Question about Polycom VSX 7000 Video Conference
Polycom VSX7000 video camera
Camera is out of focus. How do I resolve this ?
Hi there:
This happened to my VSX camera and the fix was simple. I have a VSX 8000 so if your camera is different then mine you might not be able to follow this. This might not work for you but, try it. On the back of the camera you'll find a small little screw. Keep the system on and watch your cameras image. Start to loosen the screw. You'll only have to do it a little bit and the camera should start to focus again. Tighten the screw up (maybe not as tight as it was before) and test to see if it's auto focusing. Also....manually moving the camera around while it was on could have helped as well. Finally....I did not have to do this but if it is not working simply by loosening the screw...I would take it all the way out and remove the little cover or hatch that it holds. Poke around in there a little bit to see if the the focus motor unsticks itself. If you are still under warranty (I was not) don't do the vendor who sold it to you.
Mine's working great now simply by loosening this little screw and tightening it back up.
Posted on Jan 14, 2010
  • 93 Answers
It appears that the camera auto focus motor has jammed or maybe the camera was dropped.the camera needs to opened to see if the motor on the lens assembly is working, there are 2 of them , one is for zoom & the otehr is for focus!!!
Posted on Feb 08, 2009
Polycom VSX7000, do you have to suscribe to Polycom to get anything on screen. I get a bootup sound, but that is it.
No, you do not need to subscribe. Are you sure your a/v cables are connected properly? You might also check on your video source and make sure you are in the correct source.
Jan 18, 2011 | Polycom VSX 7000 Video Conference
My VSX 7000S does not recognize the microphone. It is connected to VSX\r\ncamera by the brown RJ11 cable with ferrite end to the camera but no sound is picked up and system status indicates "no...
You need to go into the audio settings via
Admin Settings
Audio Settings
and make sure Enable Polycom Microphone is checked off.
Reboot and see if your microphone is recognized.
Jan 13, 2011 | Polycom VSX7000 Videoconferencing System...
Fuzzy camera picture for a polycom 7000 camera. Will not focus unless zoomed all the way out
Try reseting the camera, power it down, wait 30 seconds then power it back up again.
Jun 10, 2010 | Polycom VSX 7000 Video Conference
Trying to install a polycom viavideo camera, my windows 7 is nor recognizing it. Where can i download the driver for ir?
The download for the Via Video II is located at the link below. Unfortunately it may not be compatible with Windows 7 as it has been discontinued and is no longer supported by Polycom.
Jan 23, 2010 | Polycom ViaVideo II Webcam
VSX7000 series VC remote site cannot see the video of near end
for video conferencing at such long durations over IP, it is a MUSSSST to have dedicated stable bandwidth at all the locations.if that fails, symptons like the one u experieced are possible.this will generally happen during working hours when bandwith usage by pc's is high!!!!!
Dec 15, 2008 | Polycom VSX 7000 Video Conference
Can not able to dial out any number from Polycom VSX 7000.
Check out the following things:-
1. When dialing a ISDN number, be sure that the call preference has not been set to IP H.323 on the home screen just below the dialing field.
2. Check with your service provider that outwards dialling have been enabled on the lines provided to you.
Dec 03, 2008 | Polycom VSX 7000 Video Conference
Can't get to the home screen
I've just solved that problem in the VSX 7000 of my girlfriend's Job.
Your VSX7000 has at least 4 video outputs, 1 for VGA and Supervideo 1 and Supervideo 2.
Firstly you should try VGA connector, because the main menu may be there, so you could change the configuracion.
If you can't see main screen in any of the output connectors you'll have to use the http tool.
In your internet browser enter the camera IP address, and you'll get the Web Interface of the VSX7000.
It will prompt you for user & password, the default options are "Admin" and your VSX7000 serial number (14 digits) you can find this number under the camera.
Once you're in the Web Main Menu, click on Site Map. There you can choose what you want to see in the screen of Monitor1 (My menus are in Spanish, maybe your menu says something like "screens" but I'm sure you'll find it)
If you choose Monitor/Screen 1 as Svideo, and select it as output for Local, Remote and Content you should see the Main Menu after the VSX7000 Reboots.
I hope it would be useful for you, if you have any problem with this let me know... This VSX7000 is working fine now, so yours should work!
Sep 19, 2007 | Polycom VSX 7000 Video Conference
Polycom VSX 7000 Video Conference Logo
3,124 people viewed this question
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
