Memori VGEN 2 GB PC 5300, harddisk seagate SATA 250 GB 7200 RPM
Pc saya tidak bisa boting dan setiap dinyalakan, 15 detik kemudian mati.
saya juga tidak bisa masuk ke layar bios.
Nov 08, 2009 | ASUS P5KPL-AM SE Motherboard
Earlier i had ASUS P5G-MX motherboard & 2.0 GHz Core 2 duo Processor.I upgrade my Motherboard to Asus P5KL-AM/PS & then i have a black screen with my 2.0 ghz processor, But i tried 2.8 ghz Core 2...
HI,
The only Thing To Do, is view both Motherboards, user Manuals.
To see The boards CPU Support List.
It could be to do with, certain Motherboards Supporting, certain CPUs.
I.e a 533mhz cpu, would not run on a Motherboard that supports 400mhz. The Systems Bios, May cause Other Problems.
If your getting a Black Screen, is it a possible Graphics/Ram Problem, Rather Than The CPU ??
Mike @ Compurepair.
Oct 22, 2009 | Intel Computers & Internet
Compatible processor and memory for p4vp-mx
Socket 478 for Intel Pentium 4/ Celeron up to 3.06 GHz+
- Intel Hyper-Threading Technology ready
- New power design supports Intel next generation Prescott CPU!
2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Oct 16, 2009 | ASUS P4VP-MX Motherboard
Mother board
Description: The Asus P5GC-MX is an Intel 945GC Express-based, compact motherboard.Compared to other compact motherboards on the market, it is inexpensive at around $55.This motherboard supports Celeron, Pentium 4, Pentium D, Pentium Dual Core, and Core 2 processors that use the LGA775 interface.This product can support up to 2GB of memory.
Pros: None noted, given available product data.
Cons: None noted, given available product data.
Suitability: A compact motherboard, suited for small computers.
Value: In view of its inexpensive price, this motherboard has great features for the money.
Suggestions: (1) Be sure that you are using a LGA775-compatible processor with this motherboard.(2) If you want to take full advantage of the on-board SATA controller, you will want to consider a hard drive upgrade.Existing IDE hard drives will run on the ATA-133 bus.(3)
XFXg31
General
  • Product type (AE) Motherboard
  • Form factor Micro ATX
  • Width 9.6 in
  • Depth 7.6 in
  • Compatible Processors Pentium Dual Core , Pentium Extreme Edition , Pentium 4 , Celeron , Pentium D , Core 2 Quad , Core 2 Duo , Core 2 Extreme
  • 64-bit Processor Compatibility Yes
  • Mainboard processor socket LGA775 Socket
  • Mainboard / Multi-Core Support Dual-Core / Quad-core
  • Chipset Type Intel G31 Express
  • Data bus speed 1333.0 MHz
  • Storage key information Serial ATA-300 , eSATA port
  • Power connectors 24-pin main power connector , 4-pin ATX12V connector
  • Processor
  • Installed Qty (Max Supported) 0.0 ( 1.0 )
  • Memory
  • Cache Memory Type None
  • Supported RAM Technology DDR2 SDRAM
  • RAM Installed ( Max ) 0.0 MB / 4.0 GB (max)
  • Supported RAM Speed PC2-6400
  • Video
  • Graphics Controller Intel GMA 3100
  • Video Memory Dynamic Video Memory Technology 4.0
  • Audio
  • Audio Output Sound card
  • Sound Output Mode 5.1 channel surround
  • Audio output compliant standards High Definition Audio
  • Telecom / Networking
  • Modem None
  • Networking Network adapter - Ethernet , - Fast Ethernet
  • Features
  • Hardware Features Intel Fast Memory Access Technology
  • Expansion / Connectivity
  • Expansion Slots Total (Free) 2.0 PCI Express x16 - DIMM 240-pin , 1.0 PCI - LGA775 Socket , 2.0 Processor , 1.0 Memory
  • Storage Interfaces Serial ATA-300 - connector(s): 1 x 7pin external SATA - 1.0 device(s) , Serial ATA-300 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s)
  • Interfaces 4.0 x Audio - Input - 6 pin mini-DIN (PS/2 style) , 1.0 x Network - VGA - 4 pin USB Type A , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX - Mini-phone 3.5 mm , 1.0 x Display / video - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Hi-Speed USB - Line-out - Mini-phone stereo 3.5 mm , Microphone - Generic - Mini-phone stereo 3.5 mm , Audio - Generic - RJ-45 , Keyboard - 6 pin mini-DIN (PS/2 style)
  • Additional connectors (optional) 4 x Hi-Speed USB
  • Miscellaneous
  • Included Accessories I/O back plate
  • Cables Included 2.0 x Serial ATA cable , 4.0 x Serial ATA power adapter
  • Software Included Drivers & utilities
  • Windows Vista Readiness Certified for Windows Vista
  • The Intel board is a discontinued product but is a better board than asus
    Sep 01, 2009 | Computers & Internet
    Upgrading CPU
    Yeah, it was a bit hard to find, not being a currernt model I was stuck on the Asus site trying to find out for you.
    Then I found this site -
    http://www.hardwarezone.com/articles/view.php?cid=6&id=465&pg=
    It says
  • Socket 478 for Intel� Pentium 4 / Celeron processors
  • Intel� Pentium 4 Processors 1.4GHz - 2.53GHz or higher
  • Intel� Celeron Processors 1.7GHz - 1.8GHz or higher
  • Supports processors at 400 / 533MHz front side bus
    Or higher, it says. But doesn't say how higher. It's a fair assessment that if it is a Pentium 4 socket 478 chip, it should work. Then it's a case of choosing one that suits your budget.
    Have a look on the Asus site for the latest BIOS updates too - they might have a clue as to what chip you can go to -
    http://support.asus.com/download/download_item.aspx?model=P4S533-MX&product=1&type=All&SLanguage=en
    Er, no - it doesn't tell you. But if you go thru the page you will find BIOS version 1005 that " P4S533-MX BIOS 1005
    Support new Intel P4 CPU" and the latest bios is 1007.002
    There's a motherboard user manual further down on the page. Make sure you choose the English one.
    Seems the issue is FSB speed, 533 or 400. No big problem for most, but I did see a Pentium4 3.0Ghz chip at 800 FSB so just check the speed of the processor matches the specs the motherboard handles. Like you say, looks like the 3.2 might be too fast because of the FSB requirement.
    Remember, a P4 is going to be quicker than a celeron anyhow so just go with the fastest 533 FSB chip you can find.
    A short-cut to the english manual, here - http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4s533-mx/e1187_p4s533-mx.pdf
  • Apr 27, 2009 | ASUS P4S533-MX Motherboard
    Computers & Internet Logo
    73 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
