Question about Sony Xplod XM-554ZR Car Audio Amplifier
Toyota corolla 1995 sterio fuse proublem
My car was off i was putting my dash board in a wire touched another wire and it smoked it didnt smell but my light from the inside of my car wont turn on and my sterio wont turn back on what happend
  • 323 Answers
Trying replacing the radio fuse under your dash. You have blown the radio fuse, and I believe the dome light is on that fuse as well.
Posted on Feb 11, 2009
How do I replace cabin air filter for 1995 corolla
your guessing, because it didnt in ours, USA.
its an old car, all old cars smell, how could they not?
do tell.
but if its coming from vents, the spray the chambers with A./C condensate tray flush .
google that, its not easy to do.
the system is closed, and very hard to gain access.'
Feb 16, 2014 | 1995 Toyota Corolla
I have a 04 Toyota Tacoma. I have short in the dimmer switch.
It cold just be a fuse that is loose in the fuse box causing the dash lights to come on and off. Or potentially a loose wire from the fuse box the dash lights.
Oct 07, 2009 | 2001 Toyota Corolla
95 Corolla Blower works in lowest two positions ONLY
one fuse, but your have a resistor block somehwere under the glovebox area, some of the resistance wires on the block may be damaged or gone. this is a pretty common problem. pull the block out and look at it if all the wires are connected, then your problem is somewhere else, like the switch in the dash.
May 11, 2009 | 1995 Toyota Corolla
Hi where is ecu unit located on 1996 corolla and if i take out what type of shop or auto place like autozone(california) would be able to test? Thanks
i know in some corolla models the ecu is under the centre console say under the sterio area,,if not then its either in the left or right side dash under glove box or kick pannels try both sides...
Apr 08, 2009 | 1995 Toyota Corolla
1995 toyota corolla dx 1.6 ac not working
AC units in vehicles are sensative components. It is highly recommended that a certified mechanic recharge or repair your system. As I recommend to others for system problems and malfunctions, I suggest taking your car to a mechanic or local auto parts store and have a diagnostics test done to determine what this problem (if any) is found. It may just be the switch in the swtich board behind the dash. You mentions a noise and a smell, which to me, indicates that the compressor (AC pump) is now faulty, however this will only be determined upon diagnosis by a certified mechanic.
Mar 31, 2009 | 1995 Toyota Corolla
1995 toyota corolla dx ac probelm
Well if the fuse is blown, replace the fuse. Check the belts to see if one broke and replace it.
Mar 30, 2009 | 1995 Toyota Corolla
The reostat that controls dome light and dash lighting-meltdown
As the voltage from the battery drops, the starter will draw more current, which may have caused the fuse fry - more likely, the connection between the fuse and the socket was worn, causing an arc in the socket, effectively welding the fuse to the socket. You can try using a piece of wire to jump across the two silver tabs on the top of the fuse, and seeing if you can start the car, but eventually, that fuse has to come out.
Mar 12, 2009 | 2005 Toyota Corolla
My 1995 Toyota Corolla Stalls
change the distributor, plugs and wires.
Jan 03, 2009 | 1995 Toyota Corolla
Sony Xplod XM-554ZR Car Audio Amplifier Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
