Deleted Vista Recovery Partition. Now XP installer can't read HDD
I deleted the Vista Recovery Partition in my HDD using the WinXP SP3 bootable installer. My laptop came with a vista os, and I was able to change it to xp sp3 without any problem. But I needed to reformat my hd for some other reason so I run the XP bootable installer as usual, but decided to delete the recovery partition so I can could use the extra space it was using. After deleting it using the winxp bootable cd installer, the system went to a halt. So I decided to reboot the pc. Now, whenever I reboot it and let the bootable xp installer do its job, I get the usual ''error blue screen''. I hope to hear from you guys, soonest. Thanks in advance!
    New Friend:
System
Posted on Dec 01, 2012
    Problem Solver:
  • 9 Answers
If you have created recovery disk before the deleting of the recovery partition u can format the drive from your bios and create a new recovery partition using the recovery disk if not if your pc has crashed and your recovery partition is gone u will have to get a new operating system software but if your pc is still stable just run the recovery manager and restore to factory settings and it will put recover partition back on your hard disk
Posted on Feb 04, 2009
  • 258 Answers
Hi common problem, assuming you have already tried safe mode (tapping f8 during startup) and are not able to get into system restore, it looks like you have to rebuild using fixboot and fixmbr
see http://icrontic.com/articles/repair_windows_xp
good luck HPC
How to back iertutil.dll when i delete from the recycle bin
you will have to install some software
http://download.cnet.com/easeus-deleted-file-recovery/3000-2248_4-10867160.html
EASEUS Deleted File Recovery is a powerful and free file undeletion solution for Windows 2000, XP, 2003, Vista, 2008, Windows 7. It is capable to recover lost files even after a deletion or even when recycle bin has been emptied. It can undelete files on any valid logical disks visible by operation system. In the case of damaged disk volume or partition, please use EASEUS Data Recovery Wizard. EASEUS Deleted File Recovery is an easy-to-use program with a Graphical User Interface without technical skill requirement through the whole recovery process. Simply launch the software, specify the disk where lost data located, click "Next" button, all the deleted files will be listed. Bonus its free
Hope this helps
Jul 01, 2012 | Computers & Internet
I have installed ubuntu in drive C(66gb) with windows xp,giving 13 gb space to ubuntu and rest to xp .now i have deleted the disk partition for ubuntu of 13 gb .when i start computer it shows grub error-17...
maybe if go to "start" right "my computer" click on "disk mangament" that ubuntu partition u deleted should be there and i think u need to add it to the windows partition allocate or allocated it i think...im not 100% ...make sure u do some reasrch before u make any changes....jus givin u my thoughts
Feb 15, 2011 | Dell Vostro 1014 Notebook
I have put windows 7 onto my acer and i want to put vista back on using my acer disc, the message reeds no bootable device
Have you made the CD/DVD drive the first bootable device?
When you installed windows 7, did you delete the ACER recovery partition on your hard drive.
If this has been deleted, you may need a full copy of windows, not just a restore disc.
Where you having problems with windows 7?
I have found 7 to be far superior to vista
Aug 13, 2010 | Computers & Internet
To create a recovery partition in harddisk
Unfortunately the Recovery partition could not be reacreated manually. But you can recover it by using the Y410 Recovery Disc but that means reinstalling everything and youll end up with windows vista again. You can reinstall XP but do not delete the partition that usually has 10-15GB of space because that is the hidden partition for the recovery. You can call 18774536686. If your computer is out of warranty, it would only cost you 59$ for the recovery disc
Jan 21, 2010 | Lenovo 3000 Y410 Laptop
Hw 2 install winxp in cq61
first delete all partition using partition manager ( download from rapidshare or phazeddl). then install xp it will be ok
Oct 24, 2009 | Compaq Presario Notebook
Compaq CQ40-108TU unable to install XP OS
Prepare a Bootable XP Disc installer.
At first go to BIOS Setup to Boot First Priority the CD/DVD Rom Drive.
After that disabled SATA or RAID Configuration. The Bootable XP Disc Installer could not go on when you don't disable the SATA or RAID Connection.
Don't worry that you are thinking it would not detected the SATA HDD by Bootable Disc but it is. Then follow the instruction.
If i am helpful to you please rate me.
Thank you.
Yboyandrei
Aug 24, 2009 | Compaq Presario Notebook
Installing XP after formatting Vista in Dell Laptop
When you install XP, when you select which drive you want to install it on, you also have the option to create and delete partitions.
When you're asked which drive you want to install on, instead of selecting one you need to delete your C partition (There are keyboard shortcuts displayed at the bottom to tell you how), then use the free space to create as many other partitions as you want.
Make sure you size your partitions correctly, because otherwise you would go over the size capacity of your drive.
After your partitions are created, you can install windows on C. After the installation is complete, make sure to format the other partitions (From My Computer, right-click a drive and select Format) so you can use them.
Aug 12, 2009 | Computers & Internet
One key recovery not working
This problem exist because once the 31GB default partition is formatted NTFS, it reduces in size. So, I found this solution.
1. Boot your machine with Ubuntu LiveCD
2. Go to Disk Utility and remove the C partition (31GB) and do not format it. Just RAW partition.
3. Now, Power off your lenovo Y410.
4. Press the NOVO key to start OneKey recovery and follow the prompts
You should get an option to recover sucessfully.
Enjoy
If works, donate to donations@sapgeeksquad.com on paypal
Thanks
Yatin Bhatt
Oct 17, 2008 | Lenovo 3000 Y410 Notebook
Recovery partition - repair
You have obviously deleted the partition that the laptop could recover from but usually if you are supplied a cd to recover windows, there is normally a drivers folder within the cd but not the aplications, such as anti virus although these are only for a trial period. for things like microsoft works if supplied, are normally on a seperate cd. Without knowledge of your partition software, you should be able to partition the HDD and then copy the files from one drive to another, but the restore may not work as the system files may not weave together when you come to restore. I would imagine it's only the drivers that's youre main concern, which you can install from your other laptop.
Jan 31, 2007 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
950 people viewed this question
David Payne
David Payne
