Question about American Standard Plumbing
Mixer tap makes a noise like a fog horn when cold water turned on
Oras mixer tap makes a noise like a fog horn when cold water turned on. Hot side OK. Water still working, not leaking. How do i stop the noise ?
  • Anonymous Mar 12, 2014
    cold tap leaks only stops when tap turne on fiercely a few time
    President:
  • 2,692 Answers
Usually happens when the stops and not ballanced(hot and cold pressures going to the faucet). Try ajusting the stops; open more on the hot or close more on the cold.
Posted on Feb 04, 2009
Our bath taps which are a mixer with shower attachment stay really hot if you put the hot on first or really cold if you put the cold on first any idea how to adjust so we can have warm water when turning...
you make no sense. From the picture the water "mixer" is the center lever or is it a diverter valve for the shower and water nozzle below???
The knobs are for hot and cold water??
Jun 08, 2014 | Plumbing
Mira 88 not supplying hot water
may have a screwed up washer seal on the hot side..it will stop the flow to a degree and allow more cold water in..calls for dismantling the entire control or replacing it..
Jan 26, 2014 | Water Heaters
Oliveri mixer taps
turn off the hot and cold water supply, place a container under the sink where the hose meets the Sink mixer.
release the pressure from the tap by opening the tap to let the water out.
use a suitable tool to undo the flexible hose from the underside of the tap, there should be a small "O" ring on it which you will have to replace as the "O" ring is possibly the cause of the leak.
Oct 01, 2013 | Home
I have a Fisher Paykel washer that was leaking water into tub; repair people changed cold water valve but it is still leaking; although not as much. Could it be the nozzle spray holding droplets of...
Hi just read your posting.1st try turning the hot water tap off and see if the water continues to come into the tub.If the water continues to come into the tub then turn the cold tap off.If the water stops coming into the tub after the hot water tap is turned off then you need a hot water valve.If the water stops after the cold tap is turned off then the cold water valve is still faulty.Please reply on how you got on and I will help you further.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
On the back of the mixer tap on my astracast sink has a small hole that seems to be part of th mixer tap is leaking when the cold water is on and not the hot, can you help?
I sounds like the cold side of the faucet has a bad side. Contact them for free parts for that side and directions on how to install. It could be just those rubber seals but my be the actuator for the cold water.
Oct 06, 2010 | Astracast ACR1919MB Rok Composite Kitchen...
We have a neptune bar mixer shower that has been fitted to the wall and plumbed. All the water has been turned back on, the hot water is working fine but nothing is coming through the cold water side. cold...
Possibly switch off hot and cold water then undo cold water flange closest to the outlet and see if water comes out.if it does, tap assembly is faulty. If not, go back to where next available connection to the pipe was made. Work back untill you find the problem.
Aug 05, 2010 | Home
I have mixer taps on my bath, hot water tap doesn't work
you may just have to replace the hot/cold stem
Mar 11, 2010 | Home
Cold water tap not working, house heating not as strong.
Okay let's trouble shoot this problem. The Hot water issue may just be that your Temp. control is not set as high as it was before it was replaced. Find the control on the water heater and check the setting. You can adjust it hotter from there, but it is not recomended to set it all the way to HOT. Just increase it at small adjustments and see if the water gets hotter. The Cold Water Tap issue.....Turn off the Cold and Hot water supply lines to the faucet. Remove the Cold water tap. VERY SLOWLY TURN ON THE COLD WATER SUPPLY and see if you get water coming out of the line. If you get water, then your line is okay. Inspect the valve to see if there is any debris in or on it. Clean and reinstall both taps and turn back on the water. It should work. Now if you turn the water on SLOWLY when the Cold water tap is removed, and no water comes out, Then you know you have an issue with the line going to the cold water side. (Frozen Line, Debris in supply line valve, Broken or Leaking Water Line) I hope this assists you........Joe
Jan 16, 2009 | Plumbing
Plumbing Logo
1,104 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
