Question about Sony RM-X57 Remote Control
No Power to Control Panel Sony RM-X57
After I replaced my car battery, there is no power to control panel of my 10 disc cd changer (RM-X57). is there a reset procedure that I need to perform before my CD changer can be working again? how do I turn it ON? There is power to CD changer in the trunk and CD magazine ejects and loads OK. What should I do? Please help.
  • Anonymous May 22, 2009
    Did you ever fix this because I have the same problem.
5 Suggested Answers
Arpi
  • 326 Answers
SOURCE: I can't get the remote to work with my disc changer
Hello, please check the batteries by replacement (use fresh ones). Best regards, Arpi
Posted on Apr 06, 2007
SOURCE: Lost Instruction Manual Paper for Sony RM-V401 Remote Control
You must press "set" button (with a pen), then press "tv" followed by the code you have and finally "enter". Regards
Posted on Aug 02, 2008
  • 17 Answers
SOURCE: sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Posted on Oct 30, 2008
  • 3 Answers
SOURCE: Reset button on Sony 10 Disc CD changer
there is a reset button the the converter box that all the wires go into.
Posted on Aug 25, 2009
Same problem here. My RM-Y180 remote stopped yesterday....out of nowhere. The batteries are fine, and we even tried putting in brand new batteries. Nothing is working. Has anyone found a solution or should I just by a new remote?
Posted on Jan 13, 2010
My car battery died.when i put in a new my cd player stop working
If your radio is still working, then your power is OK. The Sony CD changer gets its power from the Sony Unilink cable. It is possible that it passed a power spike down to your CD player while hooking up your battery cables.
I just had a CDX-757MX just die a few days ago myself. My radio, amps, and other changers are still working. Could be an unfortunate coincidence.
Sep 09, 2009 | Sony CDX-454RF 10-Disc CD Changer
Cd changer not working at all.
You need to put a meter on the power wires to make sure you are getting power. If you still have a problem, post a comment and I'll help you dig further. Hope this helps
Jul 01, 2009 | Sony CDX-444RF 10-Disc CD Changer
Sony CDX-F5700 no longer sees Sony 10-disc changer
face plate is going bad lcd is fading solution--replace face
Jun 21, 2009 | Sony CDX-F5700 CD Player
How do I supply power to this cd changer?
Below is an image of Jack PCB inside unit and Fuse is marked that need to be checked.
Apr 26, 2009 | Sony CDX-602 10-Disc CD Changer
Oct 28, 2008 | Sony CDX-540RF 10-Disc CD Changer
Sony CDX-646 Autochanger: Magazine removal
go to the control socket on the sicd and put 9-12 volts straight in to the two center holes. can't remember which way round but it only works one way and what ever you do it's not gonna blow it up
Feb 04, 2008 | Sony CDX-646 10-Disc CD Changer
take down the remote and check the circuit for lose solder if there there is any resolder all whole circuit.if that does not work take a look on the amp IR could be it has cold solder or the IR needs to be replace,for parts replacement contact www.dalbani.com
Apr 06, 2007 | Sony RM-U185 Remote Control
Jumping Tracks when using "Next" control
find the "reset" button (this button usual is very small) find it in front of the control panel, if the control panel is removable find "reset" button after removed
Feb 02, 2007 | Sony CDX-T69 6-Disc CD Changer
Televison & Video Logo
94 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
