Question about Dryers
No dial on maytag dryer
Old maytag dryer model #ADE309, serial#820866CV. i'm missing the only dial on dryer. i would like a picture or diagram to know which and what the setting is. fast response would be appreciated as i have 3 teenagers and 6 mon. old thank you
  • 547 Answers
Heres what you do perm press is top right then delicates then airdry so start your dryer in the top right some where and when it stops mark it on face where it stoped and move it to start next cycle and repeat tell done
Posted on Feb 11, 2009
I need a diagram of how the drum belt is installed on a maytag centennial dryer. Mine came off and I don't know how to put back on.
Hi c ellerts..
Here is the picture of the routing of your Maytag..
You can get this at the following wepage
Please take time to rate me thumbs up
http://www.expertappliance.com/dryerbeltconfiguration.html
Sep 12, 2011 | Maytag Dryers
Trying to replace the dryer belt forgot how the old one came off b/c it broke. not sure how to get it back on to the pullys. maytag dryer model de7600.
This link is a listing of diagrams of belt configuration on various brand dryers the diagram for how the belt goes on the motor/idler pulley on the Maytag brand is going to be diagram E
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramE
GENE
Aug 31, 2011 | Maytag Dryers
I need the diagram that comes with the dryer. Maytag Netune Model MCE8000AYW
depending on the serise which is the first two numbers of the serial number here is the diagram http://lookup.bellparts.com/diagramenlarge/2/0/561302/91934
Hope this helps
Jun 18, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Is their a picture diagram of how to replace dryer belt on maytay dryer model LDE9824ACE?
Maytag belts are counter intuitive. They give me trouble even though I've done hundreds of them. Your model should look like the one in the picture below. I assume you know how to get to the belt but if not there are 2 screws at the bottom of the front panel you remove. Then lift the bottom of the panel up and out and it will come off. You will have to undo some other brackets to get to the drum
The belt goes on 'upside down' on maytag, meaning that the tread faces up. You should be able to see where the old belt was riding from the marks on the drum, just make sure it doesn't slip into the groove. Put it back together and undo the panel on the back, you should see this.
That should be enough to show you where it goes. Pull the pulley over to release the tension and align the belt as shown. Replace the cover and enjoy your dryer.
Cheers
Oct 06, 2010 | Maytag Dryers
1991 Maytag dryer Model #LD 68424AAL Serial # A0190126HY
Are you sure that you hooked the belt up correctly, as it sounds like you may have missed the tensioner pulley. As this will tighten the belt around the middle of the drum
Jul 20, 2010 | Maytag Dryers
I need a diagram or a picture of how a dryer belt looks like on the motor. model number DE482. i just need to see a picture of how the belt looks going through the pulley and motor
The model number you provided crosses to a Maytag. If this is correct, go to repairclinic.com and click on the "Repair Help" link. On the following page, look for the Dryer Belt Diagrams link under the Special Features section. Scroll down to Maytag and you will see the drawing you need under Diagram E. I hope you find this helpful. Let me know if you have any questions.
Sep 08, 2009 | Dryers
I need to know how old my dryer is serial number is 28676546YM
It is determined by the last letters of the serial number. The first letter is the YEAR, the second letter is the MONTH. The years will recycle, however. This serial number letter designation was first used in 1976, then repeated in 2000. So...if your dryer is a fairly newer model, it was manufactured in November of 2000. I hope this answers your question.
Jun 02, 2009 | Maytag Dryers
Timer problem
Found on partselect.com MAYTAG
Wiring diagrams:
http://www.partselect.com/Schematics/Maytag/52485.gif
data on the whole thing:
7 diagrams
Sep 24, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
