Question about Humminbird Fishfinder 565 With Transom Mount Transducer
Humminbird fishfinder 565
Is this a 24 volt? WHen installed using 1 batt. says low voltage and powers off..but when I put a jump starter on the battery it says hi voltage and powers off> why wont this thing work
    Brigadier General:
  • 5,158 Answers
According to the manual... 10-20 VDC
Please rate this solution.. thanks
Posted on Feb 04, 2009
I need schematic of fishfinder 525 Humminbird. My equipment doesn't switch on.
no power going to unit or you have a bad key pad and its not going to come on
Sep 09, 2013 | Humminbird Fishfinder 525 406260 1
2006 Mercedes-Benz C230, the starter turns very slowly.
The batt voltage is to low try jumping it with jumper cables if it starts you need a battery
Dec 27, 2012 | Mercedes-Benz Vehicle Parts & Accessories
First thing every morn. I have to jump it off at the starter. won't work at battery. after 1st start, it will start fine all day. Battery checks out fine. It's like the power does not get to the starter...
It sounds like possible bad batt cable or connection as it takes a bit more batt power when engine is cold to crank engine. if you have a volt meter, you can check this. set to volts dc and put one lead on batt neg. post and one on engine block, crank engine, in theroy you should not see any voltage but if you do, that is whats lost in neg cable, in my exp. you will see about .5 volts if you see too much more than that, i would be looking at cable. you can do same thing on pos. side but keep in mind if you go from batt pos. to large stater pos. at stater and you have a ext. sol. like ford likes to use that your loss could be in the sol. contact as well. And under cranking mode your batt should drop to no less that 9.6 volts under load and thats tested at batt post.
Jan 24, 2011 | 1996 Dodge Dakota
I get a low voltage message and unit powers down
My name is Mike. I understand your problem. What I am doing to help you the best I can, is giving you the manual to download in PDF as well as a support number and other information to help you out. Also giving you my direct page to my Services I offer. Thanks SO Much , Mike.
Thank You, Again. Please rate my solution for my free help and some nice comments back would be grateful. God Bless, Mike
Jan 18, 2011 | Humminbird 2009 587ci Gps/fishfinder...
Jet 3 Ultra, batteries 1 yr old, charge voltage only 26.3 volts output from onboard charger when batts drained after extended use. After charging overnight, batts are 12 volts each, but chair goes 1.5...
Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Oct 30, 2010 | Jet 3 Ultra Power Chair
Turns off
The first thing you need to check is if you have sufficient power going to the fishfinder. Take a multimeter and measure the dc voltage going to the display when the unit is off and also on. If this is below 12 vdc this is your problem. You will need to check for loose connections and possibly replace your battery.
If the voltage is good then the problem lies within the display. Unfortunately, you would have to contact Humminbird directly to return the display for repair or purchase a new fishfinder.
Jun 29, 2010 | Humminbird 161 Gps Fish Finder Combo
hello there:
here is a few links that have the manual that you can download for free
  1. Humminbird 595C Manuals, Support and Troubleshooting - Fishfinder GPS Free download of Humminbird Fishfinder 595C User Manual. ... Humminbird Fishfinder 595C GPS. Need a manual? HUMMINBIRD 595C MANUAL - 96k - Cached
  2. Humminbird GPS Manual and Support Information: User Manuals: Retrevo ... largest collection of user guides and manuals on the web. ... Humminbird Fishfinder 595C. Operations Manual. Humminbird HDR 400G. User Guide. Humminbird HDR 400I - Cached
Sep 16, 2009 | Humminbird 595c GPS Receiver
Humminbird 343c will power down on its own
If the unit shuts off on its own, firstly check your power supply. I keep seeing customers running their ssounders from a small, portable battery configuration that doesn't put out the correct voltage...mostly seen with AA size batteries being rated at 1.2 or 1.3 volts (8 batteries times 1.2 volts is only 9.6 volts).
If the power supply is not the issue then I would say the internal power circuit is suspect...this can only be repaired by a competent repair person who knows how and what they are doing. If you open the unit up, you'll not only void the warranty, you run the risk of killing the entire unit from static shock.
Best of luck in your repair!
Aug 24, 2009 | Humminbird 343c Fishfinder GPS Receiver
Humminbird fishfinder keeps blowing 5v fuses .Power ok to base but as soon as you attach fishfinder fuse blows
Most probable component that has gone bad and capable of blowing the 5V fuse would be:
  • voltage regulator IV or transistor;
  • reverse protection diode;
  • zener diode;
  • shorted capacitor.
As the 5VDC normally supplies the logic circuitry, perhaps diagnosis and tests should be focused within that area.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 24, 2008 | Humminbird GPS
Low Voltage
The power inverter board is most likely starting to fail. The unit should be sent in for factory service. They will change the board and test it out to make sure that another board did not cause the fault.
Jerry G.
Nov 13, 2007 | Humminbird 595c GPS Receiver
Humminbird Fishfinder 565 With Transom Mount Transducer Logo
676 people viewed this question
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
