Question about Panasonic PT-47WX49 47" Rear Projection Television
Have a 46 inch panasonic projection tv hd
Problem was told to me that i need a power module how much does that cost
  • Panasonic Master
  • 8,617 Answers
Sounds like the tech looking at it wasnt sure what was wrong. Whats the set do when you press power? Does the led blink? If so how many blinks is it blinking? I will try to assist you.
Posted on Feb 04, 2009
Panasonic rear projection 47 inch
hi you are right this is common fault what needs replacing is the convergance ics theirs 2 of them but whils replacng these you will need any resistors checking for damage also as when the ics start to fail then its usually because a resistor has blown somewhere on the board causing the power to rise or fall and this causes the ics to fail
Feb 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Color on tv
If this happens to all the input sources, the main logic board is fired. If this happens to only one input source, only that input source circuit is fired.
It is costly to replace the main logic board. And then there are other components ready to die out soon.
Your set is at least 5 to 6 year old. Have you replace the lamp yet? It is rated for 10,000 hours. Yes, it will fail in about 10,000. Off brand replacement is cheaply made, can cost problem. (mine did). The nut holding the wire to the lamp was loose.
Time for a new TV. A new 46-47 inch LCD is less than a grand.
Apr 01, 2010 | Panasonic PT-50DL54 50" Rear Projection...
We have a 18 month old Panasonic plasma HD tv 46 inches. Without anyone touching anything, the tv will start turning the volume all the way up and then the channels start flipping. We've had the A board...
I know it sounds silly, but try changing the batteries in the remote.
Sometimes when the batteries are going dead they cause the remote to send random commands to the tv.
You may want to do the same thing with other remotes in your house.
If it works great, if not, it only cost a couple of dollars to try...
Good Luck!
Jan 03, 2010 | Televison & Video
Same blinking problem with my 55" HD 1080 Series TV.
That model Mitsubishi is a 65 inch set not 55. And if the blinking you are talking about is the Power LED continually blinking green and otherwise dead it is because the digital module is not booting up. I have repaired many of them and this is done by replacing components in the digital module. Average repair cost is around $200 to $300 depending on where you live. That particular set is well worth the repair. If yours is a 55 inch instead the same still holds true.
Jun 13, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I have a 57 inch zenith hd tv and just recently i started to get a double picture and i was told it wasnt the picture tube what could it be.
No it ie not the picture tube thereis a module inside the tv that needs to be replaced. convergence module it's about $100.00
+ labor
Thank you
JOSE
Aug 17, 2008 | Televison & Video
Think this is worth fixing?
trust ME when i say setting convergence after doing repair takes alot of time to do /you can damage set if you do not have service codes and values/ you also must have the hand unit that comes with set in order to even get into convergence circuit, call your repair shops ask if they have a good blue tube for set and how much would it cost to repair?ARE you sure blue tube has been removed from set.?
Jun 13, 2008 | Panasonic PT-51HX41 51" Rear Projection...
TV is Ghosting
if convergence problem color would be bowed and off. If it is the convergence replace ic stks there are 2 inside tv if you could solder and good at this stuff. parts cost is 30.00 . if you are going to get fixed cost is 300.00 . www.part store.com has parts just give them model number .They can tell you part number.I would pay someone to do this it is trickey.
I think ghosting is ground problem on cable connections check connections and replace cable wire.
thanks doctor video
May 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Panasonic 47 inch rear projection
Have you checked the lamps. Rear projection TV's have bright lamps, that can burn out. If you have had this TV for a while, that is the first thing I would check. If you still have to manual, it should tell you how to check the lamps and which ones you need to order.
These should be special lamps only Panasonic sells. Therefore they might cost a few bills.
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
Panasonic PT-47WX49 47" Rear Projection Television Logo
188 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
