Question about Candy CDC266 Dryer
Candy cic60 condenser dryer
I have an candy dryer it is making a terrible noise when it is turning it is squeaking quite loud when turning both ways any ideas
  • 979 Answers
The drum itself turns on an axle or sprocket. It may need to be oiled. The motor that turns it may be going bad. The windings and bearing could be bad. I assume it is drying O.K.
Posted on Feb 04, 2009
Have an older model amana elec dryer, amana no 10380120, starting making terrible loud noise and not turning clothes. please help
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 10, 2010 | Amana Dryers
Dryer makes a loud squeeking noise when turning one way but not the other had a look thing it might be the motor guide pullys but in not sure?
heatman101
Asker
Nov 20, 2010 | Candy CDV262 Dryer
My dryer makes terrible noise when tumbling. It is a loud squeaking noise. Is it a belt that needs to be replaced?
Loud squeaky noises are usually a dry bearing--in this case, probably the one(s) that hold up the front of the drum. Open the top to inspect, then remove the front panel to replace or repair. Hope this helps!
Oct 23, 2010 | Frigidaire Dryers
Candy cc217-80 condensor dryer manual - I need to replace the belt and not too sure how to get to it
hi iv just bought a second hand condenser dryer its the candy cc2 17 and it squakes and make a loud noise what can i do to fix it??
Sep 23, 2010 | Dryers
Making a terrible loud squeaking problem like a belt is too tight or something....
Hello, I think by your description it's likely the rear drum bearing & hub. It is quite common on frigidaire/white westinghouse made dryer's.**unplug the unit before servicing** Try and search for a tiny little ball bearing at the back of the unit and see if you can isolate the noise is from there. If so you may be ok with some hi-temp silicone based lube for now, (you'll need to apply it from inside anyway, so you might as well replace it) but the bearing assembly probabely needs to be replaced...if that is the source of the squeaking. I hope that helps, Good Luck :)
Oct 29, 2009 | Frigidaire GLER341A Electric Dryer
My dryer works right it's just when it's running
Usually lound screeching and squeaking noises are caused by dry drum rollers. You need to lube the rollers or replace them. When I say lube the roller I mean the shaft and bearing part of the roller.
Sep 24, 2009 | Hotpoint Dryers
I have a candy cic60 reverse action condenser dryer about six years old.when it is switched on i makes a buzzing noise and nothing happens apart from the buzzing,any ideas
my candy dryer when on the light keeps come on to clean fliter and the water contain dont seem to being filling up with water
Jul 07, 2009 | Candy CDC266 Dryer
Loud Noise
heatman101
879dgyj
Dec 18, 2008 | LG DLE5932W Electric Dryer
Candy cic60 01 condenser dryer
check the vent line it may be cloged or bent if this is good then possibly the hi temp sensor may be bad ?
Nov 15, 2007 | Candy CDC266 Dryer
Candy condenser dryer cdc 266
Forget purchasing anything, i had the same problem. Slide the lid back and spary the belt with WD40..... noise goes and works a treat and no money spent!
Justin
Sep 20, 2007 | Candy CDC266 Dryer
Candy CDC266 Dryer Logo
384 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
