Question about Chaintech : SPT800 P4 Prescott/PT800/SATA/A&L/ATX Motherboard (MOTCH11)
MB starting to show age
I've had this motherboard (chainteck spt-800) for more than 4 years its been through 3 OS'es windows Me/XP/vista the only thing i had to do to get this board ready for vista was to get a sound card the on-board sound was not compatible.
i've been running a celeron D 2.1ghz processor and 2gigs of ram
its had 2 cd/dvd burners
3 hard drives
and 1 floppy drive
i've just upgraded the PSU to 450watts
now for my question i cant seem to get a pinnical hdtv tuner card to work, burn a dvd+R DL, or sync my Ipod nano 5th gen(NOT at the same time now)?
the tv tuner software informed me that my processor was weak it needed 2.6ghz
I can burn a dvd+/-R,RW just fine but i get power issues when i try to burn a DL which my drive supports.(memorex 16x-ddl-ilo ata drive)
and Itunes just crashes the whole computer half way through a sync on my ipod it just locks everything no BSOD
i've already checked the firmware on the dvd burner none avalible for ILO drives
  • 5 more comments
  • james berkhimer Feb 04, 2009
    I found a processor a 3.0ghz socket 478 P4 (prescott) on newegg and im waiting for it to come in the mail
    the ram is as high as it will go by the manufacturer standard 2gb ddr (2X1gb)
    MB has to wait until i can save up 250bucks(proc,mb,ram,video)
    I will look in to a USB2.0 card in the next few days
    my video card is a Nvidia 5200fx (pny) the only one that was availible at bestbuy for AGP I will have to upgrade my MB to get better support it said on the box vista compatible and i figured it was time to retire my ATi radeon 8500(true ATI)
    I've already started to use sATA hard drives and the dvd-burner and the dvd-rom are on there own power rail
    the power supply is a blackwido 450 i guess i can go back to bestbuy and get the blackwido 500 and give the 450 to my sis
    and for the ipod i've found out that alot of people are having the same issue its the itunes software its not compatible with vista (fully)
  • james berkhimer Feb 11, 2010
    sorry for the delay in responding as with money being tight my computer died and after 300 dollars and over a year i got a new computer put together and everything is working now
    the new parts are:
    -foxconn digitalife ELA main board
    -Intel celeron duel core
    -Kingston value ram 2gb ddr2
    -nvidia geforce 9400 gt
    -Windows 7
    the old parts are
    -black widow 450 watt psu made by thermaltake
    -pinnical hdtv tuner (still gripping about the processor but working)
    -maxtor sata 200gb
    -maxtor 160gb pata
    the processor i bought (Pentium 4ht 3.0ghz) went to my sister my aunt and sister got the ddr ram as for chaintech MB trashed the sound card is sitting on my shelf of spare parts
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Are you comfortable or capable of buying from NewEgg online? Because you'll get a better selection of Power Supplies there. I run Cooler Master or Antec True Power power supplies as they're better at delivering power as advertised.
    Many of us with more up to date motherboards, hard drives, CPUs and Display Adapters are installing 750Watt or higher power supplies. For the money spent, its well worth it to have the 'overhead' of power available.
    BTW, is there some question you still need an answer on? We're all just giving you advise at this point and glad to do it. As advice you aren't nagged by our system here to vote on our answers.
    But you sound like a reasonable person with decent user knowledge and are capable of doing your own work. Sometimes we get people here asking questions in this areana you're in that have no experience at all whatsoever. We give them a workable solution and then they vote Thanks for Trying. It really irritats us as we are all rating by our accuracy as you've seen next to our Guru marker. The only vote that raise our accuracy is a FixYa vote so we, me in particular, want to make sure we can communicate so we fully understand your problem, the problems of our customers in this free forum, so our solutions will solve your problem and earn us that four diamond response from you.
    So, yes you could go to the 500Watt PS and be better off. I'm not aware of the Black Widow power supply. I stay on top of hardware and the changes and almost all problems today can be traced back to bad or weak power supplies. So, now that I see that you konw what a power rail is, so many people do not, I feel comfortable working with you.
