Hiya the door seal is broken (Samsung 6.0kg P1453 - washing machine) -a little section missing out of the rubber - leaks out. Can i fix this myself asparts (door seal) are costly i.e £54?
Hi my name is joyce
Yes you can fix this yourself but you really need to let a specialist do this so you know that it is done so it wont leak. it may costly at first but it will be worth it.
if you want to do it yourself go online and type in hiya.com and go to their website and type in your model # and get your ser# and then call your local dealer in your area that deals in washers of that sort and order part and go to work.. good luck..
thanks
let me know how it turns out and please remember to rate me
joyce
It is so common that the drain leaks in many ways and
is the most problematic fault in a washing machine. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that water has
leaked then as the drain hose pump/valve and fittings are located on the
underside of the machine it is important that you look for possible leaks here.
In some cases the drain hose would be clogged at the drain end to outlet of the
house and so there will be back flushing resulting in overflow to the outside.
Also the drain pump/valve can be clogged or the drain hose clamps can be loose
on the grip which can all cause the leak to occur. Removing and cleaning the
drain pump/valve, tightening of the hose is also very important. Also water can
leak if there are gaps on the front door gaskets and must be checked but this
will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
