Question about Citizen 76mm-5.0LPS-40COL-PARALLEL-BLACK-TEARBAR Printer
Can't raise flame level
I have a Dearborn gas space heater. It won't let me change the level of the flame. It is tiny tiny. Or not at all. I fear that it is leaking because of the small flame there. I don't have any other means of heat.
    New Friend:
I am having the same problem. Did u ever figure out how to fix it?
Posted on Jan 17, 2018
Obviously, if you read my post, I DIDN'T solve the problem because the problem WASN'T with a PRINTER but with a HEATER. I know that there are Dearborn heaters all over the place, but for some reason your site doesn't want to address them.
Posted on Feb 04, 2009
I have an old dearborn heater we pulled it out of the garage After testing it,the dearborn works but the hose doesnt seal to the gas connection. Do I just use the yellow gas tape for a clean seal?
I have a little tube of stuff called Goop is another one that I put a little on the threads and tighten up. I like it better than the pipe tape. There are different sealants that work as well.
Jan 02, 2018 | Heating & Cooling
I have a large dearborn heater(da-6065e) 65000 btu that I want to convert to propane. I need to know the orifice sizes I need. Most haven't heard of one this large.
there is a site --www.eastwaysales.com>products
that have spares for your heater including propane use spares
try contacting them and seeing if jets are available for propane gas
you could alsays contact a local gas fitter that does conversion from one gas to the other as all it entails is a new jet size ( larger for natural gas) and a repositioning of the air shroud to get the gas air mixture right to get the blue flame
gas fitter should have a chart for jet sizes required for certain gas flows for btu unis
Dec 14, 2016 | Heating & Cooling
Why does the heater turn off?
If it's thermostatically controlled, if shuts off the burner when it reaches the set temperature. Is the pilot flame going out too? These heaters require a certain amount of fresh air to operate properly. If the oxygen level gets too low, it is designed to shut off completely for your safety.
Mar 15, 2015 | Procom 10K BTU, Vent Free, 2 Plaque...
My gas Dearborn model#drc40mc pilot light stays lit.when I turn to on position and heater comes on , it burns high , even on low number setting, then after few seconds goes out taking pilot out also
clean/replace the flame sensor. Your heater doesn't recognize that it has lit and continues to try and light the gas. when the sensor doesn't tell the 'brain' it lit? it shuts down the gas for safety reasons.
Oct 19, 2014 | Heating & Cooling
Model md200tbe shuts off, pilot and burner
1) Try blowing it out with a hair dryer. Dust does lots of weird things to gas heaters.
2) There is a thermocouple that opens when it is hot and makes the gas keep flowing. It is a small metal tube that sits directly in the flame. When it heats up, the gas flows. If that is shot, then it won't keep the gas flowing, so it will turn off when you let go of the button. Try tapping it lightly with the tip of a screwdriver to knock it loose. There is about a 10% chance that this might fix it temporarily until you can get a new one.
Mar 22, 2012 | Blue Flame Heating & Cooling
Have a dearborn ventless natural gas heater that is probably 100 years old that has been used every winter here recently i am getting a fummy odor from it i have cleaned gas valve raidants and burners did...
I t sound to me as if the heat exchanger is beginning to fail. do you have carbon monoxide detectors? If not please get some. Having the unit inspected by the gas company will not hurt.While specking with the gas company ask if the have added different oderants to the gas supply. Please play it safe with this guy and have the inspection.
Feb 10, 2011 | Heating & Cooling
What is making my gas space heater burn blue flames up above the bricks?
The gas pressure is too high...
Lower the regulator gas pressure or
adjust the pressure at the gas valve down.
heatman101
Jan 13, 2011 | Desa International Unvented Gas Space...
Charmglow CGL300TQ Keep shutting off after a minute???
Not too familiar with this product, but it looks like a vent free heater. ALL vent free heaters are required to have an ODS pilot light. These pilots monitor the oxygen level in the room and if it detects a low oxygen level, it shuts down the whole heater. This is what I think is really happening. And the solution is simple. Near the rear of the metal tube where the pilot light flame comes out, you will find two very small holes. If these holes get even a little plugged up with dust you will have this problem. Just get a can of air or use an air compressor and blow air through these holes. I bet that this will solve your problem. It is also a good idea to keep the area around your heater clean and free of dust. I have a free standing gas log heater and at the start of each season I take the logs out and vacuum everything, inside and out, and also underneath the unit. Then I use my air compressor to blow out any remaining dust, especially around the pilot light, and of course, I then blow air through the two tiny holes in the pilot light tube. Since I started doing this, I have not had any problems with my heater.
Dec 30, 2010 | Blue Flame Charmglow 30K BTU NG Vent Free ...
Pilot and Burner shut off at same time at various run times.
sounds like your pilot saftey is working.the pilot flame heats a device called a thermacoupler which gives a signal to the gas valve letting it know its ok to open main valve. you may need a new thermacouple , might have a dirty pilot orfice or a problem with gas pressure or worse case a cracked heat exchanger in any case in less you have some type of training you should call a pro
Feb 05, 2009 | Coleman Propane Forced Air Heater...
771 people viewed this question
Top Citizen Office Equipment & Supplies Experts
Tejodhar Atreya...
Tejodhar Atreya...
jay kaye
jay kaye
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