    Do you have SATA support from your motherboard or add in card. If its the motherboard I suspect it will be version 1 which has burst speeds of 1.5GB whereas the newer SATAs have 3GB burst speeds. That's only on read burst, like from the swap file, the average sustained transfer rate is only on the high side of 100MB, this is only near double a ATA-4. Its when you can create a board driven Raid 1, that two WD SATA Raptors will deliver killer transfer speeds. Then Seagate release a 1.5TB hard drive for around $150 but version 7.11 of the pcb has had a 30% failure rate in the field. Most of these hard drives sold through retail outlets only have a one year warranty, whereas if you purchase off an OEM retainer like New Egg come with three and even five year warranties. The difference is in the user knowledge level and assumptions that are made. A product sold off the shelf could be installed by a real noob whereas a home builder like yourself has more previous experience and Seagate and the others will give you the benefit of the doubt. Whereas, they know IT Techs like myself who've been a member of MS Tech Net for over ten years get unqualifed support over the phone or email from these hard drive makers.
    From what I've read so far, once again, about your responses to us, you have good amatuer knowledge and I'd qualify you right now as a home project builder capable of participating in a Beta program.
    The MS Windows 7 Beta is up for release and the download has been made available for longer than usual and the product key is good for 120 days. That's enough for me to learn where everything has been moved and what has been renamed. Windows 7 is a real improvement on Vista and the Beta is very stable. When it is fully release in May (I believe) it will be worth the upgrade to get off the Vista platform. But, I'd use that opportunity to go 64bit too and take advantage of the AMD x64 dual core or the Phenom II quad core. Those processors and the OS in 64bit too, will allow you to install up to 128GBs of RAM if you wanted to. Most of us are installing 8GBs of RAM on XP64bit and this really screams. I have the Windows 7 64bit OS downloaded I just haven't installed it yet bu will this weekend probably. I have two PCs with 64bit CPUs.
    One of these PCs I have has an AMD motherboard with the AMD chipset and the Radeon cards run really well on that chipset. The Radeon cards now are fully AMD design so long as its a 4000 series board or higher. These are much less expensive than the Nvidia boards and more stable too for running GPU intensive games.
  • Glenn Rogers
    The advise you 've been give is good so far. But, the current IPod software has some nasty bugs that screws with Vista big time. And, with Vista you do not want more than 2GB of RAM as it is, anymore and it causes problems except for the 64bit version.
    You do need a video card that will take over come of the video encoding and decoding. But, I suspect you have an AGP slot and no PCIe slot. That leaves you to a small offerring of AGP cards. Mostly the Nvidia 6200 will do the best job and they're still being made for leagacy systems like yours. You can find them on EBay if you're careful or buy new at New Egg or TigerDirect or just use Google shopping to find one and then research the vendor.
    However, what you really are running into is a power supply issue. 450Watts just won't cut it espcially when your new CPU arrives. The 450Wattss on the sticker is not True steady demand wattage capability, its usually very much lower than that.
    A good True Power 500 or 550 is what to shoot for that you can carry over to your next build and that power supply will have SATA power connectors on it as you will want to migrate to SATA drives too in the future.
    These newer CPUs draw around 65Watts by themselves. When it comes to your Burner, that it a different story. Some DVD burners are good at everything except DL despite what they say and those burners can drwaw some power. If its on the same power rails as a hard drive it will stop a comptuter. It should be connected to its own power cord not sharing connectors with anything else.
    So, the more stuff you add, like a sound card, to the PCI bus and expect to add a larger power CPU your PC will be lucky to run on Vista.
    Can you go back to WindowsXP?
  • mriver7432 May 11, 2010
    what kind of video card do you have and how much of your ram is used for video cause the hdtv tuner has to have a good video card to accelerate the graphics if you have a low end video card it will give you a proccesor error like the one you spoke of
  • 1400Slugg May 11, 2010
    sureley a simple MB / RAM / PROC
    upgrade would fix all issues
    late model USB ports for a start will help all plug in devices
  • 1,602 Answers
Its time to update your motherboard you dont have to be rich to have something as good as the rich one do.
