Question about Microsoft Windows XP Home Edition
Shut down problem
Sir i have hcl computer with 80 GB harddisk and 1 GB of ram ..recently some problems occured in my computer the problem is when i was shut down my computer ...i will restart again it never turn off sir
    Problem Solver:
  • 15 Answers
You should change CMOS battery.
Posted on Feb 04, 2009
Sir,i have install 3 sata hdd on my motherboard gigabyte 945 GCM-S2L 1. 160gb 2. 500gb 3. 1 tb. my pc many times hangs on bootup and freezes then i disconnect the cable to turn off. how to fix that...
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Sep 25, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
Getting error message on ibm x3400 Fatal Error Controller Monitor Failed Controller Not Started
dear sir in my server IBM X3400 has a problem due to RAM it might be corrupted or out of order bcause system gives continues beep when i change the RAM with HCL 1 GB DDR2 (Previous RAM was also 1 GB) it gives error:
waiting for controller to start
FATAL ERROR: controller kernel self test failed
<< press any key to continue>>
please solve the problem
Oct 28, 2010 | IBM x3400 Server
Harddisk doesn't appear in the list of intel
The computer is not getting pass the POST (power on self test) and therefore the hard disk information doesn't appear and the computer won't boot up.
The problem is with your RAM modules, your motherboard uses interleaved memory, it requires two identical RAM modules (a pair of RAM modules) to be inserted into the motherboard memory slots. These slots are color coded and the RAM modules MUST be inserted into the RAM slots with the same color.
Dec 24, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Shutdown and restart problem wit my hcl notebook.
If you go to the internet often, you need at least 1 gb of RAM. And also you need to constantly run Disk Cleanup maybe twice a month. Have enugh hard drive capacity (ROM) : preferable 80 gb or more. To find Disk Cleanup ( Start - All Programs - Accessories - System tools - Disk Cleanup). If not working, save all your documents and valuabel information in another storage mean and reinstall your operating software. And after, run Disk Cleanup twice a month and upgrade your RAM. Consider a good Antivirus.
Sep 13, 2009 | Computers & Internet
I need to add space to my compaq presario desk top. i don't know how to on this computer. the model# SR5034X
If you want to increase cpu speed so you need to increase RAM memory.
You can fix it on motherbord of desktop cpu.
But if you have low space on disk storage partition so you can add space to desktop with 2 method.
(1) you can add harddisk to desktop cpu with sata or IDE .SATA harddisk is best if your motherbord support SATA.
You can add harddisk as you like for example 80 GB or 160 Gb.
(2) If you want to add RAM memory for speed reson you can purchase new RAm and fix it in memory module slot on motherbord.
There is 2 type on
RAM in currently.
DDR1 and DDR2
you can add RAM memory like 512 MB or 1GB or more.
Aug 07, 2009 | Compaq Presario 5000 PC Desktop
Booting problem
Check your harddisk connectio to mtherbord.reconneect both cable sata and power supply to harddisk.then check in bios your harddisk is detect or not.
Mar 21, 2009 | Intel Motherboard
Harddisk 160GB
Sir my harddisk drive is not working
please give to me Delhi Service center number
Dec 21, 2008 | Hitachi TravelStar 80GN 80 GB Hard Drive
Problem while loading OS in laptop of HCL make
Greetings my name is Mark and I will be happy to assist you.
I need some information so I can help.
1. The make and model of your computer.
2. The amount of ram you have installed, this can be found by going to start then right click on my computer click on properties and the amount will be displayed.
Thank you , let me know,
Be mucho blessed,
Jul 02, 2008 | Computers & Internet
Samsung v25 shutdown
hi dear
Do not complete the following procedure unless you are very familiar with internal computer hardware removal and installation. The hardware components in a computer are very sensitive to static electricity. For information about the correct handling of computer components, contact your computer manufacturer. 1. Shut down your computer, and then remove all the Peripheral Component Interconnect (PCI) devices. 2. Restart your computer. • If Windows starts successfully, shut down your computer, and then reinstall the PCI devices one at a time. Start Windows after the installation of each device. When you install a device that causes the issue that is described in the "Symptoms" section, remove that device, and then continue to install the other PCI devices. • If Windows does not start successfully, remove one or more of the memory modules that are installed in your computer. Leave sufficient RAM for your computer to start and run Windows XP.
Note Windows XP requires 128 megabytes (MB) RAM. The minimum is 64 MB and the maximum is 4 gigabytes (GB).
For example, if two 256-MB memory modules are installed in your computer, remove one of the memory modules. If Windows starts successfully, shut down the computer, and then reinstall the RAM modules one at a time. Start Windows after the installation of each RAM module. When you install a module that causes the issue that is described in the "Symptoms" section, remove that module, and then continue to install the other RAM modules. 3. Determine if the PCI devices in your computer are compatible with Windows XP. To do this, visit the following Microsoft Hardware Compatibility List (HCL) Web site:
Mar 22, 2008 | Samsung V25 XVC 2800 Notebook
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
