Question about Cars & Co Cars and Co Cars Water Slide Inflatable
Leakage in inflatable toy
There is a leakage in an air inflatable vinyl toy of my baby. i have run out of the patches included in the kit. need to repair it kindly help
    Problem Solver:
  • 16 Answers
Go to a place that sells pool supplies they have the kits for that kind of thing. Best of luck!
Posted on Feb 07, 2009
How do I apply the patching material with this product?
The package contains no instructions. clean surface with alcohol and let dry completely. I left my air mattress with very low inflation.
I cut a patch that covered well on every side. Mine was a n inch split on a seam. I applied glue to the slit and surrounding area, also to the entire patch. I waited about 30 seconds, just enough to reduce the fluid pressure, and met the surfaces, smoothing them out. I put some air in after a couple hours, the next day inflated as usual. so far, so good.
Jun 28, 2014 | Mountain Trails Airbed Repair Kit [80800]...
When using the vinyl patch kit to repair a hole in the inflatable ring, should the ring be inflated or defalted to achieve the best results? Also, if you are repairing for the 2nd or 3rd time- is there...
Repair deflated to prevent air bubbles and it will leak... I've used 3M adhesive remover.. Comes in small 6 oz can.. Home Depot. and when repairing, use a clamp similar to this style in the picture I attached.. Let dry for several hrs... Hope this works for you!! If it helps please rate!!!
Jul 21, 2011 | Intex Easy Set Pool 15x36
How do I fix a hole the size of a quarter on the Little Tikes Inflatable bouncer
real quick duck tape.for longer re-pair tire patch kit they have a selection of sizes in the good one's if you cant find one go to repair shop and ask for a large pacth dont follow patch intructions there is no need to try to scuff up that thin nylon. just apply rubber cement then the patch and allow 24 hrs drying time before use
Nov 21, 2010 | Little Tikes Jump 'n Slide Inflatable...
I have two holes in the bottom of my pool how do I fix them
The easiest way to patch a hole in a vinyl pool liner is with the water still in the pool. With an inexpensive underwater repair kit, some swimming goggles and a few hours to allow the patch to cure, you will be back to enjoying your aquatic playground. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Pool repair kit (underwater) Rag Scissors Swimsuit Swimming goggles
  1. Step 1 Locate the tear in the liner. You may need to get into the pool and examine the surface wearing swimming goggles.
  2. Step 2 Read the patching kit instructions thoroughly before starting the job.
  3. Step 3 Clean debris from the area around the tear using a rag.
  4. Step 4 Use scissors to cut a patch for the hole. Use the vinyl from the repair kit to for the patch. Be sure it is at least 2 inches in diameter and will cover the entire hole.
  5. Step 5 Use applicator brush that comes with kit to apply adhesive to the back of the vinyl patch. Do not apply too much adhesive or the patch will not cure properly.
  6. Step 6 Fold the patch in half. The adhesive should be on the inside of the fold.
  7. Step 7 Enter the pool2_bing.gif water and relocate the area in need of patching. If hole is accessible from the outside of the pool, there is no need to get into water.
  8. Step 8 Hold patch underwater as close to the hole as possible. Unfold patch while underwater and apply to the hole.
  9. Step 9 Press the patch firmly while smoothing it from the center to the outside edges. This will help remove any excess air bubbles or water from under the patch surface.
  10. Step 10 Let patch cure as indicated on repair kit instructions.
Mar 29, 2010 | Intex Complete Easy Set Pool Kits at...
Problem with tires ,air is escaping
Pick up a kit for bicycle repair. Take the wheel off, deflate, pull the wheel from the rim and remove the tube. Pump the tube up a little, place under water and look for the bubbles. Once you find the bubbles, patch with the bike tire repair kit, deflate, put the tube back in, reattach tire to rim and inflate.
Apr 10, 2009 | Bertini Baby Gear
Vinyl air
I have a vinyl towable tube inflated with air.....I need to know how the best way is to patch this to hold air under pressure
Dec 01, 2008 | 3M SportsStuff Speedzone 3 Inflatable...
Infatable canoe
Inflatable canoes have considerable appeal for certain uses. When folded they are quite compact and their weight - about twenty to thirty pounds - makes them ideal for toting to remote fishing waters or for storage in today's small car trunks. The better-quality versions are made of heavy-duty vinyl-coated polyester, or PVC, with multiple air compartments (so if one compartment springs a leak, you still have some flotation). Restrictions include speed, since inflatables are relatively slow, and they have minimal carrying capacity. Repair kits are a must on most trips. Also, you will want to have a foot pump to inflate the canoe before starting out.
Cars & Co Cars and Co Cars Water Slide Inflatable Logo
248 people viewed this question
Top Cars & Co Toys Experts
Adam Fjeld
Adam Fjeld
Tom Chichester
Are you a Cars & Co Toy Expert? Answer questions, earn points and help others
