Question about HP Compaq Presario V2000 Notebook
Compaq persario v2000 will not boot up.
When I turn it on the power light comes on, the fan starts, the HD spins up and the CD drive constanly runs like it is looking for a disk (It stops if I put a disk in it). Also the caps light and num lock lights blink constantly. The screen stays dark and it will not do anything. Any advice will be appreciated.
  • glennmcclana Feb 04, 2009
    Thanks for the suggestion Harry. But, the system doesn't seem to get to the boot rom process before it stops the boot process. I don't know if the flashing numlock and capslock lights indicate anything or not. I'm starting to think that the mother board or maybe the processor, or both are bad. Any additional advice is still appreciated.
  • 63 Answers
Press F2 or Del key to get into Bois settings. Reset it to defaults by pressing F7 or look for the option on top of the window. F10 save & exit. See if it works.. otherwise try windows repair/reinstall
Posted on Feb 04, 2009
How do I remove/replace the ram modules on compaq persario V2000?
Just remove the power cord, remove the case, then you will see the memory inside the slots. Release the catches on both ends of the memory then pull it out.
Maybe one of the memory chips is bad or one of the slots is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 02, 2012 | HP Compaq dc5000 Small Form Factor PC...
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
Compaq Presario V2000 will not boot.
Remove the battery and just leave it off the computer, then plug in the power cord and try it. If it works with no battery...the battery is completely dead and you need to replace.
Mar 08, 2010 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 laptop stuck in hibernate or sleep mode. Power light, battery charge light and HD lights are all on, nothing on screen, no working sound of HD. I have unplugged/plugged, taken the...
Try booting into the BIOS Screen and resetting to factory defaults. If that fails suggest swapping the hard drive out and re-install the Operating System - Save your old data and migrate the data off the old drive. You can buy an external drive adapter to connect the harddrive to a USB port to migrate you data.
Good Luck!
Sep 09, 2009 | Compaq Presario 1275 Notebook
Persario V2000 cooling fan
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Use the table of contents to skip to where it shows you how to start disassembling it. Be sure you organize and label all of your screws accordingly so that when you have to put it back together, you dont have extra ones.
Page 160 is when it gets into disassembling the fan.
Be careful!! Take your time.
Aug 04, 2009 | HP Compaq Presario V2000 Notebook
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
I have a compaq persario v2000 that will not turn on.
1. The power-connector has broken-away from the motherboard. So, no power reaches the motherboard.
2. Dead motherboard.
3. Dead CPU
Good luck.
Oct 12, 2008 | Compaq Presario 1200,1600 (297657-001)...
Unmounable boot volume
This is an operating system error, and you will need an operating system disc. You can try to repair or reinstall the operating system, but most likely the hard drive has failed and will need replacing.
Jul 19, 2008 | HP Compaq Presario V2000 Notebook
Computer won't fully powerup
If you have access to the internet, and a floppy or CD-ROM drive in the notebook, download a memory-test program and write or burn it. If the notebook successfully runs the memory test, then you have reason to consider the microprocessor memory and general motherboard OK, and to suspect the hard drive.
To boot from a CD-Rom you might have to select that option in the notebook's CMOS. By the way, your question did not say if you could access the CMOS setup menu. But try that also.
Jul 14, 2008 | HP Compaq Presario V2000 Notebook
Compaq v2000
Do u have installed recently, some software?
Try to boot up pressing the F8 button, when the menu appears select the option "Windows in safe mode" if u can boot to windows. View our software installed.
If it is not software try, boot whit the windows installation disk enter to the setup and select the option repair, u will go to a DOS prompted window (all black whit white letters) must appear "c:\"
used the command "chkdsk /f /r" let it run he will try to find any problem in the disk.
Nov 08, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
227 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