i read a artical in my cpu magizine [computer power users] march 2009 issue, motherboards, cooling systems, fans, cpu, bois updates, so on
Posted on Feb 04, 2009
Testimonial: "after alot of research i decided to upgrade my MB with a foxconn digitalife ELA using pc mag buyers guide"
Asus p4sgx-mx audio driver
  • Model: P4SGX-MX
  • Size: 2.09 Mb
  • Date added: 16-Apr-2009, 07:43
  • Manufacturer: ASUS
  • Device type: Motherboard
  • Operation system: Windows XP
  • MD5: cc496c9fc693f22e1e02bccfcc0e91b9
Asus P4SGX-MX Audio drivers
Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: File size: 2 MB Supported OS: Windows 98SE, Windows ME, Windows 2000, Windows XP
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: File size: 18 MB Supported OS: Windows 98SE, Windows ME, Windows 2000, Windows XP
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: File size: 2 MB Supported OS: Windows 98SE, Windows ME, Windows 2000, Windows XP
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: File size: 3 MB Supported OS: Windows NT
buttondl.pngDownload now Check out this page for a P4SGX-MX Audio driver download. Here you may choose your Asus device driver software. Please keep in mind that you should choose a proper P4SGX-MX Audio Asus device driver. First of all you should know your operating system, vendor name and device model. If you don't know what device you have inside try out this. Try to search for your device driver using PNPid. Open Control Panel-system-hardware-device manager then double click and click details. Use this long digits and letters line to find out what device you have and driver for it. Some drivers on our website may be packed with winzip or winrar programs.
Sep 19, 2011 | ASUS P4SGX-MX Motherboard
I want cheapset drivers
Go to the section "VIA Chipset 4in1 Drivers" and download the chipset driver which matches your OS (i.e Windows XP 32/64 or Windows Vista 32/64). If you are running Windows 7 you should be able to use Vista's driver.
Sep 07, 2011 | MSI P4MAM-L (MS-6787) 400/533 MHZ FSB...
Dear Sirs! I have got Gigabyte GA-EP31-DS3L rev. 2.1 motherboard, with Intel Dual Core E2220 1M_800MHz CPU at 2.4 GHz; 2 pcs of 1 GB GEIL PC6400 800 MHz DDR2 RAM in VALUE KIT2 CL5; Samsung 500 GB 7200 RPM...
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 06, 2011 | Gigabyte (GA-EP31-DS3L) Motherboard
Why is tiger woods pga 07 not working on my windows vista
These are the requirements for this game:
Tiger Woods PGA Tour 07
Publisher: EA Sports
Developer: EA Sports
Minimum System Requirements
OS: Windows 2000/XP
Processor: 800 MHz
Memory: 256 Mb
Hard Drive: 2.3 Gb free
Video Memory: 64 Mb
Sound Card: DirectX Compatible
DirectX: 9.0c
Other Controllers: Game Pad Recommended
DVD Rom Drive
As you can see, Windows Vista is not supported by this game as the OS wasn't out then.
Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated.
Nov 01, 2010 | EA Sports Tiger Woods PGA Tour 07 for...
Can i install windows seven on board D845GVSR
i have installed windows 7 in my motherboard D845GVSR. when the installation finished the display was very poor so i taught to to install xp again . before that i have opend the windows 7 media center .when opening the said that the display was not above 32 mb . .......... .press f2 in starting then search for an option like this "video configuration" and one more option in it like this "video space " starting from 16 mb to 256 mb . the previous mode is 32 mb . change it from 32 MB to 64 MB or higher and u have to save it and restart again the system and u have to change the screen revolution in the windows 7 and the system graphics hve become enabled .
Jan 16, 2010 | Intel D845GVSR Motherboard
Sony Driver
Without the model number the above is meaningless.
Jul 30, 2009 | Sony Computers & Internet
You dont need any driver since your PC is configured as x64 bit processor so all you got to do is get hold of the XP OS which is meant for x64 compatible PC's. The one normally used is 32 bit named as x86. I hope u wont face any difficulty in getting hold of x64 based OS(XP)......sodeep
Jul 30, 2009 | Computers & Internet
Intel 845 GVSR drivers for windows vista
Fix for older motherboards like Intel 845GVSR etc.,
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
Restart your computer > Press DEL Key
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
Apr 09, 2008 | Intel D845GVSR Motherboard
Chaintech : SPT800 P4 Prescott/PT800/SATA/A&L/ATX Motherboard (MOTCH11) Logo
134 people viewed this question
Top Chaintech Computers & Internet Experts
Mark Gough
Alun Cox
Are you a Chaintech Computer and Internet Expert? Answer questions, earn points and help others
