Question about JVC RX-E100 5-Channel Amplifier
Blown fuse no sound in one channel
After 9 days new my Primare I21 amplifier blew a channel (no sound from one speaker). The repairer said there was a blown fuse caused by shorting of the speaker wires. I find this hard to believe as i took great care to ensure this did not happen. The system was also switched off when I plugged in all my cables.
can this problem be caused by anything else? Could it be due something happening during the manufacturing process, faulty component/s? Could it have been cause by amp being dropped during transit (the retailer did mention that the box could have been dropped by the freight company.
I would be grateful for your advice please.
Many thanks
Rodg
  • 11,896 Answers
The only way this could happen is either the wires touching or a capacitor overheating and shorting out, Also hardly bumped or dropped would cause loose solder connections. Wich you should check eitherway
Posted on Feb 04, 2009
I get a fuzzy sound out of the right speaker. New speakers and wires so that is not the problem
it sounds like a blown channel in the amp.open the amp and see if there are any fuses that might be blown.it might be a blown capacitor which a tech should be able to easily fix
Nov 03, 2015 | Marantz Audio Players & Recorders
Works on one channel, have replaced the 630mA and 2A slow blow fuses but they have blown again.
Disconnect the dead channels speaker connection at the Amplifier, if the short goes away then you have a shorted speaker voice coil or wiring to speaker, if still blows the fuses you have an output Transistor circuit that is shorted, and the Amplifier will need to go to a qualified home electronics repair shop for testing and repair, be advised the average cost can exceed $100+
Dec 15, 2010 | Audio Players & Recorders
Adcom GFA-7607 7 channel brand new, watched one movie!
I think the squirrels hid them in your garage under your Shelby!
RW
Jul 19, 2010 | Adcom GFA-7607 7-Channel Amplifier
Pioneer GM-6200f amp no audio - flashing light
Hello! Yes, It certainly looks like the output power circuit has blown.
I wish I had better news.
Guru................saailer
Jan 12, 2010 | Pioneer GM-6200F Car Audio Amplifier
I was given a rockford fosgate 500x 4 channel amp and the rear 2 channels work fine but the 2 front dont when i hook up the speaker the speaker bottoms out and stays like that until i unhook the speaker...
Sounds like those two of the channels are blown. There is really nothing that can be done about that other than having an expert repair it. You might as well buy a new one tho, or just use it as it is.
You could look at all the fuses in it, make sure there not blown (they will be black and the little metal piece inside the plastic will be broke or cracked)
Post back if you have any further question's and comments. Thank you for choosing Fixya!
Nov 10, 2009 | Rockford Fosgate Punch 500X Car Audio...
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
Fuse at power cord blows
first check your speaker cabels for short circuit and speaker for  short coil .after you confirm there is no shotr of cabel wires by checking with avometer in ohm postion.connect speaker if the problem excit your speaker is guilty - change it with same configuration.about switches put it in low order and chech for sound level and you can go up after that.
Mar 05, 2008 | Krell KAV-300i 2-Channel Amplifier
P10002 blown?
needs repair bad fets or outputs
May 08, 2007 | Rockford Fosgate Punch P10002 2-Channel...
JVC RX-E100 5-Channel Amplifier Logo
886 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
