Question about Lexmark Optra S 1250 Laser Printer
Should she leave the power on all the time?
My roommate said that a teck told her it was best to leave the printer (Lexmark Optra S 1250) on all the time. Yes or No?
    Scholar:
  • 157 Answers
No, shut it down. The enemy of electronic components is heat. Besides, it wastes energy. If everyone in America who left their computers on overnight would shut them off we could have one less nuclear power plant in the US.
Posted on Feb 04, 2009
    Problem Solver:
  • 9 Answers
As a general rule, you need to look at two things to answer this question: 1.) Do you have a good, clean, generally uninterrupted supply of electricity? If so, then it won't HURT to leave it turned on all the time; but if not, you'd be best to turn it off, and even unplug it during storms and other times of like power outages. Power spikes and surges can totally ruin any electronic equipment, and printers are no exception. 2.) Does the equipment manufacturer recommend that you leave it on all the time? If so, by all means, do so. If not, it's a judgement call. Two factors that influence that decision:
  • Some printers take an inordinate amount of time to warm up and cycle to ready—if yours does, you may want to leave it on.
  • Some printers also use a whole lot of ink when they first cycle to ready, so if yours does this, it will be more economical to pay for the electricity than to pay for the ink.
I hope this is helpful!
Ken
How to cealn memory lexmark x 466
If i remember correctly you can just hold 2+6 on boot up to put you in the config mode. Next find factory defaults reset the LES (Lexmark Embedded Solutions) Base Codes and Standard Network. That should put you back to defaults.Some times it can have a add-on expansion card with memory/setup you can remove. If there is a password blocking access the system board has a jumper you can use to reset that just like a PC BIOS.
Jul 09, 2014 | Lexmark Optra S 1250 Laser Printer
MY OPTRA SE 3455 IS SHOWING THE FOLLOWING: 921 SERVICE FUSER ERROR
A 921error indicates that the fuser unit failed to reach the standby temperature.
  • If this is the first time you have seen the error, turn the printer off and on. Leave the printer off for at. least 10 seconds before turning it back on. This gives the printer's engine board a chance to reset.
  • If this is an intermittent error, you may want to check how the printer is plugged in, even if it has worked on this surge device for months. Make sure the printer is plugged straight to the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in your printer which can trigger a false fuser error.
  • If this does not help or if this error appears every time the printer is powered on, you will probably need service on the machine.
If you need further assistance please contact Lexmark Technical Support or any Lexmark authorized service provider.
Aug 12, 2011 | Lexmark Optra Se 3455 Laser Printer
I want to change language - lexmark optra t610 printer
You can change the language on your Lexmark Optra T610 by pressing right arrow Menu button 6 times -> select Printer Language (first option to appear), hit Select -> select preferred language, hit Select button to save.
Hope this helps. Thanks.
Nov 10, 2010 | Lexmark Optra T610 Laser Printer
Optra T610
If your printer only prints black pages it will require the high voltage power supply to be replaced. this will fix your problem
May 01, 2010 | Lexmark Optra T610 Laser Printer
What would cause a 900 RIP code on a Lexmark T612?
Go to http://support.lexmark.com/printerfirmware
Locate the appropriate authorization code for your printer model from the following list and enter it:
Optra S (4059) series printers: 4059engn.
Optra T610, Optra T612, Optra T614, Optra T616 printers: optrateng.
Lexmark T520, Lexmark T522, Lexmark T620, and Lexmark T622 printers: lextengn.
Lexmark T630, Lexmark T632, Lexmark T634 printers: e551416.
Lexmark W812: eng204
We recommend you choose to save the file within a directory on your computer's hard drive.
Once it has been saved, go ahead and run the file. The downloaded files are self-extracting ZIP files. Running this file will create a set of .PJL files and a file entitled Readme.1st. The Readme.1st file also contains directions for sending the file over through a parallel connection.
Oct 30, 2009 | Lexmark Optra T612 Laser Printer
I keep getting memory full and it wont clear so I can print. How do I clear the memory.
Power on the printer without the printer or networkcable attached. Check if you can print a test page. If this works there is a printjob in the system that should be deleted before connecting the printer to your computer or network.
Gerrit Jan
Oct 21, 2009 | Lexmark Optra S 1250 Laser Printer
Lexmark Optra 1275sc - 900 Service - Software Error
I have the same problem, but the error only occurs when I try to print a .pdf file (Adobe Reader) using the "Lexmark Optra SC 1275 PS" driver. For some reason the PS driver didn't like .pdf files! My solution was to always print .pdf files using the alternative " Lexmark Optra SC 1275 (MS)" driver, which Lexmark also offers on its website.
Apr 01, 2009 | Lexmark Optra SC 1275 Laser Printer
Lexmark printer CD-ROM
I have a Lexmark Optra E310 printer that works fine with the following Vista printer drivers:
Lexmark Optra E312 (MS)
Lexmark Optra E312 PS.
Aug 26, 2008 | Lexmark Optra E310 Laser Printer
977 service netwrok card 1?
see this problem is bcoz of your faulty ethernet card like netwok card . see if you can disable network feature then you can reomve your printout. bye
Sep 28, 2007 | Lexmark Optra S 1250 Laser Printer
Lexmark Optra S 1250 Laser Printer Logo
112 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
