LG WFT1071TP Top Load Washer
Problem for LG WFT1071TP Top Load Washer
Water keep refilling
By maretamalan1 on Feb 04, 2009
I have a 7.2kg toploader that I bought two years back. The washmachine keeps draining the water that is coming in and ends up filling the water endlessly cause the level is never reached...meaning I can't do my laundry. Is there a valve or something thats not closing?
Best Solution
posted on Feb 04, 2009
Very Helpful)
jsrock516
Rank: Guru  Washers & Dryers  Expert
Rating: 96%, 6934 votes
This is commonly caused by a condition known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
The washer is filled when the solenoids on the water inlet valve are activated, allowing water to flow through the fill hoses. Once the washer reaches a predetermined level (as determined by the load level selector dial), the pressure switch senses the water level and shuts off the inlet valve. If the pressure switch was causing this problem, your water level would continue to rise to the point that the washer would overflow. If the water inlet valve was defective and would not shut off, you not only would have a washer that would potentially overflow, but it would also continue to fill when the washer was not in use. The key to diagnosing your problem is the fact that the washer continually DRAINS and cannot maintain the water level. Take your drain hose and pull it up from the standpipe. If you had the hose shoved down in the standpipe too far, or if the drain hose was fitted too tight, a sucking sound may be heard as you pull the hose out. You should only have about 6 inches of hose in the drain. There needs to an air gap around the top of the standpipe as well. This prevents a vacuum from forming which causes the water to be siphoned from the wash tub.
Read through the link I provided and let me know if you have questions. If you require additional assistance, please let me know before rarting the solution. I hope this helps you.
Was this helpful?
Yes
No
Popular Solutions for LG WFT1071TP Top Load Washer
Questions and Unsolved Problems for LG WFT1071TP Top Load Washer
Do you recommend LG WFT1071TP Top Load Washer?
Answer
Answer
Top Loader fuzzy logic 5.0kg LG washing machine (model wf-t502A) isn't draining. Not sure where to... (More)
Answer
how do you clean the filters onthe LG top loader Fuzzy Logic
Answer
my lg washing machine wf-s6607tc soon after start washing it stops then spin and drain lights comes.... (More)
Answer
Machine cycle but over flow as if load sensor is broken , The machine does not complete cycle and... (More)
Answer
My fully automatic Fabricare LG machine just stops before the spinning process has to begin. We need... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
