Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
My computer has lost hard disk drive
Tell me what i do
    Problem Solver:
  • 17 Answers
Drive is degrading, get your data backed up pronto. hard drives deteriorate over time. there are sector on it that go bad,so os bypass's them
Posted on Feb 05, 2009
My lappy hard disk is giving status that hard disk failure try to install in other location. then i connected it to my pc to take backup
Not sure I understand your Question... or maybe you are making a statement? But, it sounds like your hard drive (HD) is dead, no good , non useable... So what are your options? Purchase another hard drive, you should have received system backup disk or install disk with your laptop , you can use them to reinstall the operating system (OS) Windows on the new hard drive. There is a slight possibility you could try them (the install disk) to re-install your OS on your original HD, but again it sounds like your HD is dead.
If you have never made a back up of you hard Drive, then all your data (pic, documents, game, contacts) are lost. The problem most people don't understand is if the hard drive crashes for physical reasons, the spring breaks inside, or a diode burns out, then the data on the disk are lost.
You may also take your laptop to a computer repair shop near you and they can tell you more about your options.
Jun 25, 2015 | Hard Computers & Internet
How to recover data from my toshiba 320 hard disk?
Data lost due to unintentional formatting of the drive or when someone knowingly delete some data later on realizing that the data was important, In situations like this one should use a data recovery tool. To know more about data recovery process visit http://www.recoverlostfile.net
Dec 23, 2012 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
How to format my hard drive in dos
Rita,
Most computer recovery disks will perform the formatting for you. (This depends on the Manufacturer and Model though...)
If you put the recovery disk into the computer CD/DVD Drive and restart the computer - to boot to the disk, it should launch the recovery process and warn you that the hard drive will be erased and all data will be lost. This warning step is the recovery disks way of informing you that it will format the drive.
To boot to the CD/DVD you will need to tell the computer to do that. When the computer first turns on, you should see a brief message at the very beginning of the boot up process. The message will say something like: "Press Del for Boot Device" or "Press F12 for Boot Menu" or something of this sort. If your recovery disk is in the drive and you can get to the boot menu by pressing the key the computer prompts you to press, then you should be able to start up with that recovery disk.
Allowing the recovery disk to run through it's full process should format the hard drive and set your computer straight.
Make sure to run all of your updates once the recovery is complete and also make sure to install and update a good anti-virus software of some sort.
Nov 19, 2011 | Computers & Internet
I am using Transcend 320GB USB hard disk. Contents of few folders are accessible and some are not. when i try to open the folder whose contents are not visible, a message pops up saying that disk is not...
Did you try running software from windows to try repairing it? disc scan etc, There is plenty of help on your computer or on the net to repair lost or corrupt files and most of it is free, Treat it like it is the internal hdd on your own computer but tell your computer to scan that disk instead of its own internal hdd, it does work as i use this method myself, Go to start-my computer-you should see your external hdd there, Right click and go down to properties, Click on that and go to tools, Use tools from the drop down menu and try repair it from there, There will be one called check now and tick both boxes, Hope this helps,
Sep 19, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I have a HP Pavilion dV5t-1000 laptop with a Momentus 5400.4 hard drive. All was working fine until today. The computer is now telling me the hard drive does not exist. I connected it to my custom built...
No, the disk doesn't appears in My Computer because the file system on it is completely corrupted - all the data is lost. To see if the hard disk itself is recoverable download, install and run this free program (select the correct disk for testing)
http://www.hdtune.com/files/hdtune_255.exe
Feb 03, 2011 | Seagate Momentus 5400.4 250GB SATA/300...
Driver of kingston datatraveller g2 2 GB is lost so it is not able to open it data contents please tell solution on this problem
Connect it to a different computer.
Copy its files to the 'C:' drive.
Burn a copy of the files to a CD/DVD-writable disk.
Then "format" the device.
Copy the files back onto the device.
Use the CD/DVD disk on your computer.
Dec 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Feke usb size
When the flash memory USB hard drive device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
Mar 21, 2010 | SanDisk 1GB Cruzer Titanium USB Flash...
Whenever i insert an external hard drive, it tells no drivers
It is possible when *********** board is of old model.
you should update your computer's hardware system.
try your hard disk in your friend's computer, if it will work ther, that's mean *********** board can't support your hard disk, try hard disk of small sizes.
Jul 06, 2009 | Toshiba Computers & Internet
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate...
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Jan 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
64 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
