Question about APC Symmetra Tune-UPS technical support - 1 incident (SY8KRFSH) UPS System
To increase backup in apc symmentra ups
I have an apc symmentra 16kva n+1 ups ,i connected 4 battery packs,now i want increase the backup time to 1 hour what should i do ,is there any option so that i can connect external battery & how many battery & what ah of battery i require.pls help me out in this.
  • oldschoolhol May 11, 2010
    old school hollywood baseball old school hollywood baseball
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 91 Answers
If you want to have 1 Hour back up time with your symmetra 16KVA UPS what you need is to get one additional Symmetra XR Battery frame and a battery pack same as the battery pack installed on your existing Symmetra frame. for the runtime issue you need to compute if how many percent the load that you have right now. From there you will know how many battery packs you need to obtain the 1 hour back up time.
Posted on Aug 14, 2009
    Problem Solver:
  • 21 Answers
Old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Posted on Feb 10, 2009
Apc beeping twice every 2 seconds
The battery inside the APC is "weak", and the "beep" is telling you to replace the battery inside the APC, or, maybe cheaper, to buy a new APC.
Feb 03, 2014 | APC BACKUPS ES BE550G 8Outlet 550VA 330W...
Apc xs1500 beeps 4 times
Check if the unit has a breaker on the back and reset it. The unit doesn't seem to be getting power.
Dec 03, 2012 | APC 1500VA BX1500 8 Outlet UPS UPS System
@MY APC UPS SURT15KRMXLI is not charging after installation on single phase input
we have installed a new ups but the battery light indicates red light even though its on charge
Aug 12, 2011 | APC SMARTUPS RT 15KVA RM 230V...
Apc ups 5k rack option bettery pack sent quotation hai noi ka
You can get the battery pack from the APC WEB site.
Go to this WEB site.
http://www.apc.com/site/apc/index.cfm/ww/?
Aug 03, 2011 | APC Symmetra 5K VA Rack-mountable...
I have an Symmetra RM APC and there is an amber light showing and a beeping about every 30 seconds.
Hi Ewiesemann,
The amber light on the UPS usually means that the unit is 'on battery' -- meaning that input power is affected. Check to make sure that unit is plugged in and check to make sure that a breaker on a panel feeding the UPS power hasn't tripped.
Hope this helps.
Jul 28, 2011 | APC - UPS - Matix/Symmetra Enterprise UPS...
How to upgrade the ups software from apc.com?
i wana increase the charginr of apc su 620 it is 900mah i wana it 4 amp
Oct 12, 2010 | APC BackUPS ES 350 Battery Backup System ...
Matrix 3000 "bottom fan fail" need a replacement fan. APC said they don't have in stock and is discontinued.
The APC Matrix-UPS 3000 Isolation Unit IU bottom fan APC part number appears to be 490-0006-A. There are three OEM parts that APC appears to have used:
NMB Technologies 4715KL-05W-B30-P00
Japan Servo CNDC24B7-34
Sunon KDE2412PMB1-6A
But any fan that has the following specs should work:
119mm x 119mm x 38mm, plastic (black) 94V-0, ball bearing, 2-wire, 24 VDC (9.0V min, 10V to 27.6V), 2800 RPM, 80 CFM min, 41 dbA max
Nov 17, 2009 | APC - UPS - Matix/Symmetra Enterprise UPS...
APC back-ups XS 800 battery backup : warning
Turn it off and unplug it from the wall.
Open it up and make sure that the red and black wires are connected.
If they are the battery needs to be replaced. They are only good for 2-3 years. If you are not comfortable with my instructions, call APC for free support. (800) 555-2725
Vote for this solution if it helps.
Aug 15, 2009 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
Less back up time
I found the following on APC's web-site for the APC Back-UPS, this will hopefully fix the problem:
You can also perform a manual runtime calibration. This could be done if you have changed your equipment load or battery. Stop the PowerChute software from running; disconnect the serial cable between the computer and UPS. Next unplug the UPS from the wall and let it run on battery until it reaches low battery. Once it reaches low battery plug it back into the wall outlet and let it recharge. Recharge time can take up to 4 hours.
from link: http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_faqid=2819&p_created=1048797826&p_sid=tANR-rxj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9MCZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yZWNhbGlicmF0ZQ**&p_li=&p_topview=1
Mar 31, 2009 | APC Back-UPS RS 800VA UPS System
Back up problem
The time will lower the longer u keep using it. Every (Chemical) battery needs to be replaced periodically and maybe its time to change your UPS batteries too. Since you were using double battery, it is supposed to be replaced every 4 yrs or so if it is used regularly.....sodeep
Mar 31, 2009 | APC Smart-UPS SUA1000 1000VA USB&Serial...
APC Symmetra Tune-UPS technical support - 1 incident (SY8KRFSH) UPS System Logo
355 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
