Make sure you selected the correct paper size settings in your printing program and printer software.
Run a print head nozzle check to see if any of the nozzles are clogged. Then clean the print head, if necessary.
If a blank page exists in a document you are printing and you want to skip printing it, selectSkip Blank Pagesetting in your printer software.
Do one of the following:
Windows 7: Click, and selectDevices and Printers.
Windows Vista: Click, and selectControl Panel(or point toSettingsand then selectControl Panel). SelectPrinter(underHardware and Sound) orPrinters.
Windows XP: ClickStart, and selectControl Panel(or point toSettingsand then selectControl Panel). SelectPrinters and Other Hardware(if available) and thenPrinters and Faxes.
Right-click your printer icon, and then selectPrinting Preferences.
Click theMaintenancetab, then select theSpeed & Progressbutton.
In the Settings area, click on theSkip Blank Page.
ClickOKas necessary to save your settings.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us ForEpson Printer Support
When your printer seems to be skipping lines it's mostly because your printhead needs cleaning. This cleaning must be done ONLY by using the printer utility on the PC. If you cleaned them manually you might have damaged the ink cartridges or the printer itself. Try replacing the ink cartridges and trying again.
is this a case of the dots are missing for a valid line, or do you mean a line feed is added at the end of a line, ie you get 3 lines of text occupying 4 lines of space , or 4 lines of text occupies 4 lines of space, but one line has no printed dots on it? to make it more obvious, what does a document with say text thats 3cm tall look like? as it sounds to me like contacts need cleaning.. *** note for info: do not rely on printouts from within a BROWSER as that may have unpredictable results. All text will be treated as a large block of PIXELS and Not TEXT. also Non Printer fonts could cause similar issues.
I first oiled the bar once more and while the printer was off, moved the head across the bar forcefully several times until it felt the ease to move. I then typed a document with numbers 1 to 10 each number typed two lines below the other and tried printing this document several times. This worked perfectly and the printer is now in order.
