Question about Linksys SRW2008P 8-Port Gigabit Ethernet Switch (00745883571024)
How to reset settings of linksys srw2008p 8 port switch.
I changed the managable ip address, after that i cant access the switch.so i need to cahnge the ip address.
  • 106 Answers
Hmm.. router? try to check the router if it has an reset switch then press it with in 5-10 seconds...
Posted on Feb 04, 2009
Linksys SRW2008P 8-Port Gigabit Ethernet Switch Currently two of the ports do not work, can anyone help?
Not much you can do when you have dead ports on a switch but just to replace the whole switch. The cost of having someone take it apart and repair/replace the dead ports will probably cost more than a new switch.
Mar 09, 2011 | Linksys SRW2008P 8-Port Gigabit Ethernet...
Unable to access setup for my linksys by entering 192.168.1.1, not sure whats wrong
For information on how to change your router's password, click here. All Linksys routers have built-in web-based setup pages that allow the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router's Web-Based Setup Page
NOTE: To learn how to reset your device to factory default, click here.
Step 1:
Open a web browser such as Internet Explorer.
3714-015.png Step 2:
Go to the Address bar and enter your router's IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
  • Running the router's setup CD.
  • Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
  • Check the router's IP address.
  • Press the Reset button at the back of the router for 30 seconds.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password, type "admin" (this is the default user name and password), then click OK.
4525-003.png NOTE: If the user name and password of the router has been changed, type the router's new user name and password on both fields instead. In case the router login is forgotten, you will to reset the router.
NOTE: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the username and password will be "admin" after resetting. To reconfigure the router, refer to the links below:
  • To configure the router with DSL ISP, click here.
  • To configure the router with Cable ISP, click here.
Nov 13, 2010 | Linksys Wireless-G WRT54G Router
I need to get into my nat settings
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router's web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or4 ).
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Windows XP
Windows 7
NOTE:
If the password of the router has been changed, type the router's new password in the Password field instead.
The router's password can be changed by:
i. Running the router's setup CD. Click here to learn how to download firmware.
ii. Changing it on the router's web-based setup page. Click here to learn how to change password on the web-based setup page.
Unable to Access the Router's Web-Based Setup Page
Reset your router for 30 seconds. Try accessing again using the default IP address "192.168.1.1". If you are encountering problems accessing the router's web-based setup page, click here.
Related Articles:
Setting-Up WPA Wireless Security on a Linksys Router
Changing the Wireless Network's Name (SSID) on a Linksys Router
Setting-Up a Router with DSL Internet Service
Downloading at Linksys by Cisco Support Site
Nov 09, 2010 | Linksys Wireless-N WRT150N Router
Linksys no longer appears on my laptop for some reason. how do i restore it. i can't go on line without it?
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 08, 2010 | Linksys WRT160N Wireless Router
How do I find Key# for a new PC. The PC with the actual LInksys Admin Program was on PC that crashed and couldn't be fixed
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
Forgot user name and password
Step 1:
Step 2:
NOTE
Step 3:
Windows XP
Windows 7
NOTE:
Related Articles:
Nov 06, 2010 | Linksys Wireless-G WRT54G Router
How do I cahnge the ip address on the linksys spa941 when it failed to registered: it is not picking up ip address from the switch.it was working before change the switch
Confirmed modelLinksys IP Phone SPA941 and SPA962 with SPA932
Linksys IP PhoneThis document explains how to use Brekeke SIP Server with the Linksys IP Phone SPA hard phone .
The Standard features include two active line appearances, call forwarding, redialing, speed dialing, transferring calls, conference calling and accessing voice mail. For more information regarding this product please go to www.linksys.com
Configure Linksys PhoneSet up your Linksys phone with a fixed IP address (e.g. 192.168.0.15) and subnet mask (e.g. 255.255.255.0).
Once the IP address is configured you can access phone webpage by its IP from web browser (e.g. http://192.168.0.15). Network SetupClick on "Admin Login", then select “System" tab. Sign Static IP, Gateway and NetMask.
Use the following data as an example
  • Static IP: Linksys phone IP (e.g. 192.168.0.17)
  • Netmask: 255.255.255.0
  • Gateway: not needed if SIP Server is in the same LAN as Linksys phone
  • Click on [Submit all changes] button now to reboot you phone,
    or after whole setup is finished
Phone ConfigurationSelect tab Ext1 or Ext2 and enter SIP server information and sign extension number
Use the following as an example to complete the phone configuration.
  • Proxy and Registration:
    • Proxy: Brekeke SIP Server’s IP address (e.g. 192.168.0.69)
    • Register: Yes
  • Subscriber Information:
    • Display Name: extension number or Name (e.g. 400 or Alice)
    • User ID: extension number (e.g. 400)
    • If user authentication is set on at Brekeke SIP Server,
      type in the same information at Auth ID and Password as what you set at SIP Server side
      and Use Auth ID: Yes
  • click [Submit All Changes] button to restart the phone
phoneconfig.gif Brekeke SIP Server’s Registration PageClick the [Registered Clients] tab at Brekeke SIP Server admintool.
The Linksys IP Phone SPA941 Phone is registered with Brekeke SIP Server.
Jun 09, 2010 | Linksys SPA941 IP Phone
Does this switch have DHCP server? that is plug in your laptop and obtain address automatically from the switch? Thanks
No, switches seldom/never have a DHCP server in them, usually you make ONE PC the master and enable DHCP on that one, and disable it on all the others. However ALL Routers DO have DHCP.
Feb 23, 2010 | Linksys SRW2008P 8-Port Gigabit Ethernet...
I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Yes, it must be attached to the network 0. Install the yellow machine software on the PC 1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8. 2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears. 3.Click Edit. 4.Select Yes to Enable LAN Interface. Default: Yes (Enabled) • If you select No, all other LAN option fields are blocked. • If you disable the LAN Interface, the only access to the Yellow Machine appliance is through the WAN port. Anthology Solutions does not recommend this configuration. 5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled) 6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address • Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine appliance connects to either a router that has DHCP service enabled or to a cable modem. This setting makes the Yellow Machine appliance a DHCP client on your network. • Obtain IP Address from ADSL provider is greyed out. • Choose Static IP Address if your network is locally defined and controlled and does not use DHCP services. Type the IP address manually. 7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply. 8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
Jan 26, 2010 | Anthology Solutions Yellow Machine P400T...
PC2716 Connectivity
Goto start
Open control panel
Open network connection (XP)
Right click on Local Area connection
Goto properties
click on Internet protocol TCP/IP
Click on properties
Try to change the Ip address on that window
If it does not make any difference then TRy to disable the firewall that is installed on the computer.
Jun 04, 2008 | Dell PowerConnect 2716 16-Port Gigabit...
Linksys SRW2008P 8-Port Gigabit Ethernet Switch (00745883571024) Logo
1,271 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
