Question about Dell Inspiron 1000 Notebook
Inspiron 1000 LCD goes black when moved, seemed to work fine a few days ago and just went... I can start the laptop just fine but when the lcd lid is move backwards or forwards it goes black alothough the power light stays on. After looking about online came across some fixes, took apart the LCD screen and checked all connections, no such luck. Screwed it all back together and tried the power again, but this time decided to prod and press to see if a connection or anything was loose, weirdly pressing the middle of the reverse side of the LCD screen, the dell logo, it seemed to make a connection and come on. But then by moving the LCD screen it just happens again.
    Sergeant:
  • 180 Answers
My friend had a laptop that did something similar so i got him an lcd ribbon cable replacement off ebay and that fixed it. i dont know if thats whats wrong with yours, but its a possibility. here is a link to a cable on ebay
http://cgi.ebay.com/DELL-INSPIRON-1000-15-LCD-VIDEO-CABLE-P-N-DD0VM5LCOO1_W0QQitemZ350002984955QQcmdZViewItemQQptZPCA_Cables_Adapters?_trksid=p3286.m20.l1116
Posted on Feb 04, 2009
My screen on the advent roma 1000 goes dark
The usual culprits are loose connections (this only happens when the lid is moved forwards or backwards). The other is the LCD inverter getting too hot.
In both cases you will need to disassemble the laptop lid to check the leads and the inverter itself for dry joints.
If you're not comfortable with disassembling the laptop yourself then i recommend that you take it to a reputable repair store to have it looked at.
Regards.
Apr 12, 2010 | Computers & Internet
Hi, I have a dell inspiron 5100. I have two problems. 1) My screen is completely black and I have to use an external monitor. When I start my laptop, I can see the Dell Logo and after that is when...
for your video problem, you may be stuck in a different mode try holding the Fn key and hit F8 this toggles through the modes
1 - LCD on laptop only
2 - LCD and external Monitor
3 - External monitor Only
if this does not work you may have a LCD issue with the laptop .. let me know how it goes first
Feb 02, 2010 | Dell Inspiron 5100 Laptop
My screen on my Dell Inspiron Notebook went black. But I can barely see on the screen that the computer ran a problem check and said my computer was having a problem starting.
The invertor lamp has gone bad, so you would need to replace the LCD screen. there is nothing else you can do. try to connect an external monitor adn then press Fn + F8 to switch the video to the external monitor. if the image on the external monitor is fine then its the lcd. if the external monitor has the same image then motherboard problem. you can also try Fn + Up arrow key to increase the brightness.
Oct 16, 2009 | Dell Inspiron 1000 Notebook
Possible water or hard drive damage to Dell Inspiron 1000 Laptop
its fryed the GPU, sorry it won't work anymore, unless a miracle happens. If it was off and you left it off until it completely dried out (6-7 days) it would of still worked.
Sep 27, 2009 | Dell Inspiron 1000 Notebook
Dell Inspiron E1505 shows green pixels instead of black
the color pixels are different sections in the screen and the green section might be cracked
Apr 24, 2009 | Dell Inspiron E1505 Notebook
Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Apr 07, 2009 | IBM ThinkPad T42 Notebook
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
Dell inspiron 1000 lcd screen problems
The owners manual has some useful information. http://support.euro.dell.com/support/edocs/systems/ins1000/en/index.htm
Sep 07, 2007 | Computers & Internet
Dell Inspiron 1000 Notebook Logo
256 people viewed this question
Alun Cox
